Old 03-09-2010, 07:32 PM   #21
dabdibridgep
My Ride: 04 330ci 6 M/T
this is a good one.
http://forums.bimmerforums.com/forum...rchid=15819655
dabdibridgep is offline   Reply With Quote
Old 11-20-2013, 02:46 PM   #22
marblesmike
My Ride: 2002 325ci
Bumping this old thread.
I'm about to change my MAF and plan to do both the upper and lower boots while I'm at it (already have the parts). Does anyone know of a decent DIY guide for just the lower boot? I found a good one for everything else but not for the lower boot. Yes, I tried Google and searched all the BMW forums.
I should also mention I got new hose clamps while I was at it. With the lower boot, it seems the issue is that the clamp screws are hard to get to. If I have a replacement clamp, should I just cut the old boot off?
marblesmike is offline   Reply With Quote
Old 11-20-2013, 02:58 PM   #23
FenderGuy05
My Ride: 2002 BMW 325i
I don't think you need a diy to get this done. I did the job a little while ago, the first attempt didn't work because I didn't have the right size wrench. I was trying to use SAE when I needed a 6mm. Thought I could get away with something close, definitely not. Remove the plastic firewall between the brake fluid res and the fuse box.
While you are there you should definitely clean your intake and your ICV.
FenderGuy05 is offline   Reply With Quote
Old 11-20-2013, 02:59 PM   #24
FenderGuy05
Also, if you search for an ICV or throttle body cleaning DIY, they would have instructiosn for removing the lower boot.
Old 11-20-2013, 03:23 PM   #25
marblesmike
My Ride: 2002 325ci
Super, thanks for the tips. And thanks for not calling me out for being a noob asking too many questions :-)
Old 11-20-2013, 03:30 PM   #26
breadvanracing
My Ride: E46 328Ci, Z3 MC
I found that repositioning the clamp so that the screw part is at 12 o'clock and pointing forward, loosening the electrical box and pushing it outboard a little gives good access with a regular hex driver. Those boots all fail in the same spot, it is a gimme when I've looked at cars for people.
breadvanracing is offline   Reply With Quote
Old 11-20-2013, 03:38 PM   #27
jfoj
My Ride: 330CiC, M5, X5
http://forum.e46fanatics.com/showpos...&postcount=147
Old 11-20-2013, 03:47 PM   #28
qthegenius
My Ride: E36 M3, E46 323i
it's a pretty straight forward job, to be honest.
qthegenius is offline   Reply With Quote
Old 11-20-2013, 04:01 PM   #29
FenderGuy05
It is, for me is was just difficult with the way that the hose clamp was facing. Basically it was facing down, toward the engine, and my hands were too big to be able to do it any other way.
When you put the new lower boot on, be sure to face them in a more convenient way to hopefully make it an easier job in the future, if you ever need to do this again.
Old 11-20-2013, 04:05 PM   #30
Zell
Zell's Avatar
My Ride: so turbo wow
The worst part is the lower hose clamp on the throttle body. Evil, evil, evil. It's situated so that it's easier to get it from under the car. I guess that's how they put it on at the factory. If you've got big hands or arms, it's not fun to get it undone
Just remember to turn it the right way when you take it off! I made it so that once I remove the ICV I can see it right there without a problem.
Old 11-20-2013, 04:21 PM   #31
FenderGuy05
Yeah, I never removed the throttle body, cleaned it while it was on the engine.
Old 11-20-2013, 09:49 PM   #32
7xWDC-MSC
My Ride: 2005 325xi
If you're a visual guy, watch the first part of this video, he shows how everything comes off to get to the boot. But as stated, it's very simply minus the hose clamps
Rubs the roundel on its skin or else it gets the hose again.
7xWDC-MSC is offline   Reply With Quote
Old 11-21-2013, 12:40 PM   #33
marblesmike
My Ride: 2002 325ci
Awesome, thanks guys. I think I got this. Of course, just as I was talking to my buddy about setting time aside for this diy this weekend my brother calls me and tells me he needs me to help him change the coolant temp sensor and an O2 sensor on his Nissan Frontier pickup...and OF COURSE there aren't any guides or videos for half of that job.
Old 11-21-2013, 01:42 PM   #34
VishTheFish
My Ride: Ex M54B30 ZHP
Anybody read the title too fast as "lower intake BOOB JOB?"
...No?
Fvuk I'm having a strange day.
VishTheFish is offline   Reply With Quote
Old 11-21-2013, 04:11 PM   #35
marblesmike
My Ride: 2002 325ci
...No?
HAHAHA no idea what that would be
Old 11-21-2013, 04:39 PM   #36
WDE46
My Ride: '13 128i, '04 330Ci
The LITB was most certainly installed at the engine plant.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 11-21-2013, 04:57 PM   #37
futureSubie
My Ride: ZHP
If youre replacing the old boot, why not just cut apart the boot for easier access on clamps?
futureSubie is offline   Reply With Quote
Old 11-21-2013, 05:06 PM   #38
marblesmike
My Ride: 2002 325ci
Originally Posted by AW_ZHP View Post
If your replacing the old boot, why not just cut apart the boot for easier access on clamps?
That's exactly what I was wondering.
Old 11-21-2013, 06:02 PM   #39
330ism
My Ride: 2004 330I ZHP
lower intake boot job
+1 that's how I did mine
330ism is offline   Reply With Quote
