Sponsored by The Tire Rack
Old 02-06-2010, 12:42 AM   #1
jzwu
My Ride: 2005 BMW 330Cic
Think about square setup....
My car has the factory staggered setup now.
Front: 225/45-17 Dunlop 8080 tires with 17x7.5 M68 OEM wheels (~21 lb/ea)
Rear: 245/40-17 Dunlop 8080 tires with 17x8.5 M68 OEM wheels (~22 lb/ea)
I just feel too much understeer when making turns. Now thinking about changing to a square setup. I have found Kosei K1 racing wheels 17x8.5 at 17 lb/ea and Continental ExtremeContact DWS 245/40-17 tires on Tirerack.com.
Does this work? Will the square setup fit in the front like OEM? The rear fits exactly like OEM.
jzwu is offline   Reply With Quote
Old 02-06-2010, 12:45 AM   #2
BartenderPlease
My Ride: '03 540i/6 M-Sport
that should work out just fine, what offset on the wheels?
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Fiber Trim |
BartenderPlease is offline   Reply With Quote
Old 02-06-2010, 12:47 AM   #3
jzwu
Kosei K1 racing wheel info
7x8.5
$175 (each)
Offset: 40mm
Backspacing: 6.30"
Bolt Pattern: 5-120
Rec. Tire Size: 225/45-17
Weight: 16.8lbs.
Old 02-06-2010, 12:48 AM   #4
jzwu
17x8.5
Old 02-06-2010, 10:54 AM   #5
BartenderPlease
then you are good to go. if you have a coilover kit and you hear/feel rubbing in the front you may need a small spacer to push it off that damper
Old 02-06-2010, 11:03 AM   #6
e46techtuner
My Ride: 2000 328i
I have Kosei K1s on my car. 245/40/17 or 255/40/17 will fit just fine square...even with some coilovers.
e46techtuner is offline   Reply With Quote
Old 02-06-2010, 11:06 AM   #7
BartenderPlease
thanks
I know some coilover kits are different but glad you clarified this
Old 02-06-2010, 11:07 AM   #8
tiloulou330i
My Ride: 02 330i zsp
Send a message via AIM to tiloulou330i Send a message via MSN to tiloulou330i Send a message via Yahoo to tiloulou330i
Do it!!!!!You'll love it.That's what i have now on my car,excellent handling.
Filbert
Originally Posted by nawmean?
I know I sound naive, but some of the advice I've taken from this board has helped my life quite a bit
tiloulou330i is offline   Reply With Quote
Old 02-06-2010, 11:13 AM   #9
jzwu
Will the steering be more difficult?
The factory setup already has a relative stiff steering that my wife complains about.
Old 02-06-2010, 11:20 AM   #10
BartenderPlease
Steering may not be affected. I hate the way that our cars steering feels
Old 02-06-2010, 01:03 PM   #11
jzwu
The steering is tight but I got used to it pretty quick. I think it feels better than the Nissan Maxima I have.
Old 02-06-2010, 06:45 PM   #12
Geeforce
My Ride: 2002 330Ci Sport
Post pics once you get this set up as I am considering the same package from Tirerack...
Geeforce is offline   Reply With Quote
