Thread Tools Search this Thread Rating: Thread Rating: 22 votes, 5.00 average. Display Modes
Old 06-26-2010, 01:05 PM   #21
DSeyf
My Ride: b6s4
So here is how I wired it up..
Taped into the purple/white telephone switched 12v and the brown ground (however, I had two brown cables in the bundle...)
Connectors to the wiretaps.
From the connectors it goes to the iPhone car charger which I dissembled.
Solder to the connects where the side prongs and front spring loaded knob is.
Then cut the back cord that would originally go to the iPod charging and solder on a new cable (which I found lying around so gauge is unknown). I know my solder sucks, I'm fixing these spots right now which may be the problem.
Then placed a connector on that wire to easily disconnect it when taking my interior apart, as well as the other connector on the USB Hub end. (The white and Green wires are data)
Then the final
If you see anything that is off or should be different please let me know. Thanks
DSeyf is offline   Reply With Quote
Old 06-27-2010, 04:52 PM   #22
mvrk10256
My Ride: E30 325i
sorry i am a little confused by your pictures. the white wire is what exactly? also i would suggest trying the other ground wire if you are having electric issues. I hope you are not trying to hardwire your ipod? you just need to run the +12V and ground to the chargers connections ( +12v is at the "tip" and ground is at the side if i remember correctly") then plug in the ipod usb cable into the charger.
Old 06-27-2010, 04:56 PM   #23
mvrk10256
My Ride: E30 325i
after rereading the last few posts I just want to say a few things
1. antenna modulators are super sensative and in general are a bad idea. the only way would be to appropriatly shield the power wires. you can try aluminum foil but in reality you need real metal shielding which is more trouble than its worth.
2. I suggest getting a regular 2 or 4 port charger like the one i had and taking it apart. make sure you check the positivie and negative poles and solder them directly. you should be able to run it to the cigarette lighter. it is hard to give advice on the internet w/o physically looking at it, but this is the best i can come up with so far.
Old 07-01-2010, 02:44 AM   #24
sgplayer69
My Ride: 2003 CB M3 Coupe
so does the cig lighter still work when the usb is installed? cuz im gonna need it
sgplayer69 is offline   Reply With Quote
Old 07-01-2010, 04:29 PM   #25
mvrk10256
My Ride: E30 325i
yup. it still works.
Old 07-18-2010, 11:51 PM   #26
Spee D
My Ride: '02 325ci
hows those kidneys holding up?
This is how we chill
Spee D is offline   Reply With Quote
Old 07-19-2010, 12:09 AM   #27
mvrk10256
My Ride: E30 325i
just great. better than the hood. one small chip from what i heard and saw as being one bigr rock.
Old 07-19-2010, 01:21 AM   #28
lowwlife
My Ride: '11 X5 35i 86' 560sl
good work man I did the same thing with my first set of kidneys
lowwlife is offline   Reply With Quote
Old 09-03-2010, 04:41 PM   #29
mvrk10256
My Ride: E30 325i
Old 01-31-2011, 02:00 PM   #30
Ivanhoe
My Ride: BMW 330 xi 2005
Very nice . This will be my next mod on the weekend.
Ivanhoe is offline   Reply With Quote
Old 05-06-2012, 09:10 PM   #31
Justa330xi
My Ride: 2002 M3 vert
I could not find plastic primer but I found 2 in 1 paint and primer for plastic that is the flat black. Im guessing this will still work? I just dont want it to look like ****.
Justa330xi is offline   Reply With Quote
Old 05-07-2012, 04:14 PM   #32
KSims1868
My Ride: 2001 BMW 325i
Why use this method (kidneys) over just cleaning and using Plasti-dip?
KSims1868 is offline   Reply With Quote
Old 05-07-2012, 04:16 PM   #33
mvrk10256
My Ride: E30 325i
Lol this thread is old as hell.
@Justa330xi - yes it will work fine
@Ksims - cause some of us are men and can handle spray paint without having to use plastidip.
charger, diy, matte black grills, usb, windshield wiper tank
