Sponsored by The Tire Rack
Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Old 02-01-2010, 11:41 AM   #1
peleke4
My Ride: 2003 bmw 330ci
Nail in tire near sidewall (w/pix); repair or nonrepairable?
There are two nails punctured in the tire. One is closer to the sidewall as you can see in the pix. The shop refused to fix it due to "morality" issues.
If I were to get this repaired, what are the chances that this tire would blow out? Is this damage severe to the point that I shouldn't chance it? Thank you for any feedback!
ID:	346971   Click image for larger version
ID:	346972   Click image for larger version
ID:	346973   Click image for larger version
peleke4 is offline   Reply With Quote
Old 02-01-2010, 11:45 AM   #2
chasz17
My Ride: 2005 645Cic
Not repairable!!!
chasz17 is offline   Reply With Quote
Old 02-01-2010, 11:50 AM   #3
Zeekster64
My Ride: 2004 325i premium
Don't risk it. If a shop said no, then they said no to getting your money for a very good reason
Zeekster64 is offline   Reply With Quote
Old 02-01-2010, 11:54 AM   #4
zhp pilot
Falling from 14k ft.
zhp pilot's Avatar
My Ride: is totaled :(
Non-repairable. And kudos to them for not repairing it. I don't think you should be worried about a blow out but a patch job would not hold up due to the constant flexing the tire sees every time it comes in contact with the ground.
'04 Silbergrau Metallic ZHP 6MT
zhp pilot is offline   Reply With Quote
Old 02-01-2010, 01:22 PM   #5
BMW#1_323i
My Ride: Loves curves!
What about an interior patch...not a plug?
BMW#1_323i is offline   Reply With Quote
Old 02-01-2010, 01:29 PM   #6
///Flash
Banned
My Ride: a donkey
dude, that stuff is repairable. they are trying to make money off yiou
///Flash is offline   Reply With Quote
Old 02-01-2010, 01:31 PM   #7
n2Bimmer
My Ride: Loves Corners
mmm you might be able to repair that. Ive had it done once. Go to sears. 25 dollars to repair from the inside.
Old 02-01-2010, 01:35 PM   #8
TheRusski
My Ride: gone...
Last thing you wanna do is that tire blow on you going 75 on highway
TheRusski is offline   Reply With Quote
Old 02-01-2010, 01:35 PM   #9
SweTurbo
Big Pimpin'
My Ride: 323i -98
My dad has a tire shot and that would be a pretty simple drill + plug + tireepoxy, as for safety it's as good as it were before
Worst case scenario you could tube it.
Old 02-01-2010, 01:41 PM   #10
zhp pilot
zhp pilot's Avatar
That's what I'm talking about, an interior patch. I would never plug a tire on my car unless it was just to drive it to get a new tire.
I had a screw in about the same place as you. I tried and tried to get Discount Tire to repair it but no dice. And it wasn't because they were trying to make money as another member has stated above. My tires were insured under a road hazard warranty so the cost to replace would be coming out of their pocket. The reason I wanted it repaired in lieu of replacement is because my tire was on national backorder and they had no idea when it would be available. So the only options were to repair it or replace it with a different tire, which I didn't want to do.
Old 02-01-2010, 02:00 PM   #11
pbcoco
My Ride: 325i
Not sure where you took it but take that to All American Tire. They will repair it for free if possible. They did for me anyways, even tho I didn't purchase the tire from them.
I had a similar case and they actually called the head guy to see if it was repairable.
pbcoco is offline   Reply With Quote
Old 02-01-2010, 02:08 PM   #12
CRXnut
My Ride: 2004 325ci
I don't see a problem with doing patch from the inside in this case.
CRXnut is offline   Reply With Quote
Old 02-01-2010, 02:11 PM   #13
ferrarix99
ferrarix99's Avatar
My Ride: 87 325e - 05 M3 Vert
No patch! Plug and epoxy will work!
/end thread
click for pics of the old ride...
-Nick the Greek-
euro.techniks
Bimmerworld Epic Tune | OEM Euro Headers | CSL Brakes | B&B TriFlo | aFe SuperStock | PSS10 | Varrstoen TE37 | V1 | ZKW Lens Swap | Orion Golds
Want your car coded? PM me.
ferrarix99 is offline   Reply With Quote
Old 02-01-2010, 02:55 PM   #14
Kubica
My Ride: 2003 325xi
Definitely repairable.
Old 02-01-2010, 03:34 PM   #15
josephi
My Ride: '02 330i
One of those nails looks like it's pretty close to the sidewall. Could be why they didn't want to take a chance on repairing it, as any damage to the sidewall could potentially cause the tire to fail, resulting in possible injury to you and liability on their part.
josephi is offline   Reply With Quote
Old 02-01-2010, 03:38 PM   #16
peleke4
I was about to search high and low for a shop that'd be willing to repair it. But just to be safe, I decided to drop the funds and get a new tire. Thanks for the feedback. Hopefully this thread will come in handy to others in the future.
Old 02-01-2010, 04:09 PM   #17
farmdog
My Ride: Food Truck
Just repaired mine about 4 months ago...same place on the tire.
no issues as of right now
farmdog is offline   Reply With Quote
Old 02-01-2010, 04:18 PM   #18
chasz17
You CANNOT tube the tire AT ALL!!! Radial car tires cannot have a tube in them at anytime. And anyone that is saying that this tire can safely be fixed is simply wrong as it is too close to the sidewall.
Old 02-01-2010, 04:35 PM   #19
zhp pilot
zhp pilot's Avatar
Originally Posted by chasz17 View Post
you cannot tube the tire at all!!! Radial car tires cannot have a tube in them at anytime. And anyone that is saying that this tire can safely be fixed is simply wrong as it is too close to the sidewall.
+2687268972689
Old 02-01-2010, 05:09 PM   #20
SweTurbo
Big Pimpin'
My Ride: 323i -98
Wrong, radial tires can be tubed , i've seen several (though they've been like 185/75-15) and that's not to close to the sidewall , the area that needs to be treated is so small that the puncture would have to be on the "curve" of the sidewall for it to be un-reparable.
