Sponsored by The Tire Rack
Old 01-18-2010, 09:41 PM   #1
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
18" tires and weight comparison + special ending
I'm in the market for a set of 18" tires (235/40R18 and 265/35R18s). I just need a decent performing, low cost set of summer tires. So I've narrowed it down to Sumitomo HTR ZIII and General Exclaim UHPs.
Sumi's weigh 24/27 lbs and the UHPs weigh 21/24 lbs. The Direzza Star Specs are 26/28. I would think that 3 lbs per axle would make a big difference in MPG.
Now, what would be considered a light tire for a 265/35R18? About 25 lbs?
The special ending is my rant about the worst tires ever.
need to replace my Goodyear Eagle GT A/S since they totally suck. Between 3 bubbled sidewalls (read: 3 new tires) and 2 that are leaking around the bead (tire issue, not a wheel issue since other tires don't leak), I'm tired of these tires. It wouldn't be so bad if these didn't handle like I'm driving on roads greased with crisco.
Goodyear Eagle GT A/S + CF sidewall = worst tire ever.
/rant...I hope you weren't expecting a NWS pic or something.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 01-19-2010, 11:20 AM   #2
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
Forget tire weight in this case...the differences in grip levels and handling between the HTRZ3 and Exclaim UHP will *far* outweigh (no pun intended) differences in tire weight. The HTRZ3 has faster steering response and more dry grip/cornering, while the Exclaim UHP has a softer ride and longer wear.
Tires
http://www.tirerack.com/a.jsp?a=BN4&...ires/index.jsp
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 01-19-2010, 05:18 PM   #3
bigjae1976
bigjae1976's Avatar
Tires
You read my mind. This would have been my next question. It sounds like you're a tire salesman or something.
Old 01-19-2010, 05:24 PM   #4
TxZHP04
My Ride: ESS TS2+ ZHP
Old 01-19-2010, 05:31 PM   #5
E46 S54B32
My Ride: 323ci
Originally Posted by TxZHP04 View Post
+1 i think i might pick up a pair of the UHP
-oem m3 front -oem m3 hood -oem m3 sideskirts-conforti intake -h&r race springs -TR Motorsport C2's -smoked corners/sidemarkers -smoked LED tails-CF CSL trunk-Black roof vinyl
E46 S54B32 is offline   Reply With Quote
Old 01-19-2010, 05:44 PM   #6
Riverbmr3
My Ride: MB E350 & BMW 325i
he is from tirerack, check out their website.
Riverbmr3 is offline   Reply With Quote
Old 01-19-2010, 05:49 PM   #7
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
I hope there was sarcasm intended with this
Old 01-20-2010, 05:23 AM   #8
bigjae1976
bigjae1976's Avatar
Thanks for the tip. Do you have a link?
Old 02-15-2010, 06:50 PM   #9
pablo e46
My Ride: 03 M3 & 03 330Ci
Actually OP has a good topic started here. I just weighed my 265/35/18's and they are 27lbs. I am slightly shocked as I was expecting about 22lbs based on something I read. Do we have a tire weight database that I havent found yet? I wont mention the cheap arse brand I'm talking about
pablo e46 is offline   Reply With Quote
Old 02-16-2010, 01:04 PM   #10
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
I personally have driven on the track with Z1SS's and they have been doing great for me. The best bang for the buck street/track tire that does not get greasy after a few outings.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 02-16-2010, 04:25 PM   #11
BartenderPlease
My Ride: '03 540i/6 M-Sport
given his join date and the username he responded to, I think so bro
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Trim | JL Audio | V1
BartenderPlease is offline   Reply With Quote
