Old 01-30-2010, 04:55 PM   #1
Brett LaCroix
My Ride: 2001 330CiC 5-speed
Question DIY for muffler bearing replacement?
My car has developed an exhaust system rattle and the shop says my muffler bearings are shot and need to be replaced.
I really don't have the $385 to have this done, so is there a DIY for this?
Also... my ride has been on the "mushy" side lately... shop says it's most likely due to stale tire air and recommends a purge and refill.
Do I really need OEM air for this?
I understand it is purified, static-free, and has tire conditioners added... but I wonder if I will be able to notice the difference? If it impoves my MPG by a mile or two, probably worth the $59. Right?
:) Brett
Brett LaCroix is offline   Reply With Quote
Old 01-30-2010, 05:00 PM   #2
SweTurbo
Banned User
My Ride: 323i -98
Ur joking right...... :eeek:
Old 01-30-2010, 05:01 PM   #3
XPLCTBMW
My Ride: is soldddd
Send a message via AIM to XPLCTBMW
XPLCTBMW is offline   Reply With Quote
Old 01-30-2010, 05:04 PM   #4
Richy_Boy
My Ride: Alpina B3S
lol stale air?
Alpina B3S - 3.4L, 305bhp, 267ftlb
K&N panel filter, SPAX Coilovers, M3 Sway Bar, RedStuff pads, Brembo Grooved/dimpled discs.
Richy_Boy is offline   Reply With Quote
Old 01-30-2010, 05:04 PM   #5
biggs325
My Ride: 2004 325ci
my car was slightly higher on one side the other day, i topped off my blinker fluid and it handles like a dream
biggs325 is offline   Reply With Quote
Old 01-30-2010, 05:17 PM   #6
slammin_330
My Ride: is no ZHP.
For that price I got stage 4 muffler bearings! They even threw some oil in the coolant to lube up the water pump for less friction!
The air in my tires is aged in charred oak barrels, to give it that aged, seasoned effect. It's pricey, but worth it IMO.
>: 2003 330i : 5sp : Slicktop : SSK : Intrax : UUC Sway Barbarians : Kamei eyelids : eBay headers :<
Non e46
>: 1985 535i : 1989 325i 'vert : 1995 M3 :<
slammin_330 is offline   Reply With Quote
Old 01-30-2010, 07:01 PM   #7
BodyMan
My Ride: 2002 325i
You can use most any air, just make sure you rotate the air every 3k-5k miles. I use seasonal air, for Spring,Summer,Fall, and Winter. It's engineered to cope with temp. changes from season to season.
BodyMan is offline   Reply With Quote
Old 01-30-2010, 07:03 PM   #8
firefirefire90
Banned
My Ride: suce ma bite
Send a message via AIM to firefirefire90
And I thought I got a good deal with my stage 2 bearings!
firefirefire90 is offline   Reply With Quote
Old 01-30-2010, 07:14 PM   #9
rkneeshaw
My Ride: 330i ZHP
gtfo.
2003 BMW 330i ZHP
BMW Performance Intake and SSK - Headers - Magnaflow - ESS Tuning
Turner Motorsports Pullies and Reinforcements - H&R Spacers - StopTech - And more...
rkneeshaw is offline   Reply With Quote
Old 01-30-2010, 08:47 PM   #10
dwebb99
My Ride: 330ci
While you're in there replacing those worn out muffler bearings, which we all know are prone to early failure, have your guys look at the sky hook. That SOB always causes problems, and hurts your gas mileage as well.
dwebb99 is offline   Reply With Quote
Old 01-30-2010, 09:10 PM   #11
sonaldinho89
My Ride: e46 323i (Anya) RIP
the BMW Performance air is ok, but i personally run whipped cream with a touch of cinnamon (for wet weather traction) in mine.
sonaldinho89 is offline   Reply With Quote
air, bearing, bearings, muffler
