Engine & Performance
Old 02-01-2010, 12:54 AM   #1
bmwstephen
My Ride: e46 325XI, e36 M3
FS: Dinan High Flow Intake (CA: Bay Area)
Restoring my car back to stock to finalize it for sale in 2 weeks so I'm selling my Dinan high flow airbox. It's compatible with any 325 series (i/xi/ci) for NON-SULEV engine. The airbox has 35k miles on it but I replaced the filter 4-5k miles ago.
Now to the bad:
-The area of the airbox where you bolt it down to the chassis is a bit damaged (due to a previous removal error). It doesn't affect the installation or performance in anyway.
-The end of the tube that connects to the brake duct (highlighted below) is missing this rubber piece because the brake duct was ripped off my bumper due to road debris. Replacement part is available at your local hardware store or Dinan.
-Depending on your brake duct (mtech bumper or OEM) you may need to shorten or lengthen the tube for it to connect. Unfortunately, I had it installed in an mtech brake duct so the tube is short. Should you need more length, a replacement tube would need to be purchase from your local hardware store or Dinan.
Asking for: $150 and the lower portion of your stock airbox (since the Dinan airbox reuses the lower portion of the stock airbox but drilled out for the brake duct tube, I'll need an original one to properly use the oem element)
The idea is to meet up upon payment and I'll do the swap. It should take less than 15 minutes.
Will also throw in this Dinan License plate frame!
More information here:
http://www.dinancars.com/store/produ...cat=404&page=1
bmwstephen is offline   Reply With Quote
Old 02-01-2010, 03:48 PM   #2
bmwstephen
bump
Old 02-02-2010, 12:06 AM   #3
carcus
My Ride: 2006 BMW M5
I will take the Dinan plate from you if you want to sell separate.
EDIT: Also, bump for a good intake. I have the same one on my car again.
2006 M5 E60, "Lord Vader" Last real NA M series
German Car Fanatic. Colorado ///M Flight member, BMW CCA member.
carcus is offline   Reply With Quote
Old 02-02-2010, 02:58 PM   #4
jbugg328
My Ride: BMW 328ci
how does this intake sound???
will it give you a sound at all.?? just wondering
Instagram : JrVincent7
jbugg328 is offline   Reply With Quote
Old 02-03-2010, 11:43 AM   #5
bmwstephen
Sounds no different thank stock. There will be no sound in completely sealed intakes since the air filter isn't exposed in the engine bay.
Old 02-03-2010, 06:48 PM   #6
LA330ci
My Ride: 01BMW330ci
do you want to sell the DINAN plate? I can pick up. located in Daly City. Let me know thanks
LA330ci is offline   Reply With Quote
Old 02-04-2010, 11:55 AM   #7
bmwstephen
sorry. I want to include the plate frame with the intake to sweeten the deal a bit for now.
morning bump!
Old 02-04-2010, 11:46 PM   #8
LA330ci
My Ride: 01BMW330ci
let me know if you decide to change your mind.
Old 02-05-2010, 09:52 PM   #9
carcus
LOL.....no cutting in line.
Old 02-05-2010, 10:14 PM   #10
bmwstephen
lol carcus gets dibs
Old 02-09-2010, 05:30 PM   #11
bmwstephen
BUMP lowered to $130
Old 02-09-2010, 07:25 PM   #12
carcus
LOL....you know you want to sell me that plate.
Old 02-16-2010, 12:37 PM   #13
bmwstephen
sale pending
Old 02-18-2010, 02:42 AM   #14
j suede
My Ride: 2004 330i zhp
if sale doesnt go through please pm. i am interested and local.
j suede is offline   Reply With Quote
Old 02-18-2010, 02:47 AM   #15
secono330ci
My Ride: 04' 330ci/15' A3 TDI
There definitely is a sound difference, trust me have someone drive the car while you're outside it. It sounds sick!
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 02-18-2010, 01:51 PM   #16
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
and for a fellow UC Davis fanatic
Drew@Swift Motorworks is offline   Reply With Quote
Old 02-20-2010, 07:30 PM   #17
moosem3
My Ride: 2002 m3
is the intake sold?
moosem3 is offline   Reply With Quote
Old 02-21-2010, 02:14 AM   #18
bmwstephen
sale is currently pending. Will let you know on tuesday.
regardless if it has been sold or not, on that day the car will be gone.
