Thread Tools Search this Thread Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Old 02-11-2010, 07:45 PM   #41
haurelio
My Ride: 2001 bmw 325i
i meant the Headlight frame, like in the 1st picture.. what year was that frame from and what year was your headlight (2000)? i have a2001 halogen headlight but would like to retrofit with the xenon frame like you did.
Old 02-11-2010, 07:51 PM   #42
snitzl3
My Ride: e60 LCI
Send a message via AIM to snitzl3
Originally Posted by haurelio View Post
i meant the Headlight frame, like in the 1st picture.. what year was that frame from and what year was your headlight (2000)? i have 2001 halogen headlight but would like to retrofit the xenon frame..
oh ok i see what your sayin, im not sure when they started using the AL projectors. I know the frames for the zkw projectors have four mounting spots as opposed to 3 like i have. But as far as putting them into the halogen headlights, i know the mounting system is different. I have 2000 halogen housings as well but the frames wouldn't work in them because they use a totally different mechanism for adjusting them up down left right. The p46s however use the exact same mounting system/adjustment mechanism as the oem xenon frames
this picture shows (circled) the two mounting pieces that are on the xenon frames and on the p46. Halogen housings use some kind of ball joint that screws into the adjusters, its totally different.
snitzl3 is offline   Reply With Quote
Old 02-12-2010, 07:28 PM   #43
snitzl3
My Ride: e60 LCI
Phase 2: it's time for the next step in my retrofit project...wiring up the bi-xenon shutter!! Got all the parts: relay, relay wiring harness, in line fuse holder, oem plugs that plug into bi-xenon plug, oem wire for bi-xenon plug. As soon as I get my ride back from no reverse tranny rebuild I'll wire everything up. Stay tunned for more photos and bi-xenon shutter video.
Old 02-12-2010, 07:55 PM   #44
ferrarix99
ferrarix99's Avatar
My Ride: 87 325e - 05 M3 Vert
Originally Posted by Mike@F1 AutohaŘs View Post
If you ever mess with your headlights again, you should go for some ZKW replica clear lenses. The cutoff will be even sharper
hell yea! or spend a weekend and do a TFX retrofit!
click for pics of the old ride...
-Nick the Greek-
euro.techniks
Bimmerworld Epic Tune | OEM Euro Headers | CSL Brakes | B&B TriFlo | aFe SuperStock | PSS10 | Varrstoen TE37 | V1 | ZKW Lens Swap | Orion Golds
Want your car coded? PM me.
ferrarix99 is offline   Reply With Quote
Old 02-14-2010, 10:44 PM   #45
snitzl3
My Ride: e60 LCI
wanted to but i wanted more of a solid mounting set up, instead of retrofiting my own mounting system and all that. But i will probably upgrade the lenses for sure..
Old 02-15-2010, 10:16 PM   #46
haurelio
does anybody know what projector frames can i use for 2001 e46 halogen headlight? the guy on ebay has 99-01 and 02-04, which one should i get?
Old 03-04-2010, 03:09 PM   #47
snitzl3
My Ride: e60 LCI
ok, well im finished with phase 2, wiring up the bi-xenon shutter. All i can say is the bi-xenon feature is badass. I followed sna77's diy that he posted up here and it works flawlessly. ONLY hiccup i ran into and haven't had time to fix is since the relay essentially removes the halogen high beams from the lighting circuit (when i turn on the headlights, it triggers the relay to switch the power to the solenoid and not the high beam bulbs) I get bulb out warnings if i use the bi-xenon shutters. If i turn the lights off and pull the high beam stalk for flash to pass the warnings go off (because the halogen bulbs are back in the circuit). Im thinking this problem can be easily fixed with a couple of caps tapped into the wiring BEFORE the relay. Ill try it out and post up if it works. Anyways on to the pics & video!
I recently got some angel eyes from mike over at F1 Autohaus, they look awesome. Check my other thread for more pics
http://forum.e46fanatics.com/showthread.php?t=744697
Ok so next up i did a video with my crappy point and shoot camera (my nikon d3000 doesn't shoot video ), and for some reason when i uploaded it to youtube the quality is really bad. I took a couple snapshots of the original video to show the better quality. And of course in real life they are even better, but you can get the idea of how the shutter works from the vid.
shutter closed
shutter open
vid (NOTE: forgot to turn down the radio )
Overall, im extremely happy with the project. A humongous step up from p46s. Next is the last and final step, mtec 6k bulbs to match the angel eyes
Thanks for lookin questions and comments as always welcome.
hid, oem, p46, retrofit, xenon
