Technique Tuning Turbo ZHP impressions - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-27-2010, 12:16 AM   #41
Fuerza
My Ride: XXX
Originally Posted by A55A55IN View Post
Time for a S54 kit .
Amen!
Fuerza is offline   Reply With Quote
Old 01-27-2010, 01:13 AM   #42
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
congrats!! time to hit the strip
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 01-27-2010, 02:19 AM   #43
BMW_E46er
My Ride: E46 Face-Life coupe
Any updates on the 325 kit?
2005 Sparkling Graphite E46CI
2004 Titanium Silver E53 X5
BMW_E46er is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-27-2010, 03:37 AM   #44
*James*
My Ride: hates being dirty.
James
*James* is offline   Reply With Quote
Old 02-04-2010, 09:41 PM   #45
NickG@TechniqueTuning
Past Site Sponsor
My Ride: E46 330ci Turbo
dyno results
McSpeed finally had a chance to dyno his car with the turbo at one of our dealers (ICS in Stamford, CT). Before we get to the numbers, some background on his car is in order.
McSpeed dyno'd his car right before the turbo installation. His results were:
Notice the power dip above 6000rpm. Obviously something wasn't right, but the problem couldn't really be pinpointed. When McSpeed sent in his DME to us for the turbo software reflash, I read out the diagnostics first. There was a lot of knock adaption stored, especially in the upper RPM range. This explained the stock dyno graph and its top-end power drop. The ECU was detecting knock (real or false, we didn't know yet) and was retarding the ignition timing accordingly. I informed him of the situation and we noted to keep it in mind going forward.
Once he had the kit installed and running (along with the electronic boost controller he chose), he headed over to ICS. They went over the install, and after installing a fresh set of spark plugs, the car pulled about 327rwhp (with 8.5psi and 93 octane). This is the first thumbnail pic below.
Notice the 'squiggly' results around 4000rpm. This is due to his stock clutch slipping. I've also printed the graphs vs. mph to help lessen the visual effect of the slipping clutch. The 2nd thumbnail is the power vs mph.
Now, while these results weren't too shabby, they were about 10-20rwhp lower than I expected. After remembering the knock adaption of his stock engine, I suggested he try some 100 octane fuel to see if the ECU was pulling timing. Thus, he filled up a tankful of 100 octane and drove the car, allowing the ECU to adapt to this fuel. Along with this, he also changed his DISA valve in the event it was the cause of knock. He then redyno'd and pulled ~340rwhp (again at 8.5psi, 3rd thumbnail pic). This was more inline to what we expected.
His final test, if he wishes to do so, is to redyno with 93 octane again. This will determine whether it was the DISA valve causing 'false knock', or whether his engine is truly knocking (higher CR from the factory maybe?) and needs a higher octane fuel to maximize the power.
ID:	347458   Click image for larger version
ID:	347459   Click image for larger version
Last edited by NickG@TechniqueTuning; 02-04-2010 at 09:43 PM. Reason: clarification of dyno pics
NickG@TechniqueTuning is offline   Reply With Quote
Old 02-04-2010, 11:20 PM   #46
werc1
My Ride: M3, RR, Sierra
wow, great numbers^
looks like a great kit
werc1 is offline   Reply With Quote
Old 02-04-2010, 11:31 PM   #47
McSpeed
My Ride: 2005 ZHP TT Stg 1
Originally Posted by werc1 View Post
wow, great numbers^
Thanks!
Definitely. Adaptation-wise I'm thinking it was some combination of dirty plugs, a wily DISA valve and questionable (winter?) gas from a certain station before each of the first two dynos. I could actually feel it pulling timing shortly after I filled up there the second time. Now I'm back to quality 93 and things are feeling allllllll-right.
In other news: I got my grandparents to go for a ride by saying I'd keep it under 70. Nailing it in 3rd gear had my grandpa laughing and grandma grabbing for the roof handle
McSpeed is offline   Reply With Quote
Old 02-04-2010, 11:32 PM   #48
BadBoostedBmwM3
My Ride: 323i & e36 Turbo M3
You can definitely tell it was knocking/pull timing in the upper range bc of the huge abrupt job. There is no doubt that you (nick G.) will set him up with a great tune!
What is the "DISA" valve??
If the motor is truly knocking.... do you think that will cause a problem in longevity?? Or the dme will be able to handle it forever?
This is my signature....
BadBoostedBmwM3 is offline   Reply With Quote
Old 02-05-2010, 12:16 AM   #49
McSpeed
The dealership calls it an idle control valve I think. Or idle adjuster valve. Besides whatever it does at idle, its flap also effectively alters manifold runner length at around 4K and 6K in order to generate resonance waves to produce a slight air charging effect for better a torque curve. Right?
Old 02-05-2010, 02:38 AM   #50
Len013091
My Ride: S52 E30, 330i
Send a message via AIM to Len013091
Right. The ZHP 4k power dip was caused by the DME thinking the engine was knocking when in reality the DISA valve was making too much noise. It seems like you had a dip at 4k as well but now have solve the problem.
Len013091 is offline   Reply With Quote
Old 02-05-2010, 11:41 AM   #51
Activ3
Great numbers! Nick, do you think it would do any well to play with the DISA maps and maybe change where it opens/closes? From the graph it seems like it might be beneficial to open it a little earlier.
Old 02-05-2010, 01:14 PM   #52
Len013091
Is there a way to lock it either open or closed? Seems like that could also be fairly beneficial for an F/I application.
Old 02-05-2010, 01:33 PM   #53
toastygt30r
My Ride: 2002 330 ci
Can you hear the spooling of the turbo just daily driving? I did not know if it is harder to hear because they are located on the undercarriage.
toastygt30r is offline   Reply With Quote
Old 02-05-2010, 02:50 PM   #54
Past Site Sponsor
We had already tried the effect of modifying the DISA's transition point during initial software development. We'd done runs with the DISA on all the time, and off all the time. In our setups, the factory transition point was the best.
Old 02-05-2010, 02:50 PM   #55
Past Site Sponsor
Yes, you can hear it.....it's music to my ears
Old 02-05-2010, 03:07 PM   #56
WALKD U
My Ride: Just Fast!
Nice Numbers Nick I wonder what # are Pushing with the Autos...
-TrippinBimmer
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 02-05-2010, 03:14 PM   #57
malina
My Ride: stock ZHP
330 ZHP Steptronic dyno results: 275 rwhp and 245 rw ft-lbs
malina is offline   Reply With Quote
Old 02-05-2010, 03:17 PM   #58
McSpeed
video!
http://forum.e46fanatics.com/showthr...0#post11281640
Old 02-25-2010, 08:13 PM   #59
mmurrayUSAF
My Ride: 2003 E46 330i
Glad you like the kit Brian.......happy boosting!
i looked at the website and there isnt a product list for 2003 e46 330i non zhp or at least i didnt see it any help?
mmurrayUSAF is offline   Reply With Quote
Old 02-25-2010, 09:39 PM   #60
generic 330i
My Ride: 2004 330i
Originally Posted by MachRc View Post
Visited the site and I noticed the Auto for the ZHP was $300 more than the manual. What is the difference between the two kits and since they are virtually the same what limits the hp down? Is it the ecu/dme flash?
generic 330i is offline   Reply With Quote
