Old 01-22-2010, 04:49 PM   #1
evileyeray
My Ride: 1999 328i
Send a message via Yahoo to evileyeray
Transmission question !!
i have a 1999 328i sedan (e46)
now in the morning when its cold, i warm it up and leave, as im coming to a stop and the transmission is down shifting, it makes a "bang" at every down shift. When it gets to warm up (aprox 2 miles) it doesnt (bang) shift as hard.
any suggestions on what it might be? i have a feeling its my transmission but im hoping its not.....ya know what i mean!!
evileyeray is offline   Reply With Quote
Old 01-23-2010, 09:22 PM   #2
e46crooser
My Ride: 99 328 5spd
If the CEL is not on, then I would check to see if you have any transmission leaks. If you have leaks it would be logical that your low on fluid. How many miles on the car? If you have over 100k miles, I would have the transmission serviced. HTH Phil
e46crooser is offline   Reply With Quote
Old 01-24-2010, 12:16 AM   #3
evileyeray
My Ride: 1999 328i
I have 160k. I just had the trani fluid changed 6 mo ago. I did have an oil pan leak which I just had fixed. I will wait and see if anything changes
Old 01-26-2010, 03:24 AM   #4
Bimmerbaz
My Ride: E46 328i
Might want to check what type of trans is in there. Some of them had a problem with the software and oil type can make a difference.
Bimmerbaz is offline   Reply With Quote
Old 01-26-2010, 05:03 AM   #5
ASSAIL
My Ride: E46 328, Jza80 Supra
sounds like a valve body problem bud.
ASSAIL is offline   Reply With Quote
Old 01-29-2010, 02:15 PM   #6
evileyeray
My Ride: 1999 328i
thanks ASSAIL, i had a feeling it was gonna be that... no way around this !
Old 06-29-2010, 03:38 AM   #7
maxi
My Ride: BMW E46 328I, 1999
if not softwear, it's valve body.
http://forum.e46fanatics.com/signaturepics/sigpic64570_1.gif
maxi is offline   Reply With Quote
Old 06-29-2010, 04:29 AM   #8
evileyeray
My Ride: 1999 328i
Would you happen to know what it would cost me if it is the valve body??
