Sponsored by BimmerWorld
Old 01-15-2010, 08:25 PM   #1
BimmerDoc
My Ride: E46 AWD, ///M Coupe
Send a message via AIM to BimmerDoc
front suspension "clunk"
Driving over small bumps i have the "clunk" noise on the front of my car
BMW tech (a friend of mine) said this stuff has to be replaced. He just replaced my cam shaft position sensor and ran the diagnostics on it, and everything checked out. I was worried about the clunk noise so I had him inspect everything, and this is what came out as being needed.
L&R Front swaybar links
L&R Lower control arm bushings
L&R Front struts & pads???
Anyway where is the cheapest place to get these parts. I have aftermarket sway bars Eibach. Should I call BMW for these parts or is there an online or source that may be cheaper?
BimmerDoc is offline   Reply With Quote
Old 01-15-2010, 08:34 PM   #2
gofastgoodiez
My Ride: 00 328i
Assuming you have factory suspension aside from the sway bars, you should be able to get factory replacement parts at any reputable auto store (Napa, McLaughlins etc).
gofastgoodiez is offline   Reply With Quote
Old 01-15-2010, 10:55 PM   #3
BimmerDoc
Ball joints and swaybar links? Also I am still confused about "factory" suspension or sport. I am not sure what my car has. It is lowered, but it was purchased that way
Old 01-16-2010, 09:34 AM   #4
Hartman
My Ride: 2000 323i
Clunking is usually caused by end links.
Hartman is offline   Reply With Quote
Old 01-16-2010, 09:03 PM   #5
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
Replace the front upper strut mounts first. I spent 3 years chasing that down on my own car, so far I've replaced every single front suspension/steering part besides those and the car clunks TERRIBLY
hi its me alec is offline   Reply With Quote
Old 01-16-2010, 09:32 PM   #6
jbugg328
My Ride: BMW 328ci
went to a german shop today near me in edison,nj
Went to give a quick check because i had vibration in the steering(shakes) everytime i hit the brakes. So i didnt know exactly what it was. Anyway, so i decided to bring for a quick check, he said rotors seem fine, but i needed to replace l/r control arm bushings.
WITH LABOR AND PARTS= 300 BUCKS
iS THAT A REASONABLE AMOUNT??
Instagram : JrVincent7
jbugg328 is offline   Reply With Quote
Old 01-17-2010, 12:03 AM   #7
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
That's not bad. Does that include alignment? You will need one.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 01-18-2010, 10:33 AM   #8
jbugg328
My Ride: BMW 328ci
^ um idk
i should ask
Old 01-18-2010, 11:01 AM   #9
Riverbmr3
My Ride: MB E350 & BMW 325i
oem parts can be ordered thru Tisher.com
Riverbmr3 is offline   Reply With Quote
Old 01-18-2010, 01:30 PM   #10
ECSTuning
ECSTuning's Avatar
My Ride: BMW
99% this is your problem is your sway bar end links. I have done this on my personal E46 and we have done it on our shop E92.
We have several options available, however I recommend the use of MEYLE HD (Heavy Duty) replacements. They are a perfect upgrade over the stock units, and include a 4 year warranty from Meyle!
Old 01-18-2010, 02:31 PM   #11
n2Bimmer
My Ride: Loves Corners
Dont go all out replacing everything. Replace what is cheaper first.
Old 01-18-2010, 02:32 PM   #12
n2Bimmer
WHATT, 4 years? thats awesome.
