///M3 Forum
Old 01-26-2010, 11:54 PM   #1
PimpNmyM3
My Ride: 2001 E46 M3 6spd
Hit a bump, made both headlights flicker...
So it did it again tonight, which makes it three times in the last week. Im guessing loose connection somewhere.
Anyone know where the light harness is located?
2001 E46 M3 6Spd Manaul
N/A BPU Software Sponsored by Active Autowerke
Streamline Drop-in + Elbow
Ebay Header
Agency Power Exhaust
PimpNmyM3 is offline   Reply With Quote
Old 01-27-2010, 03:11 PM   #2
PimpNmyM3
Anyone??
Ebay Header
Old 01-27-2010, 03:17 PM   #3
E46Moonlight
My Ride: 2000 323i
open your hood and look at the lights in the back of the house theres like this rubber boot that looks like a boob open that and make sure all is nice and tight in there
E46Moonlight is offline   Reply With Quote
Old 01-27-2010, 11:18 PM   #4
PimpNmyM3
Well, its a good idea, however, both lights flicker so I doubt the issue lies within each separate light, but thanks tho.
I dont have a way of confirming but it appears that my fogs go out in that second as well. I definitely know that both xenon lights go out because it basically goes pitch dark for a second.
I just hope it doesnt go out one time and stay off.
Ebay Header
Old 01-27-2010, 11:26 PM   #5
E46Moonlight
My Ride: 2000 323i
couldn't hurt to check any and all connections, cables, fuses just to make sure there not lose or burnt or anything. i had same situation happen to me on my corner lights i checked everything and it was fine! It turned out that it was the metal connector that makes contact with the bulb in the housing. It was dirty so it would cause a bad connection and would come on/off on bumps or not at all, cleaned it with a compress air can and scraped it off with a small flat head. try that
Old 01-28-2010, 12:39 PM   #6
PimpNmyM3
Okay cool, well i'll give it a try.. thanks
Ebay Header
Old 06-01-2010, 06:59 PM   #7
xtasyx
My Ride: 330Ci
same thing is happening to my car...i checked and everything is fine. have u figured out a resolution?
2001 330Ci Black Exterior/Black Interior
Power:
UUC Flywheel + M5 Clutch, eBay Headers, Gruppe M Intake, Magnaflow Cat-Back Exhaust 16533, MarkD Tune
Dyno'ed 210/209! :D
Looks:
30% Tint front + 20% Tint rear, Blacked out grills and reflectors, Shadowline Trim, Blacked out reflectors, 6K HIDs Low, 3K Fogs, DRL Delete
More to come...
xtasyx is offline   Reply With Quote
Old 06-02-2010, 04:28 PM   #8
PimpNmyM3
No I haven't but for some reason, it doesn't happen as often as it used to..
Ebay Header
