Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 5.00 average.
Old 07-27-2010, 11:33 AM   #41
McSpeed
My Ride: 2005 ZHP TT Stg 1
Oh...it flattens things out alright, just not in a good way.
Disa=resonance flap
Iacv=idle air control valve
*sent from my iTool
I didn't mean it as a fix - just an experiment - but I DID think they were the same thing . This Bentley diagram helps demystify:
(btw - is the theory that the DISA flap action triggers knock sensors resulting in the dip?)
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 07-27-2010, 12:35 PM   #42
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
I've unplugged the DISA on the dyno, and lost power under the switch-over point.
The knock sensor filters are centered on resonances above 5khz....I doubt the DISA has any influence on them.
Old 07-27-2010, 01:19 PM   #43
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
I'm really excited to see what the next few additions do. Thanks for the comments. Keep them going.
Old 07-27-2010, 05:16 PM   #44
aggieE46
Keep it clean
aggieE46's Avatar
Bad post.
Old 07-27-2010, 05:37 PM   #45
xixixi
Banned User
My Ride: 01 330x-xi
you may have covered this before but are you running shark or aa? i'm sorry if you have mentioned it I'm going to dyno my car once i get the awd system off i might even do a test run with the transfer case and no front drive shafts. to see the difference if there is any either way good numbers!
Old 07-28-2010, 09:22 AM   #46
aggieE46
Keep it clean
aggieE46's Avatar
Sharked.
Old 07-28-2010, 11:40 AM   #47
Michel
My Ride: 330ci
Here's a link to my dyno results; I'm running AA software btw, but also running magnaflow cats... you can still see a small dip at 4200rpm
Michel is offline   Reply With Quote
Old 07-30-2010, 12:58 PM   #48
mvrk10256
My Ride: E30 325i
great thread. I need to get rid of my CEL, and get an intake kinda like yours to replace my K&N drop in, and then gonna hit the dyno. you primarily use LG? anyone else in the area good place to go?
Old 07-30-2010, 01:46 PM   #49
aggieE46
Keep it clean
aggieE46's Avatar
Dunno. The main reason I'm using LG is for consistency.
Old 07-30-2010, 02:41 PM   #50
McSpeed
nice. was that dip bigger before?
Old 08-06-2010, 02:30 PM   #51
aggieE46
Keep it clean
aggieE46's Avatar
TB is at the shop to be bored.
Old 08-06-2010, 02:44 PM   #52
aggieE46
Keep it clean
aggieE46's Avatar
Quick update. Ground Control dyno brackets came in. Nothing fancy. They were bare when I got them, so I hit them with a little paint. They bolt on where the bottom of the shock bolts. $50 shipped. Not too bad for an easy mounting point.
Old 08-06-2010, 03:20 PM   #53
mvrk10256
My Ride: E30 325i
So if one does not have these things what are the appropriate dyno mount locations?
Old 08-06-2010, 03:39 PM   #54
aggieE46
Keep it clean
aggieE46's Avatar
I asked one well known member of the forum. He suggested running straps around your entire subframe assembly, and then strapping to those straps.
Old 08-06-2010, 03:44 PM   #55
mvrk10256
My Ride: E30 325i
is that how you did it in the past?
Old 08-06-2010, 03:56 PM   #56
aggieE46
Keep it clean
aggieE46's Avatar
No. Unfortunately, I think the operator hooked it up to the LCAs. We tried to avoid it last time and ended up pulling the shock off. (He attached to the bottom of the shock)
Old 08-06-2010, 06:36 PM   #57
mvrk10256
My Ride: E30 325i
Where did you order these from? i went to the GC website and found nothing...
Old 08-06-2010, 08:07 PM   #58
aggieE46
Keep it clean
aggieE46's Avatar
They weren't on the website. I had to call and order them.
Old 08-06-2010, 11:57 PM   #59
AndrewBall
My Ride: 2000 BMW 323iT
Send a message via AIM to AndrewBall
$50!!!!!! are you kidding me.
Christ, thats a lot for two pieces of metal with some holes drill in them. i think ill be making my own. been meaning to make some tie down points on my e46. I dont know why bmw got rid of the ones they had on the e30's
AndrewBall is offline   Reply With Quote
Old 08-07-2010, 09:24 AM   #60
aggieE46
Keep it clean
aggieE46's Avatar
Well, that's with 2 sets of shipping, too. He told me $20 plus shipping. It went from the guys that made them to GC, and then from GC to me.
Rate This Thread
