Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
Rating:
#281 | |
58mm of Bliss
#282 | |
Of course, the reason I need this on the 413 is that it doesn't do dual VANOS. The MS43 can just have its tuning revised to do exactly what I'm doing. |
#283 | |
Banned User
I suppose you would need to change cams to keep the intake open longer. I was a little off Makes since now hovering you only have vanos on the intake side. so you basically came up with your own dual vanos? Good info here! Last edited by xixixi; 09-22-2010 at 11:13 AM. |
#284 | |
I wish I would have dyno'd my car before I had the new exhaust built. My new exhaust is very similar to Aggie's, a flange, maybe a foot or so of piping, a merge to 3" piping, a 3" straight through muffler, (flowmaster?) then another flange before the final muffler, and 3" (reduces 2.5" internally, not sure why) Borla Pro XS. It's nice and quiet on the street, and I can easily unbolt the Borla to uncork it for competition time. Love it. Not sure if it actually made any power, but I dropped probably 40 lbs. Last edited by murph1379; 09-23-2010 at 03:37 PM. |
#285 |
this was a good read
http://www.superchevy.com/technical/...exh/index.html explains a lot of details related to building a custom exhaust to make maximum power.
-Maksim DIY: How to Tackle Electronics Projects Need Quality Brakes, Headers, Meyle Products? BimmerBrakes has it! |
#286 |
Excited to see a dyno after tuning!
I've been debating AA vs. Shark for a long time, but it seems you're going a 3rd path, which I'd like to know more about
![]() 323iT 5MT ZSP/ M54B30 Manifold Swap/ F1 Headers + Full ZHP Exhaust/ UUC SSK + DSSR/ CF ACS Mirrors/ M3 Steering Wheel + ZHP Shift Knob |
#287 |
Just for reference, and the discussions/ debates a couple pages ago between M52 and 54 exhausts, here is 323 vs ZHP Exhausts side by side:
#288 |
Does the 323 also have two different sized pipes immediately after the manifolds?
#289 |
great thread, just went on the maxbore site and seems they will not do bmw throttle bodys any more looks like it was a real pain for them, also i read some where you can put a 540i throttle body on our engine and its 80mm wide, wonder if it would work.
#290 |
Keep it clean
Guess that makes mine special
#291 |
I assume 540i is electronic? I wonder what other older BMW Tb's are mechanical that I could swap into my 323 with my M54B30 Intake Manifold?
#292 |
I'd Paypal anybody $1 if they could prove there was a pressure difference(ie. flow restriction) before and after the throttle body on their 330.
#293 |
I have stock dual 330i exhaust pipes from a 2001 330Ci with both resonators deleted welded to a Supersprint muffler. I've been reading this thread and it is very interesting. Am I right to conclude what I believe I have learned?
1. It seems like going from dual to single will mainly save weight. 2. Whilst Y pipe length/taper & positioning for a single determines whether you have more torque down below or up high. The next question is I need to replace the pipes on my car as the old ghetto welds are starting to show signs of wear and I am getting vibration inside the pipes. I was toying with the idea of going for a 3" single, but it seems like having a 3" single is great for up to 700hp and my car has nowhere close to 300hp. My friend at the shop was saying all I'd need is 2.75" single to maintain street clearance height from the pipe. Would going to a single pipe with stock headers/TB make any difference? If it saves a lot of weight then I guess that's probably one of the only things that help the vehicle in less mass rather than n/a bolt ons. If I were to choose a torque curve, I would want performance for the street which is low end torque. My car doesn't get timed at a track when I'm there so that's not an issue for me right now. I need to make a decision soon as my car is sounding more and more like an old rusted Oldsmobile day by day....LOL. If you guys have advice in what is best for this application, then it would be great. I'd still love to have a nice deep sound and I've just learned that welding on different length closed canisters to the end of the exhaust will help control drone. Seems like exhaust systems is quite an art to understand and I know I'm just learning the tip of it!
--Trevor--
Vancouver, BC ![]() |
#294 |
Keep it clean
I just have to say.... there are some AWESOME members on this forum. Thanks to the encouragement and opportunities from a select few, I'll have a few new updates early next year. Stay tuned!
#295 |
Hey Aggie, I love your thread it is motivation for me! Got a couple of questions for you.
1) Do you have a before and after dyno of the stett performance silicone intake boots? I know they're mainly for eliminating the torn rubber causing vaccum leaks, and I just replaced mine back in Jan, but it seems like they smooth out the flow a bit compared to the stock ones with the bellows in them. So I'm really tempted to get them for this reason, and if no one else has before and after dyno's then if I spring for these then I'll get an after since I already have a before. 2) Underdrive pulleys I know you're running evosports and they seem to offer the best performance, anywhere to get them besides evosports site? 3) Tune, I know you just have the sharkinjector, but I presume you might be getting a custom tune sometime in the future. So are you going to just go with AA or ESS, or do you have someone who can tune the MS43 software? I would personally love to get a custom dyno tune done, but no one around me seems to be able to work with any of the siemens ecm point blank period. Although my dyno guy and someone else from this forum who is big into running e36 race cars (wish I could remember his name on here otherwise I'd be talking in depth with him right now) are working on rigging up motech (or maybe its motos?) so that they can custom tune the siemens. Anyways if you have someone who can work with the siemens let me know because I am interested!!!!
330i - AA Tuned, Headers, UUC Stage I LW FW, e36 M3 Clutch, UUC SS Clutch line, BMW Performance Intake, Evo Sport Pulleys, BMW Performance Cross-Drilled Rotors, Hawk HPS, BW SS Brake Lines, BW Solid Guide Bushings, BMW Performance CF Strut Brace, H&R Sways, H&R Sport Springs, Bilstein Sport Shocks, Powerflex Bushings, LED Tails, Clear Sides/Turns, Black Grill, Mtech 2, CF SplittersM3 - Not enough room to list |
#296 |
I can jump in and answer your last question. the pople you are talking about is moates.net and they sell various chips for OBD1 cars. I plan on running their Ostrich 2.0 emulator on my e30. Basically using TunerPro - free software - it allows you to trace your various engine parameters that are controled by the ECU and change them - everything from RPM limits to AFR. Basically an Ostrich 2.0 and a AEM UEGO wideband and you can do all the tuning in the world in your garage. but only on an OBD1 car.
#297 |
My Ride: 04' 330ci & 99' 540i
Bump for anything new!
#298 |
Keep it clean
Not a lot going on performance-wise at the moment. Just installed an Innovate LC-1 to get the emissions monitors to pass. I'll get a gauge hooked up soon.
Just paid my deposit for the ATI damper. I'll be really happy to get that swapped out. My stock damper worries me. Installing new RSMs this week along with used M3 motor mounts and low mileage front shock mounts, as the bearings in mine are shot. I have a Dinan intake on the way for testing. After that, I have two major projects for 2011 up my sleeves. I'll probably need to replace my clutch, too.
#299 |
Let me know how the LC-1 goes. I'm running one as well but it has yet to cancel out all CELs...
'05 330xi - Koni, H&R, Rogue, Supersprint, UUC, Dinan, Apex
#300 |
Keep it clean
So far, so good. My only issue is that the monitor for the heaters hasn't passed. I'm guessing I need to change up the resistors I'm using.
| Rate This Thread | |
