Thread Tools Search this Thread Rating: Thread Rating: 19 votes, 5.00 average. Display Modes
Old 01-18-2010, 12:13 PM   #1
MGSteve
My Ride: MG ZT
CAN Bus Information
Hi, does anyone have any reference guides to the message IDs used on the Can Bus?
I plan to write a little app to view/log these messages on my CarPC, but obviously need to know what the IDs of the messages translate into - i.e. which one is speed / revs / coolant temp etc..
I've seen references to J1939, but not sure if that's the actual implentation used on the E46 platform.
Any help appreciated.
TIA.
MGSteve is offline   Reply With Quote
Old 01-18-2010, 04:11 PM   #2
zbi701
My Ride: E46 318i
I think e46 use BMW DS2 protocol. Try searching in opendiag in yahoo group.
zbi701 is offline   Reply With Quote
Old 01-18-2010, 07:26 PM   #3
MGSteve
My Ride: MG ZT
Isn't that OBD related though, the Canbus isn't actually connected to the OBD port on our cars (nor on some E46s I think).
There is a can bus though on the car as I've seen it noted on the wiring diagrams.
Old 01-18-2010, 07:30 PM   #4
GCoop
My Ride: '04 325xi
TIA.
Can't be of any help. Sorry. Though I am interested in what you find out/are able to develop. Keep us posted. Good luck
GCoop is offline   Reply With Quote
Old 01-18-2010, 08:15 PM   #5
GoingNuts
Just Nuts
My Ride: 2004 330Ci
Who needs a bus when you can drive.
GoingNuts is offline   Reply With Quote
Old 01-19-2010, 03:10 AM   #6
MGSteve
My Ride: MG ZT
*sigh*, there's always one isn't there
Old 01-13-2011, 08:11 PM   #7
SweTurbo
Big Pimpin'
My Ride: 323i -98
Anyone has any info on what wires(and where to find them) is the canbus ?
I've read of GREEN(HIGH)/BROWN(LOW) coming in/out of the LSZ, correcto ?
Old 01-13-2011, 08:40 PM   #8
TerraPhantm
My Ride: M3 & ZHP
Any particular reason you want to use the CAN bus? On the e46, all information is available over the K-bus
Old 01-13-2011, 08:43 PM   #9
thefrog1394
My Ride: e46- 1999 323i
You want K-bus, thats what the BMW uses for communication. Not sure what protocol the ODB port uses but only a limited subset of information that is required for emissions purposes is available on that.
Photo in Cleveland, Ohio
1999 323i - Totaled at 265,000 miles.
Now an e30 & e90 owner.
thefrog1394 is offline   Reply With Quote
Old 01-13-2011, 09:24 PM   #10
El Zilcho
My Ride: 2001 325xi
Why not? Isn't it supposed to be?
From http://www.obdii.com/connector.html :
Pin 2 - J1850 Bus+
Pin 4 - Chassis Ground
Pin 5 - Signal Ground
Pin 6 - CAN High (J-2284)
Pin 7 - ISO 9141-2 K Line
Pin 10 - J1850 Bus
Pin 14 - CAN Low (J-2284)
Pin 15 - ISO 9141-2 L Line
Pin 16 - Battery Power
El Zilcho is offline   Reply With Quote
Old 01-13-2011, 09:27 PM   #11
El Zilcho
My Ride: 2001 325xi
This is interesting. I've been interested in watching the traffic on the can bus for a while. I thought of getting a converter from CAN to something like USB and then writing some software to read the signals from USB.
Old 01-13-2011, 09:37 PM   #12
SweTurbo
Big Pimpin'
My Ride: 323i -98
I need the CAN bus because i have a CAN datalogger which will send speed signal to my headlight leveling system
My ODB II connector only has 4 wires though (2 of which are GND if im not mistaken) :/
Old 01-13-2011, 09:45 PM   #13
El Zilcho
My Ride: 2001 325xi
How does it work? Does it have local storage that you can view afterwards, or can it feed live data to a computer?
Did you buy it somewhere, or did you build it yourself?
Old 01-13-2011, 10:22 PM   #14
thefrog1394
Its the K-bus that is not connected on all cars. On the cars with the round diag plug under the hood the K bus is not connected to the OBD port.
FYI not all those pins are connected on the OBD port. Newer cars connect CAN but older ones did not. It was only mandated in the US in 2008
A quick google search leads me to believe that the e46 does NOT have a CAN bus. It uses ISO 9141-2 on the diag port. If you want to decode speed information your best bet is probably to get a USB VAG-COM adaptor and use BMW INPA/EDIABAS and connect to your car's K-line. Google around INPA and you will find more information on it. Its a great tool to have anyways, you can read way more specific information from the cars computer besides the generic stuff that the OBD reader tells you. Think how the Peake tool is advertised only this is what BMW dealers and factories use. (well dealers use DIS but, whatever I digress, both talk to the computer through the K-line)
Old 01-13-2011, 11:11 PM   #15
SweTurbo
Big Pimpin'
My Ride: 323i -98
It just feeds data to the adjuster , but as it provides a 1mhz output for every km/h hooking up a logger would be pretty much cake
I bought it
Old 01-13-2011, 11:27 PM   #16
JJR4884
My Ride: BMW
did anyone else read the thread title and wonder why the "i" was missing
eeeeeeeeeeeeeeeeeps
JJR4884 is offline   Reply With Quote
Old 01-14-2011, 12:31 AM   #17
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
The CAN bus does not go to the LSZ. There seems to be two different wire colors for the CAN Bus. Between the ABS, steering angle sensor, instrument cluster, DME and adaptive headlight control unit it's CAN+ is Yellow/Red and CAN- is Yellow/Brown. Between the DME and the transmission control unit it's CAN+ is yellow and CAN- is white. The CAN Bus does NOT connect to the OBDII connector nor does it connect to the older DLC-20 connector under the hood.
K-Bus doesn't have any engine information. You might be thinking K-Line (ISO 9141-2) which is available on the OBDII port. If you want engine specific information it's safest to go through the OBDII port, K-Line. If you look at the wiring diagram it's called D_TXD2.
Pin 2 - J1850 Bus+
Pin 10 - J1850 Bus
BMW E46 does not use J-2284 and CAN bus is not available on the OBDII port. The E46 uses ISO 9141-2. Look at the connector, pins 6 and 14 (CAN J-2284) are empty as well as pin 2 & 10 (J1850) and pin 15 (L-Line is optional in ISO 9141-2)
Be careful messing around with the CAN bus. If you disrupt traffic on the bus you may have issues with the ABS, transmission, steering angle sensor and engine which need to be in constant communication or stuff won't work right. It's best to use the K-Line (ISO 9141-2) signals at the OBDII connector. The instrument cluster acts as a gateway to the CAN bus. It will take your requests for information and if properly formatted will send it along on the appropriate bus. If your program goes crazy and transmits garbage the cluster will ignore it and not forward it to the CAN bus.
scottjoh is offline   Reply With Quote
Old 01-18-2011, 07:11 PM   #18
SweTurbo
Big Pimpin'
My Ride: 323i -98
Hacked(spliced) my way into the CAN today and everything worked out perfect.
I located connector x6004 on the DME (the 2nd one on the left, has a "4" marking on the dme when plug is removed)
And then i located pins 36 and 37, coming out of these are a pair of twisted yellow wires with red and brown stripes(just like scottjoh said)
Plugged in there and my can reader lit up like it should.
Thank you scottjoh and thank you spaghetticoder
Old 01-18-2011, 09:12 PM   #19
zbi701
My Ride: E46 318i
Lets see the result...
Old 01-19-2011, 02:54 AM   #20
okeydokey
My Ride: 2000 328ci TopazBlau
so your reading data from the can bus, or the kbus?
///BMW 328CI 5 speed
okeydokey is offline   Reply With Quote
