FS: MISC ice Part Out, BSW, KEF, Alpine
Alpine AiNet Switch 4-port KCS-400c $200This switch can be used to hook additional CD Players, or IPOD controllers or other supported AiNet products. It does not include any AiNet Cables but does include 1 AiNet to RCA converter made by PIE. This is not the current 2-port version but is the discontinued 4-port AiNet version.
Alpine IPOD Controller KCA-420i $60This unit does not include IPOD cable; I can modify it to wake the IPod. However I won’t be able to guarantee the unit, as I have no way to test after making the modification. I will include the modification kit purchased from intervention if you choose not to have me modify the unit. KEF Rear Speakers mounted in BSW conversion rings $35These are KEF Co-linear Speakers, including crossovers. One cover was trimmed to fit in rear seat airbag location. One Adapter ring has a stress crack but once installed it has no impact.
6 ½ in Kef Speakers and crossovers no tweeters Q160 $25These were items installed in my front doors. One tweeter was failed in the last year so I am selling just the Mid-bass speakers and crossovers.
Modified Spec Dec $25This unit was originally for a DICE, but after replacing my DICE I modified it to support 12v Charging and Aux input using a 3.5 mm cable. Audio Control Matrix $50
I used this to interface my Amps with the BMW Factory Radio outputs. It convert BMW balance differential to standard line level.
More pics available.
