Old 01-16-2010, 07:31 PM   #1
tko200
My Ride: 01, 325i
lower intake boot job
my engine soon light was on i suspected i had a vaccum leak somewhere, check my lower intake boot and it was ripped open, it's a tuff diy i had
to remove the plastic pieces from the firewall and the adjuster the diy is nightmare.
tko200 is offline   Reply With Quote
Old 01-16-2010, 07:35 PM   #2
Golden330ci
My Ride: 330ci
just replaced mine...wasnt fun
Golden330ci is offline   Reply With Quote
Old 01-16-2010, 07:42 PM   #3
e46Scrub
My Ride: 2001 330i
Just did this as well. I had to replace both that piece and the piece above it PITA. They made it really tough to get in there it really is a pain to reach.
e46Scrub is offline   Reply With Quote
Old 01-17-2010, 11:00 PM   #4
GEEZ_ITS_A_BMW
My Ride: 2000 323I
while you were down there hope you cleaned your throttle
GEEZ_ITS_A_BMW is offline   Reply With Quote
Old 01-17-2010, 11:32 PM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
It's not hard at all to do the job...
Old 01-18-2010, 07:35 AM   #6
magnuzza
My Ride: Black 323i
Just like jake said, not that hard for me, took about 40 minutes from start to finish. Definitely worth the work, my MPG increase by 1 yay!
magnuzza is offline   Reply With Quote
Old 01-18-2010, 10:46 AM   #7
02gtstang
My Ride: 2005 zhp coupe
i replaced mine last week when i did the ccv valve and all its hoses. i had problems with the wiring harness box being in the way as i was using a 6mm rachet to remove them, my big hands and a screwdriver had trouble getting in there. lol.
2001 325i sport 5spd topaz blue R.I.P.
2005 330ci zhp 6spd black on black
02gtstang is offline   Reply With Quote
Old 01-18-2010, 11:37 AM   #8
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Very common! Replaced the one on my E46 330i, and E53 X5.
Usually a very easy & inexpensive DIY! We have them available
Old 01-18-2010, 12:35 PM   #9
Illogical_Mind
My Ride: 2000 323Ci Conv.
I've never taken my cars anywhere besides inspection, when you guys call a job like this a DIY, i feel like i'll be a pioneer when i turbo my 323 for under 2k. Does the dealer give KY also for work like this?
Illogical_Mind is offline   Reply With Quote
Old 01-18-2010, 12:46 PM   #10
nathancarter
My Ride: 02 330i
Calm down there, big shot. Not everyone sprang fully-formed from Zeus's head with a torque wrench in one hand and their **** in the other hand.
nathancarter is offline   Reply With Quote
Old 01-18-2010, 12:57 PM   #11
derek0606
My Ride: 01 330CI Orient
^i thought that was normal?
Wasn't all that bad of a DIY.
derek0606 is offline   Reply With Quote
Old 01-18-2010, 02:14 PM   #12
Illogical_Mind
lol i'm just playin, i'm nothin but happy about bein able to work on a car. It scares me to know that theres some things, like gettin my daytime lights turned off, that you just can't do without a garage. Lucked out that there is an indy BMW garage near me. don't get upset. This ****'s expensive.
I also just feel like there's a lot of stuff on these that can be explored and worked with. Everybody on here just immediately says don't waste your time when there is a modding question. I feel like a 10 year old car has more aftermarket options by now then it did when some of these posts were made.
Old 01-18-2010, 05:37 PM   #13
Hartman
My Ride: 2000 323i
The hardest part on that boot is that the hose clamp is inverted for some reason. That makes it 10x harder than it needs to be.
Hartman is offline   Reply With Quote
Old 03-09-2010, 12:18 AM   #14
lecourasa
My Ride: 2001 330i
I am trying to get mine out now to clean the icv and I am stuck at this point. The clamps are on the underside and i have no way of reaching them to loosen them. How did you overcome this challenge?
Any help is very much appreciated.
Frustrated,
Alexis
lecourasa is offline   Reply With Quote
Old 03-09-2010, 12:26 AM   #15
Jblack4083
My Ride: E46 ///M3 Vert JB/CB
Send a message via AIM to Jblack4083
Frustrated,
Alexis
Same thing happened to me. If you reach deep into the engine bay where the air box was before you removed it (hopefully you removed it), you can stick a screwdriver onto the back end of the bolt for the clamp. Then take a hammer and hammer it so it is eventually facing upward enough for you to unscrew it from the top of the engine bay looking down (to the ground)
That helped me.
For Sale:
  • Automatic Climate Control - $40
  • Turn Signal Indicator and Wiper Lever w/ center circular piece - $35
Jblack4083 is offline   Reply With Quote
Old 03-09-2010, 12:30 AM   #16
stigg
My Ride: 2003 325 Wagon
Frustrated,
Alexis
I used a gearwrench type ratchet with an addon to go in the wrench to let it hold sockets. since the head swivles both ways on the particular ratchet I used I could point it back torwars me and lower it around the shadow of the intake boot to do the work. I was struggling the last time I did this before I found that out.
Naturally when I put them back on I had the screws facing up towards the hood.
stigg is offline   Reply With Quote
Old 03-09-2010, 11:04 AM   #17
nathancarter
My Ride: 02 330i
Flexible screwdriver will make short work of those hose clamps.
Old 03-09-2010, 11:15 AM   #18
rowdy lee
My Ride: 2000 323ci
yes...
The only ones to think about how to install something so it can be gotten to are mechanics.
The guys who build 'em don't have to worry about taking them apart.
I'd buy it in a heartbeat... if only I wasn't living on the moon!
rowdy lee is offline   Reply With Quote
Old 03-09-2010, 07:30 PM   #19
DaHammer
My Ride: 2003 325i
I used a 1/4" drive flexible spinner handle with a 6mm socket. You can find them at Sears for under $10. Might also want to get a 1/4" drive flexible extension, in case you need it a little longer. I got the one on the ICV off with a piece of RG6 TV cable with a 6mm socket rammed onto the end and taped, before I finally broke down and went to Sears for the spinner handle.
DaHammer is offline   Reply With Quote
Old 03-09-2010, 07:32 PM   #20
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
Amen to that. I did mine as preventative maint in 90 degree heat last summer and it sucked... it was like giving birth except in reverse.
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is offline   Reply With Quote
