Old 01-23-2010, 08:47 PM   #1
ec133
My Ride: 33Ci Sport
Question 330ci Moves to cold, misfires during starting, runs lean
So I just moved a 2001 330ci sport from CA to MA, for it's first cold winter ever. Now, it is suddenly having lots of misfiring codes and running lean. What could the cause be? Spark plugs / cables / coils? Any tests I could run? hhhmmm...
OBD Codes:
p0300 misfire
p0301 mifire, cylinder 1
P1344 Misfire During Start Cylinder 2
P1346 Misfire During Start Cylinder 3
P1348 Misfire During Start Cylinder 4
P1350 Misfire During Start Cylinder 5
P1352 Misfire During Start Cylinder 6
P0171 Lean Bank 1
P0174 Lean Bank 2
It runs great at speed, but feels a little rough at idle... I love this car! I don't like failing inspection right after getting registered... DOH!
Any tips? -Ethan
ec133 is offline   Reply With Quote
Old 01-23-2010, 10:18 PM   #2
brian328i
My Ride: '00 328i M/T
Check the air intake boots, sometimes they rip and the unmeasured air that gets in past the MAF causes problems. Check the part that branches off to the ICV those creases usually rip.
Other then that, I would start with checking the ignition coils, the spark plug leds...
Seems really weird that your missing on all cylinders.
brian328i is offline   Reply With Quote
Old 01-24-2010, 04:01 AM   #3
Cowspoo
My Ride: 328Ci
Air intake boot cracks never caused me any misfires. Only a whistle @ 2k rpm. Replaced it, no noticeable difference.
Sometimes when it's cold my car will start then run rough, no codes are thrown. If I restart it's healthy again..
Welcome
spacebarissolazy
doesntfeelikebeingpressed
Cowspoo is offline   Reply With Quote
Old 01-24-2010, 10:55 AM   #4
ec133
My Ride: 33Ci Sport
Hmmm... I couldn't find any problems with the air intake boot, and MAF sensor is new and fine. Well, the boot was pretty grimey. I'm thinking of trying out the Seafoam spray. Maybe it will clear things out enough with the downstream valves and sensors (or make them worse):
http://forum.e46fanatics.com/showthr...ntake+boot+diy
My 2.5yo son is unhelpful with troubleshooting...
Any mo tips?
Great picture here from xi ter! My sparks plugs and coils also seem fine...
Old 01-24-2010, 11:51 AM   #5
CT330xi
My Ride: '04 330xi 6-spd
this is a shot in the dark, but have you gotten some mass gas? cali gas isnt blended for our weather...seeing as though you havent done anything to provoke it. Maybe get a fuel treatment like stabil or octane booster?
CT330xi is offline   Reply With Quote
Old 01-24-2010, 02:53 PM   #6
Craig330Ci
E46Fanatic
My Ride: 2006 330Ci vert
Could be a plugged fuel filter. Both sides are running lean. Has the filter ever been replaced? I see you have a 2001. BMW says lifetime, I say bull ****. Filters do get plugged up and do not last a lifetime. Just a thought. Good luck.
Craig330Ci is offline   Reply With Quote
Old 01-25-2010, 09:48 AM   #7
rshanley
My Ride: 2001 330i
This may be another one of my crackpot theories, but it seems a number of people hit the P134x code in the winter, particularly after the car sits. We have 10% ethanol fuel here in VA. With the change in temperature and the tank sitting still, it would not surprise me if some of that ethanol separates out. Ethanol has a higher specific gravity than gasoline, so it would sink to the bottom of the tank and be the first thing to burn on a cold start. I'm wondering if this is not a factor for some of the P134x codes people are getting. The ethanol would certainly not combust with the same characteristics as gasoline.
From my experience, my car threw a P1346 a few weeks back. My car runs rough longer as some function of how long it sits in my garage. If I drive it daily, or as the tank empties, the problem is less likely to happen. The irony is, I try to keep the tank full to reduce the amount of moisture that works its way into the tank over the winter. Perhaps that's not the best thing to do when your gas contains 10% ethanol.
It's just a theory... I'd say you may want to burn through this tank of gas and see if it continues, but the P030x codes would worry me. You don't want to damage your cats spilling too much unburnt fuel through them. Are you still getting misfires after driving the car around for a few minutes?
rshanley is offline   Reply With Quote
Old 01-25-2010, 09:02 PM   #8
ec133
My Ride: 33Ci Sport
So I just spoke with an 'expert' 15 years BMW experience mechanic guy, and when I mentioned that the car is also burning a bit of oil, when he suddenly had an Aha! He thinks this is the crank case vent valve, where moisture gets into the crank case, it can destroy a bellows... causing the lean burn and misfires. Supposedly gunk can buildup around the dip stick base, and that it as a bimmer-specific problem at the dealer shops. Does sound sound right? It is hard to write about, because I don't really understand it yet...
I still haven't tried the Seafoam, but think it is a good idea, if this is being caused by gunk built up near the intake or injectors... I also like the idea of doing all three Seafoam products at the same time, using the process on their web site...
Old 01-27-2010, 08:14 PM   #9
ec133
My Ride: 33Ci Sport
So... I heard about a 330i with nearly identical error read out, where it was the PCV valve, and not the crank case vent valve... hmm...
Old 01-28-2010, 05:05 AM   #10
Schnake
My Ride: 325ci
Good luck with finding your problem and certainly keep us informed....
Now please introduce us to the lovely lady sitting in the bimmer hehe!!
Schnake is offline   Reply With Quote
Old 01-28-2010, 05:11 AM   #11
azzy989
azzy989's Avatar
My Ride: 325i
Send a message via AIM to azzy989 Send a message via MSN to azzy989
correct me if i'm wrong... but aren't the CCV and PCV valve the same?
edit: just looked it up... it is listed as a PCV valve on tischer's site. so yes they are the same thing.
CCV valve- Crank Case Ventilation valve
PCV valve- Postive Crankcase Ventilation valve
oh and... to that picture
-Azlan *I want to be like CD330*
azzy989 is offline   Reply With Quote
Old 02-26-2010, 11:26 PM   #12
JFarley187
My Ride: 2000 323i
Ccv
I had basically the same issue, with the same codes, and after replacing the MAF, I discovered that I had a small vcuum leak in the CCV, which was causing all of the problems. Replaced the CCV and spark plugs and now everything runs great. Also I didn't have the crud under my oil cap or on my dipstick like everyone says to look for...heck I didn't even notice any oil consumption. I did have a lifter tick, which since fixing the CCV has quieted down to a whisper. I'd have a shop run a smoke or vacuum test...my bet CCV leak.
JFarley187 is offline   Reply With Quote
Old 02-27-2010, 02:46 AM   #13
Andy2108
My Ride: SpecE46 & E46 M3
Methinks its a computer/fuel problem. Computer is "used" to cali but its in mass now... so it has to aclimate?
You sure the movers didnt have a bit of "fun" with the car?
De gustibus non est disputandum.
Old 03-16-2010, 01:26 PM   #14
rshanley
My Ride: 2001 330i
What was the final verdict? I am sticking to my crackpot theory for my car (ethanol separating out due to sitting for long periods of time). Now that I am driving it regularly, I no longer get the code.
