Old 01-15-2010, 09:35 PM   #1
E46onE70
My Ride: 325i
How can I mount my GPS on the dash?
I just bought a 2003 325i and am trying to mount a GPS on my dashboard. I tried the dash mounting sticky disk that came with the GPS and even had them send me a new one because I thought that maybe the glue had dried out. But neither the new disk, nor velcro or double-sided tape will stick to that dash. Has anyone had this problem? The suction cup works fine on the windshield but it kind of obstructs the view. Help please. Oh, and yes, I did clean the dashboard before I tried to stick the suction cup disk.
E46onE70 is offline   Reply With Quote
Old 01-15-2010, 09:44 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
One drop "Dawn" dish soap, & tooth brush-scrub.
Clean off.
Alcohol, & tooth brush-scrub
Clean off.
Should work.
SUMMIT POINT WV 1:24:229 SCCA
Old 01-15-2010, 09:49 PM   #3
Marley78
My Ride: 325I
i bought a vent mount holder. my disc thing looked out of place on my dash and seemed like it nearly destroyed my dash when i tried to remove it. I think the vent one looks cleaner and removes easier
Marley78 is offline   Reply With Quote
Old 01-15-2010, 10:16 PM   #4
BobSC
My Ride: 01 330Cic, 12 750Li
Take a look at this thread...
http://forums.bimmerforums.com/forum....php?t=1158529
I thought it looked pretty good in his DIY
Also, take a look at....
www.kudausa.com
They have some unique holders / mounts on their site.
2016 X5
2012 750Li (Sold)
2012 X3
2007 750Li (Sold)
2004 X3
2001 330Cic
2000 328i (Sold)
BobSC is offline   Reply With Quote
Old 01-15-2010, 10:30 PM   #5
Steve330ci
My Ride: 2006 325ci vert
Pro-Fit
I use a Pro-Fit mount for my GPS. The Pro-Fit attaches underneath the trim piece around the radio and sits to the right of the A/C controls. Search for Pro Fit and you'll likely find several photos.
Steve330ci
2006 325ci vert
Steve330ci is offline   Reply With Quote
Old 01-15-2010, 11:04 PM   #6
jorg323
My Ride: 1999 323i
Well, this might give some placement suggestions:
http://forum.e46fanatics.com/showthread.php?t=699440
Or you can do what this guy did, if you got the skillz...
http://forum.e46fanatics.com/showthread.php?t=644666
18" Black ASA AR1 Rims | Yokohama Advan S4 Tires | Bilstein Sport Shocks | Eibach Pro-Kit Springs | Brembo Slotted Rotors | 6000k Xenons | 6000k P. Chrom. Angel Eyes | Eagle Eye LED Tail Lights | K&N FIPK CAI | M-Tech II Front Bumper | 35% Tint | Clear Corners | Matte Black Grille
jorg323 is offline   Reply With Quote
Old 01-17-2010, 09:49 PM   #7
E46onE70
My Ride: 325i
Thanks for all the great input. Thanks a lot.
Old 01-18-2010, 09:51 PM   #8
trudnick
My Ride: 2005 M3
Not really "on" the dash, but here's what I came up with http://www.m3forum.net/m3forum/showthread.php?t=301244.
2005 BMW ///M3 / Carbon Black / Black Leather / 6MT
OEM BMW Performance Short Shift Kit, Illuminated ZHP Knob, XM Direct, DICE iPod, Color Matched Reflectors, Hoen Fogs, Stealth Corners, V1 (3.872) Hardwire, Eibach Pro-Kit, RE 15mm-F/12mm-R Spacers, CDV delete, Clutch Stop, Summer OEM ZCP 19s: Vredestein Ultrac Sessantas (245/275), Winter OEM 18s: Dunlop SP Winter Sport M3s (225/255), Self-installed OEM Alarm & OEM Homelink UGDO.
trudnick is offline   Reply With Quote
dashboard, gps, non-stick
