Old 01-16-2010, 10:25 AM   #1
BQuicksilver
My Ride: 330i
Yikes - Broke the Crankcase Vent Tube...
Okay, so how much trouble is this fix going to be?
While doing my valve cover seal job I broke off the crankcase vent tube clean while pulling it. Honestly, I can't see how I could have saved it. It's unreal how brittle plastic is under the hood of these cars.
Anyone have experience with this fix?
BQuicksilver is offline   Reply With Quote
Old 01-16-2010, 10:38 AM   #2
BlacknBlueFL
My Ride: 2003 325i
I would say that is going to have to be a replacement job. Repair just seems out of the question from the picture.
BlacknBlueFL is offline   Reply With Quote
Old 01-16-2010, 10:38 AM   #3
Mclovin1458
My Ride: 2005 325ci, zsp/zpp
Have u stuffed it up with mayo?
Mclovin1458 is offline   Reply With Quote
Old 01-16-2010, 10:44 AM   #4
aioros
My Ride: 2001 330xi auto
You will need to change it and maybe the CCV as well. that hose goes to the CCV. a quick fix would be using aluminum tape. it will stand the heat and seal it.
aioros is offline   Reply With Quote
Old 01-16-2010, 10:49 AM   #5
blacksport325
My Ride: 98 M3, 318is, CBR600
Its an easy fix, I believe that hose is about 25 bucks at BMW, the only hard part is getting you hand all the way in the back where the other side connects but it shouldn't take more than 10 minutes to change out. It's number 2 on the diagram below, says $25.75 for the part.
blacksport325 is offline   Reply With Quote
Old 01-16-2010, 11:01 AM   #6
aioros
Its going to take more than 10 mins
Old 01-16-2010, 11:45 AM   #7
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
lol at 10 min. now, you might as well do the ccv and all the hoses since you already broke it. they are a pain in the butt but always need to be replaced on e46's
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 01-16-2010, 12:03 PM   #8
olinjohnston
My Ride: Dakar 330Xi + ESS TS
Send a message via AIM to olinjohnston
You gently wiggle it from the valve cover instead of pulling on it...
Reasonably easy fix though. You could also substitute a better (flexible) hose and clamp it the old elbow fitting so it doesn't happen again
olinjohnston is offline   Reply With Quote
Old 01-16-2010, 12:18 PM   #9
TxTorqueMade
My Ride: 330i
Send a message via Yahoo to TxTorqueMade
The entire kit cost something like 146.00 including the CCV. The DIY is a PITA but worth doing, especially if your up North. Be sure to order the upgraded Canadian version. Could be they dont even sell the non-upgraded version any longer.
Good luck
BMW e30 Bling
TxTorqueMade is offline   Reply With Quote
Old 01-16-2010, 12:18 PM   #10
blacksport325
I dont know about replacing the entire CCV, but the hose literally took me 10 minutes, just fitting a hand down there is the hardest part and getting the tube off, I didn't take anything out to get the hose off, might have been easier if the intake box was out though im guessing.
Old 01-16-2010, 01:32 PM   #11
Lbert
My Ride: 325i
See post #107
http://www.bimmerfest.com/forums/sho...parator&page=5
Lbert is offline   Reply With Quote
Old 01-16-2010, 01:50 PM   #12
Toad21
My Ride: 00' 328CI
I had this exactly happen to me during my Vanos repair. The ideal solution to replace the whole tube.
I used alot of black tape, and it has held up over the last year no problem.
Toad21 is offline   Reply With Quote
Old 01-16-2010, 03:35 PM   #13
genuity
My Ride: E46
genuity is offline   Reply With Quote
Old 01-16-2010, 03:42 PM   #14
AEmedic
My Ride: 2008 528i
Send a message via Yahoo to AEmedic
I did the same, it lasted till I got the replacement CCV sys.
Chris
2008 528i - Deep Green Metallic
AEmedic is offline   Reply With Quote
Old 01-16-2010, 07:04 PM   #15
BQuicksilver
My Ride: 330i
Yeah, thats what I did. It was amazingly brittle. I just held it with a Knipex Cobra so I could focus on pulling easy...it was doomed from the start. My valve cover seal and plug seals were just as brittle. I dropped a spark plug seal (the set of three) and it shattered like a piece of tempered glass.
Is this normal for a car with 80k on the clock? Are new seals less prone to this, or is this a side effect of some form of abuse by the previous owner?
As noted, it seems like my other CCV hoses are affected as well.
Old 01-16-2010, 07:15 PM   #16
lkstaack
My Ride: 04 330iZHP, 05 325iT
A 3/4" hose would fit over those pieces. An alternative to replacing that brittle plastic hose. Keep the original elbow, but cut off the hose that covers the end. A single 3" piece of 3/4" hose would then patch the split.
Lars
2004 330i ZHP ESS TS2
lkstaack is offline   Reply With Quote
Old 01-16-2010, 07:46 PM   #17
hendrich
My Ride: 01' 325ci
Send a message via AIM to hendrich
having this hose broke affect you car in which way?
hendrich is offline   Reply With Quote
Old 01-16-2010, 08:08 PM   #18
E46330iguy
My Ride: Supercharged 330i
No need for this dam kit this is what you need right here
Winter Authority When Hell freezes over,we'll play Hockey there too
you've Met a terrible fate haven't you ?
KONI /Michelin/Stoptec/ Bimmerbrake / MTechII/AA Stage one (for now) Automatic--->5 speed swap/ UUC High performance clutch kit
Questions about Header wrap? clickHere
Supercharger build thread click Here
E46330iguy is offline   Reply With Quote
Old 05-03-2010, 10:23 AM   #19
mbadger
My Ride: '02 325i '95 325ic
I'm now officially a member of the Broken Crankcase Vent tube club
mbadger is offline   Reply With Quote
Old 05-03-2010, 10:29 AM   #20
330I6SPD
My Ride: 2005 330I 6Spd.
Look like he used.............
Name:	baconnaise poster.jpg
330I6SPD is offline   Reply With Quote
