Thread Tools Search this Thread Rating: Thread Rating: 46 votes, 5.00 average. Display Modes
Old 03-31-2003, 09:56 AM   #1
XscoreX
My Ride: the dirt devil
Send a message via AIM to XscoreX
need fuse diagram 323ci!
does anyone have a scan or pdf of the e46 fuse layout for a 323ci 2000? I lost the sheet that was in the glovebox now I have no idea where everything is, thanks!
XscoreX is offline   Reply With Quote
Old 04-01-2003, 06:22 PM   #2
Scoot
My Ride: 2001 325i (blk/blk)
Fusebox Layout
Since no one has answered your post, I have attached pics from my 2001 325i. One pic shows the entire fusebox, so maybe it matches your 323i. The other two pics are the left and right side of the placard. Hope this helps.
Scoot is offline   Reply With Quote
Old 04-01-2003, 06:23 PM   #3
Scoot
pic2
Old 04-01-2003, 06:23 PM   #4
Scoot
pic3
Old 04-01-2003, 08:10 PM   #5
rAyZ
modding is expensive!!!!
My Ride: FX45 (then 323Ci)
Send a message via ICQ to rAyZ Send a message via AIM to rAyZ
i'll go down to take a pix of it if u gimme da number of that gurl in ur sig .. hahahah!!!!
j/k ... gimme a sec..
rAyZ is offline   Reply With Quote
Old 04-01-2003, 08:42 PM   #6
rAyZ
uMmm....there's a little problem
it's April Fools Day ... and I was napping ... and my roommate and my friends did a phrank on me....they moved my car somewhere and now i can't find it ... ahhahaha!!!!!
Old 04-04-2003, 09:36 AM   #7
XscoreX
thanks for the pics of the placaard does anyone know if the fuse #s would be different between the 323ci & a 325i? I figure it is all pretty much the same but there might be a few changes, thanks!
Old 04-18-2010, 11:31 AM   #8
AMCINK
My Ride: 2000 323CI
Thanks for the pics ans chart I did not had the chart in my car
AMCINK is offline   Reply With Quote
Old 04-18-2010, 11:40 AM   #9
Anub!s
My Ride: e46 330ci, e92 M
Send a message via AIM to Anub!s Send a message via MSN to Anub!s Send a message via Yahoo to Anub!s
here's another
Anub!s is offline   Reply With Quote
Old 05-23-2011, 10:14 PM   #10
vndavid
My Ride: 2000 BMW 323Ci
Where is the fuse box located in a Bmw 2000 323ci, and what number of fuse is for the sunroof
vndavid is offline   Reply With Quote
Old 05-23-2011, 10:23 PM   #11
TrickTizzle
My Ride: 325i
Old 05-24-2011, 09:03 AM   #12
vndavid
Thanks to Trick Tizzle for pics. I check the fuse no. 46 for the sunroof but not burnt or cut. Here's what happened, I replaced the right and left sliding headliners for the sunshade. Everything works after the repair and sunroof function as normal. I tried to manually adjust the sunroof glass cover elevation. I tried to close the sunroof but has no power so I cranked the motor manually to close. Do I have to replace the switch or the motor?. Should the OBD II detect the fault?
