Old 01-22-2010, 11:25 AM   #1
kapsig431
My Ride: 328i
How much coolant?
Can anyone tell me exactly how much coolant a 2000 328i should take? I need to flush my system and need to know how much to add. I wasn't able to find it on another post.
Thank you!
kapsig431 is offline   Reply With Quote
Old 01-22-2010, 11:28 AM   #2
Miko_10
My Ride: 330i 5 Spd
check your manual. it should have capacity specifications in there.
FS(PM me if interested, MID Atlantic Area, 22307 zip)
- 2 M68 fronts w/ winter tires, local pick up preferred,
- OEM Pre face Sedan Clears.
Miko_10 is offline   Reply With Quote
Old 01-22-2010, 11:29 AM   #3
mujjuman
My Ride: not an E46
i tink its 2 gallons or 3 gallons.... dont take my word for it though
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
Old 01-22-2010, 03:32 PM   #4
nathancarter
My Ride: 02 330i
Buy one gallon of undiluted coolant, and two gallons of distilled water. The exact amount for the refill varies, because you don't know exactly how much remains in your engine after you drain it. Total capacity is printed in your owner's manual, but you'll need slightly less than that because you don't get out every last drop when you drain it.
There's a metal drain plug on the passenger side of the block. Ideally you'll replace the crush washer under that drain plug (I didn't).
There's one blue plug on the bottom of the radiator.
If you have a manual transmission, there's a second blue drain plug on the bottom of the expansion tank. (for automatics, you instead have a transmission fluid cooler on the bottom of the expansion tank)
Pour in half the gallon of coolant, pour in half a gallon of water, then pour the remaining half-gallon of water into the coolant jug. Then pour from that jug until it's topped up properly. If you have too much, mark the jug with a Magic Marker "50% PRE-MIXED" and store it for future top-ups. If you have too little, top up with more distilled water.
DON'T OVER-FILL! Fill it so that the floating stick gauge reads halfway between "min" and "max."
http://www.bmw325i.net/maint_coolant_change.shtml
nathancarter is offline   Reply With Quote
coolant
