Sponsored by The Tire Rack
Old 01-14-2010, 10:21 AM   #1
TiAg2247
My Ride: E39 M5
Fitting 19x10.5 et25 on e46 non-M
Yes you read that right. I know I'll have to shave the fender lips and raise the rear a little AND stretch the tire, dial in more negative camber... But will that be enough? Might even machine off 5mm of the hub to bring it to et30. Right now with a 19x9.5 et45 I am nowhere near flush, I'm hoping the new setup won't stick out atrociously.
Poke and stretch / wheel fitment gurus, help me do it without excessive bodywork!
Imola Red M5 | Imola Red Interior
M-Audio Package, Power Sunshades, GT Exhaust, Custom BC Coilovers
Past:
'01 330Ci Titanium Silver on Coral Red
'96 328i Jet Black on Black
TiAg2247 is offline   Reply With Quote
Old 01-14-2010, 11:46 AM   #2
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
Imagine your car with a 20mm spacer.. almost.
Throw a 245/35/19 on it and I'm pretty sure you can make it work.
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is online now   Reply With Quote
Old 01-14-2010, 12:14 PM   #3
SIN3
My Ride: Fitment Connoisseur
Send a message via AIM to SIN3
this can be done but the 10.5 has to have a low offset. i put a 10 VB3 at et33 and with no tire it came to the fender. i am sure with some camber you can do it but i would suggest running 245-255 max 30/35 series anything more and you cannot lower you car drasticly.
OR
if you getting wheels with custom offsets have the offset in the 40s
2006 M3 Cabrio
2004 ZHP Cabrio
/stanceworks\
"keep it clean, keep it OEM+"
SIN3 is offline   Reply With Quote
Old 01-14-2010, 01:23 PM   #4
TiAg2247
My Ride: E39 M5
I was sticking to a 255/30 at most. I'll have to crunch numbers once the wheels arrive
Past:
Old 02-15-2010, 08:04 PM   #5
TiAg2247
My Ride: E39 M5
Alright it's down to either a 245/35/19 Kumho SPT or FK452; or a 255/30/19 Toyo T1R or Kumho SPT. I'm hoping to pull it off with the 255. Going to see how tight the wheels fit when they arrive next week. Can't wait!!!
Past:
Old 02-15-2010, 09:03 PM   #6
BMW-UDM
My Ride: Piggy bank
its def doable, without question! I be running something wider and in lower offsets OP, go for and dont look back...
yes non-m as well.... dont let ppl who dont know anything abt wheel fitment tell you otherwise (not referring to any previous posts on this thread)
BMW-UDM is offline   Reply With Quote
Old 02-15-2010, 09:07 PM   #7
SteelGray3
My Ride: 2003 slicktop LSB M3
Let the punka$$ 17 year old tell you.
(I'm helpin this indecisive mofo pick his wheels and specs lolz)
SteelGray3 is offline   Reply With Quote
Old 02-15-2010, 09:10 PM   #8
BMW-UDM
My Ride: Piggy bank
spec are done, mofo which some M3 done even run lol just need to figure out the finish!
