Sponsored by BAVSOUND
Old 01-27-2010, 12:08 AM   #1
DelzDawg
My Ride: BMW 325i
Subwoofer Installation
Hi Guys,
I have an aftermarket Sub & Amp. I would like to install it in my 2002 325i. I'm having trouble knowing what to connect where. I have a 4 line out converter. Where does this connect? There is no OEM Amplifier present it looks like it has been removed in the past by a previous owner. There is a blue wire and a red wire coming from the boot and has a small little connection on the end that says AMP. Are one of these wires the remote?
Thanks!
Daniel
DelzDawg is offline   Reply With Quote
Old 01-27-2010, 01:09 AM   #2
Orion329
My Ride: MKV GTI
the only factory-run remote turn on wire to the trunk from the stock head unit is a small white wire, and none of the stock wiring for the amplifier is labeled. you're in Australia, so it may be that the speakers are powered from an internal amplifier in the stock head unit, similar to many European e46s.
is there nothing behind the driver's side trunk carpeting? how are the current speakers powered? do you have the stock head unit?
some pictures of what you're working with would be good...
Orion329 is offline   Reply With Quote
Old 01-27-2010, 08:47 AM   #3
jbrewer
My Ride: 2000 323ci
here you go... just installed my system last weekend and posted everything I did
http://forum.e46fanatics.com/showpos...7&postcount=39
post up any questions and I'll try to answer them for ya.
I am trying to find an option for an AUX input without having to buy a 03+ headunit.
I would think I could tap into the disc player wires, but not sure... I am doing some research!
jbrewer is offline   Reply With Quote
Old 01-27-2010, 06:40 PM   #4
DelzDawg
My Ride: BMW 325i
Thanks guys. Here is a photo of what I'm looking at..
Old 01-28-2010, 03:01 AM   #5
Orion329
My Ride: MKV GTI
the amps (if in the trunk) are always on the left side. have you dug around over there?
from what i've read, the little wire that isn't connected to anything has something to do with shipping the cars overseas, it has nothing to do with audio components.
you might want to take a look at this thread for a great overview of how to replace all the speakers (though i realize that isn't what you're intending to do).
Old 01-28-2010, 08:02 AM   #6
DelzDawg
My Ride: BMW 325i
Are you sure the amp is on the left? Would that be typical for left hand drive cars? Mine is right and the battery is on the same side as the driver..
Old 01-28-2010, 08:17 AM   #7
sonaldinho89
My Ride: e90 325i 6MT
the amps are always on the left. however most Aus spec cars do not have an external amp. easiest thing to do is tap your 4 line out converter into your two rear speakers, and use the line out from that to feed into your subwoofer's amplifier.
sonaldinho89 is offline   Reply With Quote
Old 01-28-2010, 05:33 PM   #8
DelzDawg
My Ride: BMW 325i
Yeah that's what I was planning on doing. The only query I had was where to connect the remote...
Old 01-28-2010, 07:13 PM   #9
DelzDawg
My Ride: BMW 325i
Also, what colour would these rear speaker wires be?
Old 01-28-2010, 10:16 PM   #10
jbrewer
My Ride: 2000 323ci
*if* your amp is on the left side of the car unclip the wiring adapter that goes in it and use these wires:
Pin # 1 / Woofer Rear Left (-)Brown
Pin # 2 / Woofer Rear Left (+)Yellow
Pin # 24 / Woofer Rear Right (-)Brown
Pin # 25 / Woofer Rear Right (+)Blue
****DO NOT use the rear decklid 6x9's (i think that's what size they are).
the ones above are pre-amp'd, they will be 10x more powerful than the others wires.
my installation:
Old 01-28-2010, 10:47 PM   #11
wilawok
My Ride: MY04 E46 330ci Indiv
He is from the us and their drivers side is the left....... all are wired on the left...our passenger side
my installation:
you can tap into your rear speakers using the above colour coding.......if you dont have HK sound then you wont have to worry about the 6x9's as mentioned.........
As mentioned earlier their is a white wire behind the left boot trim (aus passenger side) this can be used as a trigger for your amp.......
BTW what state are you in ??
6 speed short shift man with Aluminium cube interior, MTech II bodykit
19 inch Hamann reps with Dunlop SP Sport Maxx,
Factory TV and Nav, upgraded audio with Alpine, Lanzar and Phoenix Gold Components
Individual Colour Tannin Green
wilawok is offline   Reply With Quote
Old 01-28-2010, 11:38 PM   #12
DelzDawg
My Ride: BMW 325i
Thanks pal very helpful. I'm in Adelaide!
Old 01-29-2010, 09:27 AM   #13
wilawok
not a problem...........Talk with cortinaD........he is in adelaide too....... and he is a wealth of information
Old 01-29-2010, 07:26 PM   #14
DelzDawg
My Ride: BMW 325i
So even though my battery, and all the wires are situated on the right hand side of the boot, the remote wire is on the left?
Old 01-29-2010, 07:34 PM   #15
M3_GTR
My Ride: hates driveways
yes it is
i done exatly what you done but ran my remote wire into my headunit
FOR SALE!
M3_GTR is offline   Reply With Quote
Old 01-29-2010, 08:13 PM   #16
DelzDawg
My Ride: BMW 325i
Thanks I will try have a look now. What I am also confused with is that there seem to be more than 2 brown wires... Which are which!!!
Old 01-30-2010, 12:35 AM   #17
DelzDawg
My Ride: BMW 325i
Forget what I said. I've found the speaker cables. But that's the least of my worries.. Cannot for the life of me get a green light on my amp. I have connected the + and Ground but it must be the wrond white wire that I am connecting to. There are 2 on the left hand side of the trunk and neither give a signal...?
Old 01-30-2010, 08:12 AM   #18
wilawok
its there dude........ remember to have your head unit turned on when checking for power from the white wire.
note that this wire runs to the antenna amplifier which is located behind the passenger c pillar cover........
inside the car above the back seat... has the light in it !!
( can also tap into it up there and run a wire down from there if you like )
Old 01-30-2010, 11:38 AM   #19
M3_GTR
behind ur hu on the bottom left or right, very last wire is white, splice and tap the remote wire into that
FOR SALE!
Old 01-30-2010, 09:33 PM   #20
jbrewer
My Ride: 2000 323ci
hookup your remote wire to pin10 on the factory amp plug!
like wilawok said... to test it turn the key and it should then be on
