#1 |
My Ride: 02 325i, 03 SC COBRA
DIY: For HID FOGLIGHTS 02 front bumper/round bumper
I wasn't intending to make a DIY but I was looking at pics I took and I thought to myself that I think I have enough pics to help alot of guys out.
First of all, I got my fogs hids from ddm. Make sure you get H11 ballasts because they sent me I believe the h7 ballast but I still made it work. I've never done a diy so if I leave anything out please help out guys. Here we go. What I mean by round bumper is the bumper in the pic below. 1. The first thing I did because I tried every other method with fail, is jacking the car up and removing the front tires (one at a time that is). ![]() ![]() You are going to want to get under the car and release some of the screws and clip ons to get the inside fender? to move so you can get working. The pic below is the foglight housing witht the bulb removed...You twist the bulb and remove it. DON'T throw the bulb away. You won't be using it now but you might have issues with you HID fogs and you might decide to go back to halogens. ![]() Here was my issue. The ballast connector wouldn't fit the oem connector, so I used some other connectors that came with another set of HIDS from before to make it work. I don't got pics of that but heres the H7 Ballast connector vs H11 connector. H11 is smaller ![]() vs ![]() Fog ligh hids have been known to cause electrical surges which basically reset the cluster when you hit the fog light button. I've spoke to some peopel that all they get is the dash light flashing once real quick. I Installed all this yesterday and knew nothing about this problem untill it happen. I flashed someone with the highbeams while i was on the highway, speedo and everything else jumped to max and went back down. I tried to get it to do it again so i can see whats causing it but I guess its just a 50/50 thing. Anyways, I didn't use a harness, even though i have one, I didnt use it because bmw really does let you have space to work with accessories, or at least i think so. So basically i plugged and played the HID fogs and used 3-4 straps to get the ballast and the wirring to hang securly inside the bumper. If you leave the ballast just there on the floor of the bumber/inside fender the chances are that water will get inside when you hit a puddle of water or something. I tapped all the electricals just in case something of that was to happen. ![]() ![]() One side down another to go.Put everything back in the order you take it off. READ THIS !!!!!!!!!!!!!!!!! When you do the driver side, your going to end up unplugging something and say oo heck with it and your going to be excited to get the hids working and your going to forget to connect that wire ...make sure you connect it. I forgot to connect it (its the temp sensor) and now the temp says its -40 F. I'll have to wait to get that done because its raining outside. MORE PICS: ![]() ![]() LEt me know if you have any questions. Thanks for reading this DIY, hope I helped. |
#2 |
great DIY. thanks
mujjuman
![]() 2003 325xi 5MT Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP sig by Solidjake |
#3 |
Thanks mike! I have a Q, instead of putting it up the jack can i turn the wheel to the other side and just take out the inner fenders and work from there?
#4 |
you would think its that easy but beleive me its a real tight squeeze and id recommend you see what your doing for at least one side...Just to let you know, you turn the inner fender outwards. I couldnt get the clip for the world. Let me know if you need anything else. If you do jack the car up, put a brick infront of the front tire and back tires and kick them in, or you can get the plastic thing thats made for that. yea just let me know
#5 |
Thanks dude...Its my first, I never thought I can contribute to such a great site but I did. Who would of knew
#6 |
DK Jack Sparrow
My Ride: 328Ci | Range Rover
HID fogs FTW
![]() Everything you need to know on muffler deletes : http://forum.e46fanatics.com/showthread.php?t=745244 Back Up Camera for E46 : http://www.youtube.com/watch?feature...&v=ckrDiAClGgM Muffler Delete on E46 : https://www.youtube.com/watch?v=ofYhRq0T3eI ![]() |
#7 |
#8 |
#9 |
I need to do this mod.
Filbert
Originally Posted by nawmean? I know I sound naive, but some of the advice I've taken from this board has helped my life quite a bit |
#10 |
nope and im not hoping it will. did you hook up any other lights on ur car that might of needed resistors? that may the problem. the only reason im getting HID is because I have white halogens on my car but one of them arent working. I HOPE its not the wiring. |
#11 |
sweet diy
#12 |
Well... heres an update of my project, I haven't had it happen today which is sweeet. I really think its my battery more than anything because i've read only ppl with 55w have these problems...I have 35w low / 35w fogs. So far it has only happen 3 times. My car is a 02 and it still has oem battery. I had my brother drive the bimmer and I drove infront of him...The look made me speechless. I have the hids in the low beam set up in a halogen headlight, i think i had more output with the halogen, the light is just blown all over the road and in the air, idk I prob put the bulb in there wrong. Did you end up taking off the tires? lol
#13 |
UPDATE!!!! ATTENTION!!!!
Guys!, if your doing this pay attention and make sure!!!! that you tighten inner plastic fender!! Make sure the screws aren't broken or anything, use zip ties if you need too. I was on the highway going 120 when the inner fender flew off the car...yes flew off the car! and got crushed by another car. Im getting one from the stealership tom, you need this because the fender protects the HIDs...Gluck |
#14 | |
#15 |
My Ride: '03 325i --> '13 GTI
Nice DIY! Definitely will come in handy...
BTW, where did you get your angel eyes from? And do you have a link to the H11 bulbs? I tried searching on their site but couldn't find it |
#16 | |
http://www.ddmtuning.com/index.php?p...=102&parent=85 |
#17 |
Mike I got them!!!! It drops my jaw every night. And thank god no cluster problems (knock on wood)
#18 |
Nice DIY, I've been thinking about doing this. Still not sure, but I would definetly use a relay harness. BTW, If you remove the headlights you can access the fogs.
Edit: You should also look into using watertight connectors. http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=h11+connector&_sacat=See-All-Categories
#19 | |
#20 |
congrats man..I'm glad you like them, they are def. a win My cluster thing went away
