Sponsored by BAVSOUND
Old 01-30-2010, 09:41 PM   #21
DelzDawg
My Ride: BMW 325i
So even though a stock amp doesn't exist?.. There will still be a white wire that can double as a remote? Like I said, I have found 2 and neither turn on the amp. This is a photo of the cluster of wires on the left of my boot..
And this one is the right hand side of my trunk. As you can see I have the Amp connected to the battery. And is that a suitable location for the ground?
DelzDawg is offline   Reply With Quote
Old 01-30-2010, 09:47 PM   #22
jbrewer
My Ride: 2000 323ci
I believe it's solid white, but not 100% sure.
Your best option would be to get a light tester and see which wires work.
First though you should search for a wire diagram/color codes for your model.
All of my wires were on the left side/drivers side (USA) of the trunk.
On both sides of the trunk you should see 2 factory grounds. I connected my amp to the one on the right side of the trunk.
As long as the metal is bare where you connect it you should be good.
jbrewer is offline   Reply With Quote
Old 01-30-2010, 10:02 PM   #23
sonaldinho89
My Ride: e90 325i 6MT
if you just want to TEST your amp, your could connect your remote wire directly to any 12V source, to make sure it turns on, but for the actual remote wire, it's a white wire coming off the back of the headunit. That's where i tapped into it, but as it travels along the side of the car to the trunk, you can tap into any where you can find it (some other posters have already mentioned good spots)
sonaldinho89 is offline   Reply With Quote
Old 01-31-2010, 02:48 AM   #24
DelzDawg
My Ride: BMW 325i
Done
We have lift-off. I ended up tapping in to the remote behind the head unit. Rad it under the carpet, backseats and in to the boot. Success! Thanks for all your help!
Old 02-03-2010, 10:27 PM   #25
DelzDawg
My Ride: BMW 325i
PROBLEM. The positive wire running from the Amp to Battery cam loose last night. I reconnected it to the amplifier but no green light. Any idea on why this would happen?
Old 02-03-2010, 11:56 PM   #26
B-Man
My Ride: 2002 330ci
Check your fuse.
B-Man is offline   Reply With Quote
Old 02-04-2010, 05:49 PM   #27
DelzDawg
My Ride: BMW 325i
Fuse is in tact
Old 02-04-2010, 08:36 PM   #28
B-Man
My Ride: 2002 330ci
Did you check the large fuse on your power wire (+12V) for your amp near your battery? Did you check any fuses on the amp itself? If these are ok, then check the remote wire connection and ground wire.
Old 01-24-2013, 03:15 AM   #29
E46RED92
My Ride: 2003 bmw 325i
Hello i jst got my first bmw but i am trying to put an aftermarket sub and amp and i been following this thead and i got it down but when i took the carpet out i found 2 other connection i beleive is the same one u guys were talking about and i was wondering if i could wire them up to that one or does it have to be to the one that goes on the amp??
E46RED92 is offline   Reply With Quote
Old 07-15-2013, 04:25 PM   #30
MATT14
My Ride: 2002 325i
2002 325i sub Install
Hey I am trying to connect my kenwood amp to the factory amp in my 2002 325i. I've read this thread multiple times but am still a little unclear on how to do it. Any help would be greatly appreciated.
Thanks,
Matt
MATT14 is offline   Reply With Quote
Old 02-28-2015, 03:13 PM   #31
lc3v1n3212
My Ride: BMW e46
Hello!
I am trying to connect my Hi Low RCA converter to my rear speakers, and the converter has 4 chors, a positive and negative for the left and right. In your tutorial you show that you use only 2 T-Tap connectors and connect them to the wires. Do you have pictures of the connection? Because I am trying to figure out exactly how to connect the Hi Low connectors to the Rear speakers. Thank you!
lc3v1n3212 is offline   Reply With Quote
