My search for more NA power (Dyno time) - Page 25 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 5.00 average.
Old 06-10-2011, 10:11 PM   #481
Iceman00
Banned User
My Ride: E90 6MT
So I log on to My350z.com today and see a member name that's very similar to someone on here..the avatar is very similar to one he used to have.
Old 06-10-2011, 11:30 PM   #482
mvrk10256
My Ride: E30 325i
care to share who?
Old 06-11-2011, 07:32 AM   #483
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
I've been on there since 2003 I'm also on an EVO forum, an RX-7 forum, several dsm forums, titantalk, thenewx.org, twinturbo.net and a ton of others, haha.
I have more posts on my350z.com than my friend with a 350. I generally troubleshoot for most of my friends.
Speaking of the Z, I plugged in my best run against his best run again. We both did 4th gear pulls. I plotted time and speed instead of hp and RPM. 10 seconds of pull, starting at 40mph showed me hitting about 115mph and him hitting about 108mph. The 350 is actually a pretty hefty car, too. About 3200 stock, so my car is pretty close to his in weight. Even though he has more peak hp and torque, it looked like I should take him.
Old 06-11-2011, 01:32 PM   #484
Iceman00
Banned User
My Ride: E90 6MT
I have different names on different different forums, a few now that I'm no longer active on. My350Z I'm KA24DE, I was Iceman00 on bimmerforums, Nissanclub, Freshalloy, G35driver, was a member of carspin.net (general car forum) was on clubrsx.com etc...Wow.
But I'd be interested in seeing the outcome if you ever go head to head with your buddy.
Old 06-12-2011, 08:46 PM   #485
aggieE46
Keep it clean
aggieE46's Avatar
Anxious to get my DME back in the morning. I'll try to burn through a couple hundred miles quickly. Then it's clean the filter, change the oil, and dyno!
Old 06-12-2011, 11:12 PM   #486
Iceman00
Banned User
My Ride: E90 6MT
Honestly man, I don't buy that "adaptations" stuff, but keep going on the path you're on to keep it consistent.
Old 06-13-2011, 11:51 AM   #487
aggieE46
Keep it clean
aggieE46's Avatar
She's back!!!
Only got to put 3 miles on her, I'm at work. On the plus side - she started, that's always good. Idle is raised to help out with my gearbox rattle. Throttle sensitivity is turned down a bit (also requested). Shark always seemed pretty artificial. This seems much more natural. More sensitive than stock, but not 10/10 like the Shark.
Downside is that my redline seems to be about 6800 although I requested 7k. Maybe the car is just so blisteringly fast that the tach couldn't keep up... lol. I'll put some miles on her and then give a review. All I will say is that it doesn't seem like I've lost anything. More of a review to come, and of course, a dyno ASAP.
Old 06-13-2011, 11:59 AM   #488
mvrk10256
My Ride: E30 325i
Why do you want redline at 6K is the falloff that bad afterwards? (too lazy to look back at graphs) but i am curios to see the new dyno.
Old 06-13-2011, 12:04 PM   #489
aggieE46
Keep it clean
aggieE46's Avatar
I made peak power around 6600rpm
Old 06-13-2011, 12:12 PM   #490
mvrk10256
My Ride: E30 325i
Then why do you want the rev limit at 6K you would never hit peak power?
Old 06-13-2011, 12:45 PM   #491
TxZHP04
My Ride: ESS TS2+ ZHP
Perhaps that was a typo (especially with the comment about the tach not keeping up)? The ATI damper which he should have soon was awful expensive to never rev past 6k.
Old 06-13-2011, 12:55 PM   #492
Andy2108
My Ride: SpecE46 & E46 M3
I bet he requested 7000
did you try it out in gears other than first? I have a 7k limit but for some reason that really only works in 3rd or 4th. 2nd is a bit better, but in 1st it would seem my limit is still about 6.5k.
maybe try some higher gears on the way home
De gustibus non est disputandum.
Old 06-13-2011, 01:06 PM   #493
aggieE46
Keep it clean
aggieE46's Avatar
Oops. Sorry, I meant 7k. Edited.
That was 2nd gear.
I'm going to go out in a bit and try to get a few miles on it.
Old 06-13-2011, 02:21 PM   #494
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
If you have the DSC turned off, or even in sport mode, I've found both the tach and speedo sometimes can lag behind what's actually going on. Also, OEM tachs aren't known for being that accurate. One of the reasons why I went with the Stack piece was because it's extremely fast to respond and show accurate RPM.
Old 06-13-2011, 02:43 PM   #495
McSpeed
My Ride: 2005 ZHP TT Stg 1
Weird - so in your experience the tach is more accurate with DSC on?
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 06-13-2011, 03:20 PM   #496
aggieE46
Keep it clean
aggieE46's Avatar
I hit 7k in 3rd gear a bit ago. It's fine. Probably just one of those things.
Car feels good. Idle is at 800, so it's knocked out some of the gearbox rattle. Very happy about that.
Old 06-13-2011, 05:21 PM   #497
xixixi
Banned User
My Ride: 01 330x-xi
Idle at 800? How much did it help the chatter? Mine is really bad with the ac on not so bad without? My car idles around 700+ish? Just a simple shark, and my rev limit is 7K. Many people that have seen/heard my car run can vouch for that. I was shifting at the same point as a stock m3? PLS get the AFR's without them the dyno is junk. Many have said their AFR's didn't change I'd like to see if yours did? Awesome thread awesome car!
Old 06-13-2011, 05:24 PM   #498
xixixi
Banned User
My Ride: 01 330x-xi
Double, I agree that adaption sh!t is marketing Also on (dig run) pull your abs module, see if anything changes with your tach. That is a fail safe way to know your DSC isn't kicking in. Even in "off" mode.
Old 06-13-2011, 07:20 PM   #499
Rob43
My Ride: 03 331Ci 5spd R1200R
As far as I'm concerned, adaptations are real. When I first installed my shark it was on the dyno, once installed the motor stumbled on its first pull & died. The second pull/try was better but still real rough. I then stopped the session and drove off. After a few days it went back on the dyno & ran perfectly. So for me adaptations are real, the ECU needs a little time to re-adjust.
SUMMIT POINT WV 1:24:229 SCCA
Old 06-14-2011, 10:01 AM   #500
DanFromTucson
My Ride: 2004 330ci ZHP
Do I need to disconnect the battery before taking out the DME? I found some instructions on AA's web site and they didn't mention disconnecting the battery.
EDIT: Sorry to threadjack. I meant to post this in the group buy thread for AA Software, but I forgot where I was. :-)
DanFromTucson is offline   Reply With Quote
Rate This Thread
