Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 5.00 average.
Old 03-17-2011, 12:19 PM   #341
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Well, initial torque was better until the exhaust went on. Then I lost a bit up to 3.5k. Worth top end, though.
We did one pull, but it was before my exhaust and it wasn't very legit. We just kinda hit it. If he was pulling on me, it wasn't by much. I think from a legit start he'd take me, though. We're going to try to get to the strip this summer.
Originally Posted by secono330ci View Post
It's pretty cool to see the difference in torque between the two. With the tune you should come really close to his numbers. Have you tried doing some highway pulls with him? I think you'd be suprised at the results...
Old 03-17-2011, 12:39 PM   #342
secono330ci
My Ride: 04' 330ci/15' A3 TDI
Originally Posted by aggieE46 View Post
Well, initial torque was better until the exhaust went on. Then I lost a bit up to 4.5k. Worth top end, though.
Yeah from a dead start he'd get the jump because of the LSD, but starting from 2nd or 3rd gear it would be very close.
Can you post up the exhaust dyno again? I'm looking back at the original one and the link's broken.
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 03-17-2011, 12:40 PM   #343
aggieE46
Keep it clean
aggieE46's Avatar
Actually, he's got a base model... no LSD or traction control. He's planning on swapping in a factory LSD from another model, though.
Here's the dyno again (Magnaflow vs. 3-inch)
Old 03-17-2011, 12:46 PM   #344
secono330ci
Oh, nvm then about the LSD then. Thanks for posting that up!
Old 03-17-2011, 02:03 PM   #345
aggieE46
Keep it clean
aggieE46's Avatar
No problem! Can't wait to see what you crank out.
BTW, maintenance tonight. New vacuum lines, new front O2s, valve cover gasket, oil cap, oil change, cleaning TB and IACV. Hoping to hit the dyno in the next 2 weeks.
Old 03-17-2011, 05:11 PM   #346
Rob1796
My Ride: 2006 350Z
Hey Rob,
No, not Jotech. I've been going out to LG Motorsports. Always easy to get in. Very consistent pulls. Here's a pull against my buddy's 2005 350z. Berk test pipes, TurboXS catback, Motordyne plenum spacer. This was his first pull and the only good pull he had that day. He kept losing power, even with 25-30 minutes between pulls. Not peak, but his low-mid power/torque was suffering. Still, He'd probably take me. He actually recently bought some HFCs, though. Drone was killing him.
Not bad. Not sure where I got JoTech from, must have been tired. I'd like to see a legit run, I'm thinking the Z would edge out but not by all that much. The impressive part is how well the 3er has responded to what you've done, and even after paying the BMW tax you'd still come under a bit cheaper than the Z, unless the Z strayed from name brand parts.
TBH, I saw your post in the for sale section and I started trying to get some numbers to work. To mny "big boy" things I need to take care of right now. So I'll just stick along for the ride and keep watching this thread, I'd like to see what you can figure out for headwork and if you can hit that 260 wheel goal NA.
Worst case scenario: if you can't hit that 260 all motor...would you be open to Nitrous if it came to that, or would you just go boost?
And on an unrelated note, there is going to be a dyno day out at AWD hosted by Imported Performance. 30 bucks for three pulls. Probably wont be consistant at all to LG, but if you don't got anything else going on.
2006 Alpine White M3
Rob1796 is offline   Reply With Quote
Old 03-17-2011, 05:32 PM   #347
xixixi
Banned User
My Ride: 01 330x-xi
Stock Z has no chance against aggies car imo. I've seen less epic N/A 330s pull stock Z's. Love to see a video though
Old 03-17-2011, 07:41 PM   #348
Rob1796
My Ride: 2006 350Z
It would really depend on the year and some other factors. Based on nothing but pure ricer numbers, it would be a close race, not one I would want to bet on. Despite being a Z owner myself, I would want Aggie's car to win. It would be a good run, that's for sure. The most impressive thing for me to see is how well the M54 responded to the modifications. Not that it hasn't been stated a million times, but Aggie's car would really wake up with a custom tune. The Shark injector looks like it is holding its own in these dynos, but canned tunes never really match up to a true custom tune.
Old 03-17-2011, 09:53 PM   #349
Iceman00
Banned User
My Ride: E90 6MT
I got WORKED by a modded 350Z. If I could do it over, I would have bought one over the Z3.
Old 03-17-2011, 10:11 PM   #350
aggieE46
Keep it clean
aggieE46's Avatar
They're great cars. Lots of available support. I tried to part out the bimmer and get into one a couple years ago.
Old 03-19-2011, 01:53 AM   #351
F1004fun
My Ride: '02 330Ci
I was going to tell you how I hooked up those 50ohm resistors until you said that. Those cars are my arch nemesis only because I have spanked a few and got spanked by a few. And they just sound so damn good, but screw em I'll take my 330 any day.
Those 50ohm resistors don't get that hot since the wattage going through them in low, I just wrapped them in heat shrink tubing and zip-tied them to the O2 sensor connectors.
F1004fun is offline   Reply With Quote
Old 03-19-2011, 12:19 PM   #352
Andy2108
My Ride: SpecE46 & E46 M3
just use your o2 sensors' heater circut... don't wire up resistors
look me up on youtube. I have a video of how to do it. I would but I'm on my phone
De gustibus non est disputandum.
Old 03-20-2011, 06:22 PM   #353
dpgrand
My Ride: 2005 330xi
I'm using resistors and I thermal-paste-epoxied a nice heatsink on them from digikey as well as mounted them on a piece of aluminum.
'05 330xi - Koni, H&R, Rogue, Supersprint, UUC, Dinan, Apex
dpgrand is offline   Reply With Quote
Old 03-20-2011, 06:59 PM   #354
aggieE46
Keep it clean
aggieE46's Avatar
that's how I had it, but I no longer have rears. Just one single wideband. I'm not hacking up the wiring to the LC-1.
Old 03-20-2011, 07:05 PM   #355
Andy2108
gotcha
edit: actually you could still use the oem O2 sensors instead of afttermakret resistors, I think.
Old 03-22-2011, 09:43 PM   #356
zmainiac
My Ride: 2000 323ci
Porting the heads will give you a big jump. My machine shop has picked up 25 to 40 hp on a 2.5. They have built a bunch of SCCA competition motors and done extensive flow bench testing. Don't know where you live but I would highly recommend them. They are just north of Philly. They charged me 800 for a complete head job with extensive porting. They made 225 whp on a 2.5 (with diff pistons and a standalone). I can't wait to get my car back together.
zmainiac is offline   Reply With Quote
Old 03-23-2011, 12:37 AM   #357
R0B
My Ride: zhp sedan
hmmm I need to discuss this further with you.
I've done a lot of work to my car recently, so far TMS pulleys, Bimmerbrakes headers, UUC flywheel, 3.46 diff, and AA tune. I was looking at the head as my next step
Merhaba
:Headers: :Header-back Magnaflow Exhuast: :UUC clutch/lightweight flywheel: :AA stage 1 supercharger: :VMR V710:
For sale: 3.46 differential, 18x8.0 style 135/18x8.5 style 135/ 19x8.5 varrstoen 1.1.2
R0B is offline   Reply With Quote
Old 03-23-2011, 02:13 AM   #358
zmainiac
My Ride: 2000 323ci
Yeah, they might even have a spare head to work on so that down time is kept short. You could probably sell your stock head and make money on the deal. Let me know when you are ready
Old 03-23-2011, 08:28 AM   #359
aggieE46
Keep it clean
aggieE46's Avatar
Thanks for the info. I have a head that'll be available to me early 2012. It's undergoing some R&D by another Fanatic
Old 03-23-2011, 09:04 AM   #360
B33MER
My Ride: 330i SMG M-Sport
Pei by any chance?
330i SMG M-Sport Paket II Euro Spec
Mods:
CF Roundels all around, Black grillz, 7000k Angel eyes,6300k HID fog lights, Hamman Lip reps, ACS roof spoiler reps, Alutech front and rear struts, BMC CDA with DIY heatshield, Pro RS braided brake line, ///M Billet Oil Cap, OEM ///M mats, ///M aluminium pedals,
B33MER is offline   Reply With Quote
Rate This Thread
