Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 5.00 average.
Old 01-03-2011, 04:24 AM   #301
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
weren't able to get it to pass with the sims?
SL Blak Soldier is offline   Reply With Quote
Old 01-03-2011, 08:15 AM   #302
TrickTizzle
My Ride: 325i
Bought a new o2 sensor, and still cant get rid of the SES
Old 01-03-2011, 12:20 PM   #303
///Miller325ci
My Ride: 2005 Dinan-S2 325Ci
go here
http://www.dinancars.com/university/ and click on Dinan's E90-92 M3 Exhaust you may find it interesting...
///Miller325ci is offline   Reply With Quote
Old 01-04-2011, 10:19 AM   #304
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Passed the first year. Wasn't able to pass this year. They changed the laws in TX. Last year you could have 2 monitors "not ready". This year it's 1.
Old 01-05-2011, 12:36 AM   #305
F1004fun
My Ride: '02 330Ci
You still haven't gotten the monitors to check off yet? Did you get the LC-1 installed yet? What are your voltage curves?
A good catalytic converter voltage will look like this .650Volts from 8:1 AFR up to about 19.1AFR then go about .099 volts up to 22:1. This will give you the .650 volts that you need and give you then lean signal on decel. that the DME checks to make sure we haven't been screwing around. Also in the sub menu you want o set the delay to the 1/3 second delay, this sill slow it down a little also.
About once a year you might need to pull the wide band 02 sensor and do a free-air calibration. But my monitors check off in a matter of 20 miles and stay that way all year long. Good luck!
F1004fun is offline   Reply With Quote
Old 01-05-2011, 12:45 PM   #306
TxZHP04
My Ride: ESS TS2+ ZHP
Nah, his problem now is the monitor for the O2 heater circuit.
Old 01-05-2011, 07:20 PM   #307
aggieE46
Keep it clean
aggieE46's Avatar
I just checked it out. I had cleared it a week or two ago. Catalyst and O2s again... hmmmm.
Just changed my rear shock mounts again. Passenger's side was about 80% torn. Also checked the dampening on my Konis. One was a little stiffer. Adjusted. Car feels a bit better. The train-track test said all is good.
Old 01-08-2011, 02:01 AM   #308
F1004fun
My Ride: '02 330Ci
Ok.. So what are your voltage curves that you entered into the LC-1? What kind of resistors are you running? I found a pair of 50ohm 20Watt resistors, one for each of the two heater circuits.
Old 01-10-2011, 10:30 AM   #309
aggieE46
Keep it clean
aggieE46's Avatar
Checked this morning. Catalyst had passed. Heaters still no.
Honestly, I'm not sure what resistors are on there. I had purchased a pair from o2simulator.com a long time ago. Just used them.
Also, I made the mistake of putting them in the same little project box. They've warped it. Time to separate them and remount the boxes.
Old 01-17-2011, 12:45 AM   #310
F1004fun
My Ride: '02 330Ci
If you have an electronics supply house you can look for something close to 40 ohms resistance rated to about 25watts and that should work just fine for a heater circuit. I have used as high as 50h ohm and still had it check off the heater circuit. Glad to hear you got the monitors to check off.
Old 01-18-2011, 03:36 AM   #311
Andy2108
My Ride: SpecE46 & E46 M3
I just read the whole thread. Awesome project aggie! Keep up the good work, I have more to learn from you lol.
When doing my headers I relocated my O2 sensors to the "drugbin" and wired the O2 simulator to use the actual oem heater circut instead of a resistor. That seems to work ok. Maybe your resistors have just gone bad? They do that...
I'm going to go look into the HKS and Magnaflow exhausts
De gustibus non est disputandum.
Old 02-07-2011, 09:52 PM   #312
richyboycaldo
My Ride: Mx5 300zx 240z 330c
I have 330ci with ebay header, then X pipe, then two AR25 resonator and then a dual magnaflow muffler (quad exhaust setup), and I think I lost some low end torque, thinking of putting back my cats. my piping is 2.25, except for resonator and muffler are 2.5
richyboycaldo is offline   Reply With Quote
Old 02-07-2011, 10:18 PM   #313
Andy2108
X-Pipes are generally better for high end power and I think those AR25's may hurt low end torque a bit too, not to sure.
Old 02-13-2011, 12:32 PM   #314
secono330ci
My Ride: 04' 330ci/15' A3 TDI
I'm really itching to see what numbers the Dinan CAI will make.
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 02-13-2011, 01:24 PM   #315
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
I forgot I made that post in your sig. I'm still on track to achieve this....
Me too. Problem is, Brady hasn't got it yet. Somebody better get off their butt and ship that thing....
Old 02-13-2011, 07:10 PM   #316
TiAgTouring
My Ride: has a D-Pillar
Aggie I've got an extra Dinan CAI sitting around if you want to test it....
Just needs to be cleaned
Im waiting for spring to install
TiAgTouring is offline   Reply With Quote
Old 02-13-2011, 07:45 PM   #317
Andy2108
Old 02-13-2011, 10:59 PM   #318
rovert
My Ride: is an Individual
Send a message via ICQ to rovert Send a message via AIM to rovert Send a message via MSN to rovert Send a message via Yahoo to rovert
This could be of interest to you guys. My boys locally are dealers but the company is based in Cali. I know the owner as he came to Vancouver to do some tuning on some cars. Good guy!
http://oetuning.com/blog/?p=355
Here are the results from a recent dyno session of a 2002 E46 330i. The car had no mods and was running CA91 pump gas. ECU tune gains of +19Hp@4700rpm & +20Tq@3650rpm were seen to the wheels. Throttle response, drivability and all-round performance are improved.
--Trevor--
Vancouver, BC
rovert is online now   Reply With Quote
Old 02-13-2011, 11:31 PM   #319
Andy2108
Something is seriously wrong here. figuring a 15% drive train loss, that car should be making whp numbers in the 190's.
Old 02-14-2011, 12:19 AM   #320
rovert
That's what I thought too. But if they screwed up on environment correction but kept the same, then the difference in numbers should be the important part. If the car does make 200RWHP technically, then it still gained that difference. I'm going to look into it more. I'll give the owner a buzz.
--Trevor--
Vancouver, BC
Rate This Thread
