intermittent long crank time followed by no power - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 06-20-2014, 07:09 PM   #1
objec123
My Ride: 99 328i
99 328i, 160k.
has new vanos seals, fuel pump and filter, spark plugs, intake cam sensor, no cel, no stored dtcs
sometime if I start car right away it has a long crank time before starting. after the long crank time and it does start it has no power, drives fine, no bogging or sputtering just no power. I pull over and shut car off then restart and it start up right away and has normal power.
most of time I key on, engine off for like 5 seconds before I start to prevent this problem
wtf???
objec123 is offline   Reply With Quote
Old 06-21-2014, 11:05 AM   #2
scarede46er
My Ride: 2001 BMW 325i ZSP
Sounds like a crankshaft sensor failure. Any codes? You would need a BMW scanner to scan for them.
Old 06-21-2014, 08:59 PM   #3
objec123
My Ride: 99 328i
I have scanner, no codes.
ill check the rpm on scanner when I get a long crank
Old 06-21-2014, 09:40 PM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
BTW you do not need BMWScanner or a specific BMW scan tool for this. A standard OBDII scan tool that read real time data is all that is really needed.
Just use your tachometer as a crank sensor tool, the tach should register around 200-400 RPM when cranking.
