Old 02-09-2010, 08:34 PM   #21
jzwu
My Ride: 2005 BMW 330Cic
Sounds like some fuel pump problem
jzwu is offline   Reply With Quote
Old 02-09-2010, 11:13 PM   #22
slickware
My Ride: 323i
lol.
I keep gas in my car, so that's definitely not it.
slickware is offline   Reply With Quote
Old 02-09-2010, 11:15 PM   #23
slickware
My Ride: 323i
I think the pump itself is in good shape.
I was thinking maybe fuel pressure regulator...
Old 02-10-2010, 01:35 PM   #24
slickware
My Ride: 323i
CPS and Serpentine belt arrived today. Figured if I have to take the fan off, I'll put in a new serp belt too. Who knows when it was done last!
Old 02-11-2010, 04:18 PM   #25
slickware
My Ride: 323i
2 CPS sensors and serp belt installed. Wow, what a ***** to find the connector for that intake CPS! It's frigging UNDER EVERYTHING!
Cleared my CEL, gotta go drive it around a bit now and keep my fingers crossed. Should take about 5 minutes before the sucker comes back on
On the bright side, throttle response is back to normal, nice snappy bmw feel.
Old 02-12-2010, 05:15 PM   #26
slickware
My Ride: 323i
50-60 miles on the car since the VANOS repair and the CPS replacement. Still no CEL, although the car did refuse to start today - sits there and cranks like it's still not getting fuel, and then starts.
However, it *didn't* act limp the hard-start, like it usually does.
I'll check for codes in a little bit, even though the CEL is still off.
Any other thoughts?
Old 02-13-2010, 09:52 AM   #27
slickware
My Ride: 323i
Scanned codes with the peake tool: 15/41: Camshaft Position Intake Sensor
WTF. Returning the aftermarket and purchasing the $116 OEM one today I guess.
Old 02-13-2010, 03:16 PM   #28
slickware
My Ride: 323i
OEM sensor installed. Cleared CEL again, time to go drive...
Old 02-13-2010, 05:55 PM   #29
carthageHannial
My Ride: 330CI
Try to reflash the DME, I mean you've replaced pretty much everything on that car ....
I don't beleive hard/hesitant starts have anything to do with the DME, but some of the problems you've mentioned- car stalling when slowing down/breaking to low speed- could be fixed with a reflash. Not sure if you did, but check the spark plugs, take'em out and examine them.
carthageHannial is offline   Reply With Quote
Old 02-13-2010, 08:15 PM   #30
slickware
My Ride: 323i
Engine is now throwing codes for the EXHAUST camshaft sensor! Stupid aftermarket sensors!
I'll have to order a new one and put it in Tuesday.
On the bright side, the car is running fine otherwise.
Carthage - I'll search the forum and look at reflashing the DME. I'm not sure what that means but I am sure I can figure it out with a search
Old 02-15-2010, 08:28 AM   #31
slickware
My Ride: 323i
So I put my old sensor back in, no engine light and no Exhaust Camshaft Sensor code.
NEW code: "EVAP LDP reed switch doesn't open".
How'd that happen? Could the old exhaust CPS be bad and cause that code somehow?
Old 12-14-2016, 08:05 PM   #32
lilise46jetblack
Originally Posted by slickware View Post
Hopefully the vanos seals I replaced will be good enough.
If that whole vanos needs replacement, I'll be dumping this POS and going back to Honda
So what happened? I have the same problems replaced:
Fuel pump
Fuel filter/ pressure regulator
Fuel pump relay
Manifold gasket, CCV / hoses
Still have the long crank...
lilise46jetblack is offline   Reply With Quote
Old 12-14-2016, 08:09 PM   #33
jfoj
My Ride: 330CiC, M5, X5
Thread is over 6 years old, not sure you will get a reply, but maybe??
Intake cam sensors problems can cause long cranking.
Also watch the tach and see if it moves to 100-150 RPM while cranking.
Old 12-14-2016, 08:14 PM   #34
slickware
My Ride: 323i
Heh. I still get email notifications for replies. If I remember correctly, that resolved my problem. I kept the car for a few more months and then sold it, still running well.
Old 12-14-2016, 08:28 PM   #35
lilise46jetblack
I changed the CSPS intake one already ***128557;.
Yes the rev goes to 100-150.
Would leaky injectors do it. That's my next step?!?
Old 12-14-2016, 08:30 PM   #36
lilise46jetblack
The hope is lost if you fixed it with the CPS and it doesn't do it with my case. It's so weird... the car drives like a dream except for this stupid problem...
Any advice?
Old 12-14-2016, 08:31 PM   #37
slickware
My Ride: 323i
On a 2000? Honestly, I'd suspect a vacuum leak. Every ****ing rubber part on that car was bad when I owned it, and that was over six years ago. If any of those rubber hoses on yours are still the originals, they're probably swiss cheese by now. Have a smoke test done.
Old 12-14-2016, 08:46 PM   #38
lilise46jetblack
Already did smoke test
Brake fluid test
No air leaks
I will never solve this problem ***128557;
Old 12-14-2016, 08:59 PM   #39
slickware
My Ride: 323i
"I will never solve this problem"
Solve it how I did... Sell the car
That's how I felt though too. That thing was weekly problems for the entire time I owned it. Fun as hell to drive, but gawd what a headache.
Old 12-14-2016, 09:00 PM   #40
lilise46jetblack
What does the tach moving to 100-150 while crank mean?
Also why pumping the gas pedal helps in this condition?
fuel, shitbox, stalling, starting, vanos
