Sponsored by The Tire Rack
Old 01-18-2010, 05:13 PM   #1
vtechthis
My Ride: 02' 330CI
Exclamation 330Ci wheel fitment w/ eibach prokit
I just picked up a set of wheels 18x8"--18x9" both ET38. Im going to be putting them on my 02' 330Ci sport package with eibach prokit springs. Anyone running a similiar setup that can suggest a good tire size to run with these wheels safely. Im also wondering if fender rolling is going to be necessary. I will most likely be installing 10mm spacers up front to bring wheels flush with fender. Thanks in advance!!
vtechthis is offline   Reply With Quote
Old 01-18-2010, 05:47 PM   #2
tiloulou330i
My Ride: 02 330i zsp
Send a message via AIM to tiloulou330i Send a message via MSN to tiloulou330i Send a message via Yahoo to tiloulou330i
With a 38mm offset,the wheel will be flushed if not sticking out to the fender.A 10mm spacer will be too much.You might need to stretch the tires to avoid shaving the fenders.I have eibach prokit on my car right now and i have a two-finger gap front and rear.
Filbert
Originally Posted by nawmean?
I know I sound naive, but some of the advice I've taken from this board has helped my life quite a bit
tiloulou330i is offline   Reply With Quote
Old 01-18-2010, 05:56 PM   #3
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
With your setup, 235/265 would work perfectly fine.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 01-18-2010, 08:04 PM   #4
vtechthis
My Ride: 02' 330CI
Thanks for the input! What aspect ratio should I run with 255 or 265 rears? 35/40?
Old 01-19-2010, 03:40 AM   #5
VMRWheels
VMRWheels's Avatar
Both will be 35 series.
-Charles@VMRWhels
Old 01-20-2010, 02:02 AM   #6
Julius@WSTO
Past Site Sponsor
235/35-18 front and 265/35-18 with your wheels will work perfectly. It'd be like running 9.5 et44 or so..
Julius@WSTO is offline   Reply With Quote
Old 01-20-2010, 03:41 PM   #7
VMRWheels
VMRWheels's Avatar
Originally Posted by Julius@WSTO View Post
235/35-18 front and 265/35-18 with your wheels will work perfectly..
It should be a 235/40/18 front.
-Charles@VMRWheels
Old 01-20-2010, 05:10 PM   #8
vtechthis
My Ride: 02' 330CI
Thanks for the help! I think I may play it safe and only run a 255/35/18 rear tire to prevent the risk of rubbing. Im hoping the front wheels dont stick out past the fender!
Old 01-20-2010, 05:58 PM   #9
VMRWheels
VMRWheels's Avatar
18x8.0 +38 with a 235 will not sit outside the fender. You'll be fine.
-Charles@VMRWheels
Old 01-20-2010, 06:03 PM   #10
Julius@WSTO
Past Site Sponsor
-Charles@VMRWheels
sorry... you are right 235/40-18 fronts.
Although I like how the 225/40-18's work with most tire brands.
Old 01-21-2010, 11:08 AM   #11
hummer
My Ride: 2001 330CI
My 235/45 on 17x8x35 offset don't stick out or rub.
Old 01-21-2010, 01:07 PM   #12
VMRWheels
VMRWheels's Avatar
OP can even throw on about a 10mm spacer up front and he will be fine.
-Charles@VMRWheels
fender, fitment, rolling, tires, wheels
