Old 12-16-2009, 06:31 PM   #1
RedTRex
My Ride: 05 330ci ZHP
Vanos bad or setup wrong - need help.
Hi All,
New to this forum, but not BMWs (my current garage has a 2008 135i and a 187 325ic with M50 swap and I have owned about 10 over the years.
Anyway, I have a 99 323i with a M52TU (dual Vanos), bought with a blown headgasket (overheat?), I had the head rebuilt and sourced a new shortblock since the headbolts kept pulling threads.
I took pictures during dis-assembly and when I reassembled the VANOS, I set the gears and all on the wear marks and per the pictures I used on teardown. Cams were set perfect, but when I rotated the crank through the cams moved on the VANOS stuff and I assumed once the engine ran and oil got up there it would sort itself out.
So, the engine runs, seems to idle just fine, air pump runs for a couple of minutes and then quites. in neutral engine seems to rev okay, but in gear it responds very very very slowly until about 4k rpm , then takes of like a banshee.
I am confident it has something to do with the cams advanced too much or not enough. However, I have no experience with VANOS so I do not know how to troubleshoot, or do I know if I even set it up correctly - although must be close as engine does run.
ohhhh - when running gives me a code of CAM posit sensor bank 1 bad, so I ordered and replaced Intake cam sensor - no change in performance though.
Well, sorry for being long winded but I thought more info would help you to help me.
Rick
RedTRex is offline   Reply With Quote
Old 12-17-2009, 09:13 PM   #2
mrshelley
My Ride: 2004 330i
If you don't have the Vanos tools to set the cam timing, you'll never get it right and the car will never run correct.
Old 12-17-2009, 10:56 PM   #3
RedTRex
Well that was helpful.
Old 12-18-2009, 12:05 AM   #4
mrshelley
My Ride: 2004 330i
Look here:
http://www.baumtools.com/pdf/bmw_cam-timing.pdf
Purchase #B1160K and #113240.
Then buy this shop manual:
http://www.bentleypublishers.com/bmw...ir-Manual.html
Old 01-01-2010, 07:42 PM   #5
smolck
My Ride: 2004 ZHP Sedan
nevermind
Check out my BMW Blog
http://smolckbmw.blogspot.com/
Check my Youtube channel for DIY's and fun stuff
http://www.youtube.com/user/flipfinish?feature=mhee
smolck is offline   Reply With Quote
Old 01-01-2010, 08:03 PM   #6
RedTRex
so I had some discussion with Rajaie after I discovered his site and bought a VANOS seal kit.
I also bought the tool set from eBay, it just came Wed (30 Dec) but I wasn't able to get to the car until today.
Anyway - I am a believer! You cannot set the VANOS up correctly without the Jigs (tools). That is a fact.
My intake cam was 2 teeth retarded. Never would have figured it out with the tool.
I will rebuild the VANOS in the and get the rest back together in the AM.
Sooooo.....Thanks ALL.
Old 01-02-2010, 03:08 AM   #7
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Look here:
So how much are these tools? I don't see a price on their site.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
bigjae1976 is online now   Reply With Quote
Old 01-02-2010, 06:42 AM   #8
RedTRex
Here is the same set I bought....it is nicely built.
http://cgi.ebay.com/ebaymotors/BMW-C...item5637ecabc5
Old 02-19-2010, 11:48 AM   #9
nikoloza
My Ride: 325i
After I saw this thraed I'm really confused with that vanos becouse I am going to
get that vanos kit from beisan and replace camshaft position sensors .
Do you still need this tool to
or change the cam sensors and vanos seals needs?
nikoloza is offline   Reply With Quote
Old 02-19-2010, 11:58 AM   #10
RedTRex
No - the "tools" are only needed if you mess with the chains/gears......
