Sponsored by The Tire Rack
Old 01-30-2010, 12:30 AM   #1
eddiewolfgang
My Ride: 325i sharked cai
Question Need tires for 18X9.5 and 18X8
If you have any suggestions, let me know whats the best tire size for these rims 18X9.5 5-120 45 and 18X8 5-120 45. I live in NY so please know that there are plenty of pot holes here, i need something that is more comfy and safer.
eddiewolfgang is offline   Reply With Quote
Old 01-30-2010, 01:53 AM   #2
Penguin Koolaid
Banned
My Ride: Inline Six
225/40R18 and 255/35R18 You might want to add 10mm spacers to the fronts.
Penguin Koolaid is offline   Reply With Quote
Old 01-30-2010, 01:56 AM   #3
Snik
Snik's Avatar
My Ride: IR M3 Vert.
+1 spacers up front. 45 is hella tucked.
Do you ride a sportbike?
Old 01-30-2010, 02:06 AM   #4
eddiewolfgang
sorry guys i typed it wrong here the fronts are 18x80 5/120 +35 and the back are 18X9.5 5/120 +45 =D thank you
Old 01-30-2010, 02:10 AM   #5
Snik
Snik's Avatar
then you'll be fine, but id go 245, or 235 up front, and 255s in the back, less stagger, less understeer.
Old 01-30-2010, 02:19 AM   #6
eddiewolfgang
thnx =D i guess i go with those then
Old 01-30-2010, 02:46 PM   #7
ZZen330
My Ride: 2002 330Ci
I'd stick with 225 up front personally. That maintains the stock/OEM tire diameter.
ZZen330 is offline   Reply With Quote
Old 01-30-2010, 02:48 PM   #8
Snik
Snik's Avatar
doesnt matter, the speed sensor is in the driver rear.
id rather have the speedo be off a tad and have more neutral handling.
im running 245/45 and 255/35 right now, no issues, no rub, and it def rides better than 225/40 too.
Old 01-30-2010, 03:16 PM   #9
Penguin Koolaid
Banned
My Ride: Inline Six
I think your numbers are off with regards to sidewall ratios.
There is a 0.24% difference in overall diameter between 225/40 and 255/35. BMW uses that setup on staggered wheels for a reason.
235/40 and 245/35 has a 2.56% difference in overall diameter. The rears are going to read too 2.68% too fast.
Old 01-30-2010, 03:21 PM   #10
Snik
Snik's Avatar
i never said they wouldnt be off, i just said im not concerned about it and its not much.
a 2% change in the wheel diameter is gonna throw the speedo off by what, 1 maybe 2 mph. that doesnt bother me. its already optimistic from the factory anyway
Old 01-30-2010, 06:23 PM   #11
eddiewolfgang
Question
i called up this tire place and the guy told me, he said i need 225 because that's whats recommend, he was telling me that's whats on the books. He also tells me that 330 and 325 needs different sizes . Is it true ?
Old 01-30-2010, 06:42 PM   #12
Snik
Snik's Avatar
no, theyre the same chassis.
as koolaid said, its whats recommended, when BMW went to 18s on the ZHP they went that way, but it doesnt mean it wont fit.
ive seen 255/35s on track cars, and after running a taller 245/45 up front im confident i could fit 255/35s up front too.
ive had tire vendors tell me a 10" wide rear wont fit a non M also. so really what do those guys know?
oh just noticed you said you have a 8" front
id try to get 235s for your 8" front. 245 may look a bit fat.
235s should fit the 8" perfectly
Old 01-30-2010, 07:58 PM   #13
eddiewolfgang
thank you sinkwad. I really wish these people understood how bmw's work. It's very rare to find a place that knows almost everything about E46 and other bmw's.
Old 01-30-2010, 08:14 PM   #14
Snik
Snik's Avatar
i think if you had called tirerack youd have been better off, they may not tell you to go with a super aggressive setup, but they know their sh1t.
here is a 225/40 Michelin on a 8.5" wheel.
here is a 255/35 michelin on the same 8.5" rim
here is a 245/45 Bridgestone on the same wheel
and finally 255/35 bridgestones
if you want a lil stretch, then go 215, or 225, but with a 255 rear, understand the car will understeer more, you will notice this even on HWY ramps.
Yes your rim is 1/2" narrower, but as you can see, 20mm makes a big difference, this is why i say go 235 or 245s up front because when i did the difference was instant the 1st onramp i his, and i went from kumho 225/225 to michelin, 225/255 to bridgestone 225/255 then to 245.45/255, the 1st three setups felt the same, but the 245 made it neutral again. Plus its a lil more rim protection.
Old 01-31-2010, 02:41 AM   #15
eddiewolfgang
Hmm, so I think I'm going front 245 and rear 255, snikwad your a genius if these fit perfectly on the rims I'm getting. Your set looks sweet. 18"s or 19"s?
Also I gotta ask the tire shop people to see if the set 245/255 fits perfect without rubbing or anything. Thnx alot snikwad =D
Old 01-31-2010, 03:46 AM   #16
Snik
Snik's Avatar
thats a 254/45 on a 8.5" wide rim. your rims are 1/4" smaller, that 245 wont look square, it'll look jumbo jet like. i say go 235s man. if they still have a stretch, then go 245s next time, but id def try 235s 1st so you dont have sidewalls pass the wheel like an offroad tire.
im no genius either. but thanks.
id bet you wont rub with those offsets up front. again, my 18x8.5 pictured are ET38, so if you put a 10mm spacer up front on your 18x8, you'll have an effective offset of ET35, and that will look pretty much identical to mine with a 235/40 front wheel.
Old 01-31-2010, 04:29 PM   #17
ZZen330
My Ride: 2002 330Ci
snik - your 245/45/18 on the front is WAY to tall for the sidewall.
OEM fit for the front would be 225/40/18, though many do 235/40/18 which works ok. Rear OEM fit is 255/35/18 though some put 245/35/18 to avoid rubbing when slammed.
I don't think anyone would ever advise a 245/45/18 as it's going wider AND a higher sidewall %. If you want a 245 it shoud probably be a 245/35/18, but others may want to jump in as well.
Eddie - put either a 225/40/18 (or 235/40/18 if you want) on front with a 255/35/18 on back. Penguin had it right.
Old 01-31-2010, 05:11 PM   #18
Snik
Snik's Avatar
I know its taller, its visibly taller but honestly, it rides better and I got them at a killer price. So really, I don't care, the speedo is read from the driver side rear wheel anyway.
I never recommended a 245/45, I just said 245, I should have clarified, that I was talking about a 245/40 for him initially. HOWEVER, I have changed that recommendation since seeing that he has a 8" wide front. And I did say 235/255 combo
I know what the oem setup is, but again, I ran this setup and found that it understeered too much for my liking, which is why I'm encouraging him to run a wider front tire.
Old 01-31-2010, 06:46 PM   #19
Penguin Koolaid
Banned
My Ride: Inline Six
Why do people bother buying staggered wheels if they're going to complain about the understeer
There is a lot of bad advice in this thread.
Old 01-31-2010, 06:47 PM   #20
Snik
Snik's Avatar
i got a deal on them, thats how i ended up running staggered, and as a plus the back end fills out better with the wider rubber.
Youre welcome to correct where you see errors.
Im merely relating my experience, if you have input, please share, we're all here to learn, not just BS in OT.
18's, rims, tires
