Old 02-10-2010, 09:34 PM   #1
anival755
My Ride: 323i M-Sport
323i exhaust suggestions
alright so i have a 2000 323i msport, 5 speed.. Im looking to get an exhaust done, but i have no idea which route to go. I have also seen people delete the mufflers and resonators.. Does doing the muffler delete kill power at all??
anival755 is offline   Reply With Quote
Old 02-10-2010, 10:05 PM   #2
vsvahia007
My Ride: E46 M3 02 Vert
Straight pipe will give you a nice sound from Stock. Horsepower wise your going to lose power due to the loss in back pressure. I would recommend deleting resonators with test pipes to free up the exhaust flow. I would recommend upgrading the rear muffler with either Active or Eisneman to obtain both performance and superior sound.
vsvahia007 is offline   Reply With Quote
Old 02-10-2010, 11:02 PM   #3
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
I would do Active Autowerke. These are designed to give the car a deeper grumble but not be too loud for daily use or ruin the classic BMW sound.
Active Autowerke 323i/328i Exhaust
This is a 325 but will give you an idea:
Old 02-10-2010, 11:33 PM   #4
Iceman00
Banned User
My Ride: E90 6MT
This is bullshit. All of it.
I have already posted many times on how to make power from an exhaust:
Y pipe as close to the header collectors as possible, to a single 3" exhaust. You do not lose power from "lack of backpressure"
Everything else out there is a muffle, which will give next to no noticeable gains.
Old 02-11-2010, 01:12 AM   #5
anival755
i was told that a 3" was WAY too big for a 2.5L. i was going to do that till they told me otherwise.. i just want the sound in the cheapest way possible.. im not after the performance...
Old 02-11-2010, 03:02 AM   #6
Iceman00
Banned User
My Ride: E90 6MT
How is it too big? Pipe size doesnt really matter after the Y pipe anyhow.
Old 02-11-2010, 02:09 PM   #7
anival755
well i called my local bmw dealership, and the second i told them 3", they said that was WAY too big for my I6.
Old 02-11-2010, 02:18 PM   #8
ModBargains
ModBargains's Avatar
My Ride: M3
Supersprint or Remus is a great and proven system!
Mike the CEO of ModBargains had a Supersprint on his project 323ci
Kevin
Blake Brunner|blake@ModBargains.com|(714) 582-3330 ext. 8011
We Specialize In:
BMW Brakes | BMW Suspension | BMW Parts | BMW Exhaust Experts | BMW Tail Lights |
BMW Wheels | BMW Intake
Hours
Check out our Blog for updates!
ModBargains is offline   Reply With Quote
Old 02-11-2010, 02:39 PM   #9
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Old 02-12-2010, 12:50 PM   #10
Tater49
My Ride: 04' G35 Coupe
Grab yourself a pair of ebay headers from a trusted seller, and loose the restrictive stock muffler and you should be good. It's a cheap setup that gives you a beautiful exhaust tone and isn't too raspy. Your not going to gain much power by going full exhaust if you have headers and a different muffler.
2000 328i 5 Spd Black on Black SOLD!
2004 G35 Coupe 6 Spd Gray on Black Current
Daily
FS. JB Racing Lightweight Flywheel (Non-M 6 Speed ONLY) - $450 obo
FS. Spec Stage 3 Clutch Kit (Non-M 6 Speed ONLY) - $400 obo
Tater49 is offline   Reply With Quote
Old 02-12-2010, 12:53 PM   #11
mtnbound
Town Clown
My Ride: 330Ci Vert, 325iT
Bay Area Top Dropper
Orient Blue 330 Ci Vert
mtnbound is offline   Reply With Quote
Old 02-12-2010, 02:37 PM   #12
anival755
yea thats probably the route ill take.. is the header install tricky?? ive done headers b4 on other cars, im just curious if BMW likes cram them in there
Old 02-12-2010, 02:50 PM   #13
Tater49
Install is a little tricky but since you have expirience you should be good. Just make sure you buy OEM Gaskets and new studs and you should be good.
Daily
Old 02-12-2010, 02:53 PM   #14
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Take your car to an exhaust place, have them cut the piping between the second resonator and your muffler, have them put straight pipes in its place (in other words, leave both resonators in tact), and then have them weld tips on the end. It's a nice cheap solution and you can pick tips that work with the rest of your car
Here is my car with the stock intake, stock headers, both resonators, and muffler delete
Hope that helps
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 02-12-2010, 03:52 PM   #15
Tater49
Daily
Old 02-13-2010, 05:00 PM   #16
anival755
i ended up getting a rear muffler. Its a direct replacement. Now im debating if i should just replace the last muffler with the performance one, or should I also cut out the last resonator and put a pipe in for the added sound..
Old 02-14-2010, 02:43 AM   #17
khbiesfd
My Ride: 2000 BMW 323ci
I also have a 323ci. I want to do exhaust ASAP. As my car sounds very.....ugh. I have stock headers and intake. I was thinking about doing 2.5 inch straigh pipe all the way back to a performance muffler such as Aero mufflers.
khbiesfd is offline   Reply With Quote
Old 02-14-2010, 02:44 AM   #18
khbiesfd
btw what size piping does the 323 come with stock?
Old 02-20-2010, 07:02 PM   #19
anival755
alright so i finished up my exhaust last night.. ended up doing a T.S performance muffler, with a resonator delete.. car sounds awesome.. is anyone wants pix let me know,
Old 03-02-2010, 03:05 AM   #20
lwderic
My Ride: alpine white e46
pics and sound clip
Photobucket
lwderic is offline   Reply With Quote
