///M3 Forum
Old 02-18-2010, 03:04 PM   #21
jbcritch
My Ride: 2005 Steel Blue 325i
See the post above you...it tells you what to do!
2001 330Cic AW/Sand- ret.
2003 330i SB/Grey - ret.
2005 545i 6spd BLK/Black - ret.
2005 325i SB/Grey - ret.
2007 550i Grey/Black
Mods: M5 mats, M5 spoiler, tint....for now.
jbcritch is offline   Reply With Quote
Old 02-18-2010, 04:45 PM   #22
dillard
My Ride: 2004 M3 Cabrio
Originally Posted by m3monkey View Post
ok,
i picked up on 04 vert w/ navi. been trying to find out if it has bluetooth. it doesnt have a talking man button on the center console, but has it on the steering wheel. I looked at the trunk and saw the box show on the pic. but it doesnt have any labels on it. So i dont even know what the passcode is if it has bluetooth.
Do I have bluetooth?
I think a simple test is to push and hold your steering wheel phone button. If you hear something about BMW assist or that BMW Assist hasn't been activated, then you got a TCU.
I have an '04 Vert. No BT. Had to buy a ULF module. I think the code is on the module but I'm not 100% positive.
Proud owner of '04 M3 Convertible:
dillard is offline   Reply With Quote
Old 02-18-2010, 05:37 PM   #23
VJ18
My Ride: 04 CB M3
is the pass key the last 4-5 of the vin?
VJ18 is offline   Reply With Quote
Old 03-06-2010, 08:20 PM   #24
Gordo GT
My Ride: Carless ATM
No, it is a 4 digit passcode.
Gordo GT is offline   Reply With Quote
Old 04-23-2010, 06:58 PM   #25
Icexx99
My Ride: E46 M THR33 V3RT
Send a message via AIM to Icexx99
I have an 04 vert i believe it has bluetooth, i opened the trunk and it had a motorola on the back of the box with the bluetooth emblem and it had the passkey on it as well, i push the r/t button and it shows on the navi no phone connected. i have tried numerous times to pair my phone but no luck, do i need the pairing button?
Icexx99 is offline   Reply With Quote
Old 04-25-2010, 07:57 PM   #26
tootall
My Ride: 2011 328iT 3 pedals
http://forum.e46fanatics.com/album.p...ictureid=11492
My module looks black, but I have the BT ULF manual in the car and a pass code, so I tried it one more time and had success! I was considering the dealer telling me it was about $1200 to put the BT in, but thanks to the previous owner, I now have it for free! This is wonderful news. Thank you E46fanantics! I can even get rid of the old cradle and put the two center cup holders back in.
BMWCCA member since 1990
Upgrade your 328 with a 330 intake: http://forum.e90fanatics.com/showthread.php?t=1095889
tootall is offline   Reply With Quote
Old 10-07-2012, 05:33 AM   #27
Davew
My Ride: 2004 330ci Msport
Talking Success with pin 1 and 17
Thanks to all posters on this thread, managed to pair iphone4 to 2004 330ci by jumping pins 1 and 17, along with ignition sequence. Ulf fitted, Bluetooth inbuilt, monitor, no nav, no pairing button.
Davew is offline   Reply With Quote
Old 11-07-2014, 05:30 PM   #28
Shinysideup
My Ride: '05 M3
Bluetooth Passkey locaton
I started looking for the passkey for my 2005 M3 and got to the bluetooth module - just like the picture posted by M3Monkey. I was hoping the sticker would be visible, it wasn't so I kept taking things apart.
I almost gave up too, The sticker is on the bottom of the module - you have to turn it over to see the sticker. The module is mounted on a shelf, so you can't see the sticker until you unmount it from the shelf and pull the module loose enough to spin it.
Found the passkey!
Shinysideup is offline   Reply With Quote
Old 07-29-2016, 09:43 AM   #29
Mriyazh
My Ride: Bmw e46 320d
Send a message via ICQ to Mriyazh
Bluetooth pairing button DIY
Hi. Guys. I hv a 2002 320d , which had a tcu unit and inbiuld phone.. I replaced it with a ulf unit.. Nw on my display when u select telephone it shows activate phone.. I don't hv a pair button on the console.. when I inspect the wire harness under the cup holder( the 18 pin connector )doesn't have pin 17...
How can I get the system to on the pairing mode... which wires are ones I hv connect to get to the pairing mode???
Can somebody help TIA
Mriyazh is offline   Reply With Quote
Old 08-01-2016, 11:52 AM   #30
dillard
Hmmm. I can try to take pick of the wire bundle but you should have same connectors I have.
Just a note... when you changed out the TCU for ULF, did you also install the BT antenna? Goes under ash tray back of center console
