Old 12-29-2013, 09:42 PM   #21
Augster
My Ride: 2008 335i Sport
What I believe I used was a fine-toothed ratcheting boxed-end wrench. I have a Craftsman set, but I think there are some good brands found at your local auto parts store: you want a fine-tooth one that will ratchet even in tightly confined spaces such as that bolt.
And/or I could have come in from the opposite side that you have your wrench: from above, rear by removing the shift linkage to gain more room to get my hand up on that side.
Another technique I may have tried was to unbolt the transmission crossmember in order to drop the transmission (using a jack, of course) enough to give me extra room.
Augster is offline   Reply With Quote
Old 12-29-2013, 10:59 PM   #22
iRide113
My Ride: 2004 M3
Finally got the screw out. Ridiculous amount of force required... Next is fishing the line out.
iRide113 is offline   Reply With Quote
Old 02-24-2014, 04:57 PM   #23
jinxone99
My Ride: BMW 232i and 525i
How easy is it too fish the cooler line through?
jinxone99 is offline   Reply With Quote
Old 02-24-2014, 06:01 PM   #24
mcbonio
My Ride: 330ci sport
It involves doing one line at a time, pushing, pulling, turning and finally you'll get it out.!
mcbonio is offline   Reply With Quote
Old 03-17-2014, 07:41 PM   #25
reynaldo
My Ride: 2001 325i Sedan
Send a message via Yahoo to reynaldo
The squirrel chewed up the transmission cooler outlet.Is it difficult to replacemit? i purchased the outlet as well the inlet since i will do them self. Is it difficult to remove the bolt that holds the inlet amd outlet tube? Also there is this bulky thing that blocking the bolt.how can i remove them? Thanks , Rey
reynaldo is offline   Reply With Quote
Old 03-18-2014, 08:11 PM   #26
Augster
I believe that "bulky thing" is the transmission shift linkage, which I think I disconnected to ensure I have as much room to access the bolt holding the clamping plate that secures both cooler lines to the tranny. If I recall correctly, I was able to remove the bolt without too much fuss, even in the tight spaces; might have to "feel" your way around the bolt as once you get your hands and tools up in there I think you're then working blind. With any R&R (remove and replace), having the right and sometimes esoteric set of tools makes the work so much easier (extensions, fine-toothed ratchets, universal joints, ratcheting box-end wrenches, etc).
Old 03-20-2014, 09:53 PM   #27
reynaldo
Well i just loosen the transmission shift linkage and was able to remove the bolt. Removed and replaced the outlet. Removed the inlet but can't seem to push the inlet cooler though. I will try again tomorrow bec its getting dark now. Luckily I have the special tools to remove the lines.
Old 03-21-2014, 09:18 AM   #28
Augster
Just be patient and work slowly. Whenever it binds on something, feel around the obstruction to determine how to orientate (rotate) the line and how much force may be necessary to gently persuade (slightly bend) the line around it.
I used these cheap plastic ones from O'Reilly that still were difficult to use. Next time I have to work on such special hydraulic fittings, I will pop for a higher quality "professional" set of disconnect tools.
Old 03-21-2014, 08:20 PM   #29
reynaldo
Finally replaced the cooler inlet and outlet. The Inlet is a PiA but with a little wiggle and pulling amd twisting it was done.
Old 03-22-2014, 09:28 AM   #30
Taylor@Bimmertools
also NOT a mechanic
My Ride: BMW X5 35d
Perhaps this will make your life easier.
AST Line Disconnect Tool Power Steering & Trans Oil Cooler Lines
click the pic
Taylor@Bimmertools is offline   Reply With Quote
Old 03-26-2014, 07:49 AM   #31
mcbonio
I didn'y have the BMW tool to remove these, I just got 2 open ended spanners and taped them together at the ring ends then used the open ends to pinch the fitting open. Easy
Old 09-07-2014, 04:49 PM   #32
EDWAGON
My Ride: 2004 325xiT
Just found my inboard line to the cooler is leaking , have to tackle this ASAP .
Has anyone done this on a xi ?
EDWAGON is offline   Reply With Quote
Old 09-20-2014, 04:13 PM   #33
EDWAGON
Ok did this last night with my neighbor . Had car on race ramps Blocks much more room to work around then on jack stands.
On xi the drive shaft gets in the way but here is what I did.
To remove cooling lines attached to tranny I used a craftsman 13 mm box end wrench to get bolt out. Don't forget to order 2 orings because once you remove that 13 mm bolts both lines come out of tranny together . To get bolt back i used duck bill or needle nose pliers once in you should be able finger tighten it.
Next the best way to get access and maneuver line I had to remove alternator and move the ps resivior . This allows you to twist and turn the line better without bending it , i removed and installed inboard cooling line from the engine bay.
I used a quick release tool to remove the inboard line from cooler and a foot down there is a plastic block holding the two rigid line in place to the chassis . I think it's a 10 mm bolt. That was a pain to get to but was much easier with alternator and the cooling duct out of the way.
I think on the xi you need someone else on the other end of the line to maneuver it because that drive shaft clearly in the way and was about to remove that but got it done without.
Can't imagine what BMW would charge to do this job but it took a total time of about 3 hours. Next time I did say I could do it in 2 .
Old 08-03-2015, 10:50 PM   #34
Blademan
My Ride: 2000 328i
I just swapped ATF fluid and got nearly all the old ATF out by pulling the ATF cooler return line in addition to dropping the ATF pan, I'll post a DIY video soon. But I wound up with a leak at the quick-connect coupling. When inspecting the fitting, I felt grit/dirt operating the quick-connect. Tried some WD-40 as suggested to clean it out, and wrapped some Teflon tape in case the O-ring was failing. Just before I reinserted the line, I looked very closely at the mechanism, and noticed one of the plastic tabs had broken off and was sliding around, possibly blocking one of the metal tabs. Removing the broken tab + Teflon = no leak. Perhaps spraying WD-40 before removal will remove the grit/dirt around the quick-connect. I did use this tool to remove the hose as cleanly as possible, so I'd guess the grit/dirt caused the plastic tab to break.
Originally Posted by MIRoundel View Post
Here is the picture of "quick-connect coupling" and O-ring is marked with RED colour.
Blademan is offline   Reply With Quote
