Old 02-08-2010, 02:11 PM   #1
Tater49
My Ride: 04' G35 Coupe
M52TU Build
Alrite so here it goes. A swap and FI is out of the question due to availible funds. I already have Headers, Dinan Software, Remus Muffler and a Dinan CAI. I am planning on doing an M54 Manifold Swap and UUC Pullies next. After I'm done with those 2 mods, should I start breaking down the cylinder head and upgrading that? (Port & Polish, Slightly bigger valves, Tougher Springs, etc.) I am also considering ZHP Cams. I am almost positive that they are a direct swap, can someone clarify that for me? Also, will I see a significant difference between ZHP and Schrick Cams and if so, which set should I go with and will that power justify the money being spent on the Shricks? I don't think I will upgrade the bottom end of the engine because it seems that the stock internals are fairly strong, or atleast strong enough for an N/A build. After that a good tuner would need to finish everything up and thats about it. Am I missing anything?
2000 328i 5 Spd Black on Black SOLD!
2004 G35 Coupe 6 Spd Gray on Black Current
Daily
FS. JB Racing Lightweight Flywheel (Non-M 6 Speed ONLY) - $450 obo
FS. Spec Stage 3 Clutch Kit (Non-M 6 Speed ONLY) - $400 obo
Tater49 is offline   Reply With Quote
Old 02-08-2010, 02:18 PM   #2
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Yes, there is a big difference between Schrick and ZHP cams. Go with the Schrick.
