Old 02-02-2010, 12:08 PM   #1
JmAbshire
My Ride: 01 330i Jet Black
M3 Steering Wheel Refinish DIY
My steering wheel was in pretty bad shape and desperately needed to be restored and refinished to its original factory feel and look. Replacement or having someone do a rewrap at a upholstery shop would be an expensive option that would literally break the bank. However with a little work I refinished with excellent results!
I purchased the Leatherique steering wheel kit for $27 (http://www.leatherique.com/) and had absolutely phenomenal results. I was very impressed the products themselves and with the little amount of effort it took to make the wheel look and feel new again (estimate about 6 hours over 5 or so days). Of course I spent the majority of the time prepping the wheel, and I have a lot of experience shooting paints/stains, your skill level will determine the end result. That's just my disclaimer, don't let that discourage you, this is truly an easy DIY.
What you'll need:
Leatherique Steering Wheel Kit (includes 4oz of each of the following: Prepping agent, Black Dye, and Klear Kote)
Leatherique Rejuvenator oil (If you have leather you should have this stuff on hand at all times, the most amazing cleaner available in my opinion)
Leatherique Pristine clean (Same as above)
A few sheets of 600, 1000, 1500 grit sandpapers
Crack Filler (Used if you have any problem areas that don't come smooth after you hit it with your 1500 grit)
1.A few days before I started the actual refinishing of the wheel, I did a rejuvenator oil and pristine clean treatment to hydrate and clean the leather. Once I pristine cleaned the wheel, I let it dry for a few days.
2.Unhook negative battery terminal, and removed the steering wheel. Pretty straight forward, there's a good DIY here http://kinmak.com/?page_id=88
3.Once the wheel is off I removed all of the electronics and trim plates. (see above link)
4.I sanded the wheel with some 600 grit wet/dry sandpaper with the prepping agent to remove all of the original glaze, oils, and die. The prepping agent did an excellent job removing the old dye; make sure you wear gloves!
5.Once I did a round of 600 grit, I moved to 1000 grit, then to 1500 grit. The wheel was now silky smooth with the exception of 1 o'clock. From the pictures one will note some pretty nasty damage at this and the 8 o'clock positions. The 8 o'clock position was easily sanded and blended perfectly, not so with the 1 o'clock position. Not to worry I have some crack filler on hand from a previous repair for a screw driver in the back pocket incident that I don't want to talk about. I applied it onto the damaged area and press it into the area with a plastic applicator. I let that cure for about 3 hours and went back at it with my sanding regime 600, 1000, 1500. Problem solved, worked perfectly! I let the filler and dye cure for 24 hours.
6.Next, mask off with paper/tape around anything you don't want to get dye on, for me that was the interior of the wheel and the rear vinyl etc...
7.From the directions you can wipe the dye on, but for a more factory finish I decided to spray (I have a decent HVLP setup). I realize most DIY'ers won't probably have this, but It'll definitely take your results to the next level, gave me a very smooth and consistent professional finish, plus its very fast and uses significantly less product. The wiping/blotting technique on the leatherique site has been used with great success as an alternative to spraying.
8.Shot 3 coats, fine mist each time. I thinned 4:1 with distilled water for those who will spray. After this my fix to the 8 o'clock position was completely undistinguishable like it was never there!
9.I Let the dye sit for another 24 hours, and then applied a coat of Klear Kote. I applied the Klear with piece of (clean/lint free) T shirt and wiped it on, being careful to do in a uniform way to reduce buildup and streaks.
10.Let that sit for another 24 hours and reinstall the wheel. That's it..
The biggest issue anyone might face is, unless you have an old wheel, you'll be out of a steering wheel for at least 3 days while your dyeing and refinishing the wheel, plan accordingly. From a product standpoint I used 1.5oz of dye, .5 oz of Klear Kote, and about 3oz of the prepping agent. So with the exception of the prepping agent I could do another couple wheels with the amount of product I have left.
Hope you find this useful!
Jason
UPDATED PICTURES
ID:	347182   Click image for larger version
ID:	347183   Click image for larger version
Name:	After Close up.jpg
ID:	347184   Click image for larger version
Name:	During the wet sanding.jpg
Name:	during the dying process.jpg
ID:	347190   Click image for larger version
Name:	Close up of the finish.jpg
ID:	347191   Click image for larger version
Name:	poor mans spray booth.jpg
JmAbshire is offline   Reply With Quote
Old 02-02-2010, 12:12 PM   #2
pushtiulk
My Ride: 2003 BMW M3 Hamann
Send a message via Yahoo to pushtiulk
Great results.
2007 Fiat Panda 1.3 JTD - Daily Car
2003 BMW M3 Hamann - Sold
Auto Detailing
Leatherique Romania
pushtiulk is offline   Reply With Quote
Old 02-02-2010, 01:53 PM   #3
Navin323i
Europrojektz East
Navin323i's Avatar
My Ride: See Sig
Great writeup!
Question though... I envisioned just applying the dye to my steering wheel and not removing the wheel.
Is it possible to do this without having to remove the entire wheel? I have a few spots on my steering wheel where it's a bit worn - can't see it unless you look behind the wheel around the 12 o'clock position.
Below is a pic of my steering wheel...
USA Paralympic Table Tennis Athlete and the 1st in history with Parkinson's Disease and father to these 2 lovely angels below...
BMW Individual Atlantis Metallic Twin Screw S/C'ed 2000 323i
SPONSORED BY: BBS | Modbargains | Toyo Tires | DPE | WheelSTO | Vorsteiner | European Auto Source | Bimmertools | GetBMWParts.com | Race Apeel
Navin323i is offline   Reply With Quote
Old 02-02-2010, 04:46 PM   #4
JmAbshire
Originally Posted by Navin323i View Post
Great writeup!
Pretty sweet wheel man... depending on the damage (if you have to use any filler) you might not have to take the wheel off, but.... the wheel is pretty simple to remove, and you'll end up doing a better repair job just because it won't be as hard to position your self and keep your interior clean IMO.
I would opt for removing the wheel you'll be happier with thre results in the long run.
Jason
Old 02-02-2010, 05:06 PM   #5
Navin323i
Europrojektz East
Navin323i's Avatar
My Ride: See Sig
Jason
Thanks Jason! It's a carbon fiber AC Schnitzer steering wheel that unfortunately has been long discontinued... fortunately I found and bought the last brand new one in the world almost 4 years ago.
Another reason why I didn't want to remove the wheel is due to medical reasons on my end (heart condition plus pacemaker) and didn't want to pay someone to remove my wheel and reattach it later.
In my case here I just have a few "touch-up" spots that would need to be dyed. What is the purpose of the filler that you were mentioning?
Old 02-02-2010, 06:29 PM   #6
JmAbshire
......In my case here I just have a few "touch-up" spots that would need to be dyed. What is the purpose of the filler that you were mentioning?
The filler is for if the leather has been damaged and can not be sanded smooth if you can hit it with some 600,1000,1500 and it becomes smooth then you're ok. The other thing is for the dye to adhere to the wheel you'll need to remove the old dye/oils etc.. in that area or section for your particular wheel. This is primarily why I would remove the wheel due to the mess you'll have with a leather dye prepping agent or deglazer. Also chances are the new dye will not match the existing wheel color due to natural aging, fading, etc. so you'll be able to tell where you made the repair. You probably want to do all the leather areas at the same time regardless of it it needs it or not. That way it'll all match.
hope that helps Jason
Old 02-03-2010, 06:59 AM   #7
JmAbshire
I added a few more pictures.....
Old 02-04-2010, 09:19 AM   #8
Navin323i
Europrojektz East
Navin323i's Avatar
My Ride: See Sig
Thanks Jason... that definitely helps! Since you're local to me I may contact you later on (in case I have more questions) once I actually undertake this project.
Old 02-04-2010, 01:32 PM   #9
JmAbshire
Sure thing man....
Old 05-24-2010, 07:56 AM   #10
lkstaack
My Ride: 04 330iZHP, 05 325iT
Can you provide more detail on what crack filler is and where to get it? Also, do you have any suggestions on how to re-dye the wheel without coloring the tri-stitch stitching?
Lars
2004 330i ZHP ESS TS2
lkstaack is offline   Reply With Quote
Old 05-24-2010, 10:26 AM   #11
JmAbshire
The crack filler is used to repair any cuts, rips, or any other damage for that matter in the leather. You fill in the damaged area, let it cure for about 4 hours or so, then hit it with some sandpaper to level it off. It then can absorb dye at the same rate as the leather and is indistinguishable when the job is complete and done properly. The best stuff is from Leatherique (link below) youíll not need any more than 2oz.
http://www.leatherique.com/products.html
Unfortunately you will not be able to pull off not messing up the stitch color .... even if you donít spray and use the blotting technique. When you use the prepping agent as a lubricant to remove the dye, all of the old dye is going be everywhere and will stain pretty much everything it comes in contact with. Just to hard to not get it on those threads.. Sorry man...
Good luck
Jason
Old 09-08-2011, 10:32 PM   #12
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
I'm guessing the dye doesn't match stock exactly?
phamine is offline   Reply With Quote
Old 09-09-2011, 05:55 AM   #13
sgplayer69
My Ride: 2003 CB M3 Coupe
any updates on the longevity of the dye?
Coming Soon...?
sgplayer69 is offline   Reply With Quote
Old 09-09-2011, 06:54 AM   #14
JmAbshire
Dye is holding very well, every once and a while I do a quick pristine clean wipe down and that's it, stuff is rock sold.
As for the match, the dye is black with a glosser finish than stock, but I'm thinking that's why its holding up better.
Jason
Old 09-09-2011, 07:06 AM   #15
phamine
Thinking about covering the trip stitch with tape and the dying. Is the a noticeable difference if that is done.
Old 09-09-2011, 07:50 AM   #16
JmAbshire
I didn't have the multi colored stitching if that's what your talking about, it would be very hard to make it look good and not get any dye on it, best to dye everything IMO
