Replacing Guage Faces on 2004 E46 330CiC - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-11-2010, 10:13 AM   #1
BigSky
My Ride: 2004 330CiC
I am trying to convert my stock guage face from black to white. The problem i am having is removing the needles. I was able to remove one of the needles using a fork, but the others will not come off, partially because i dont want to pry to hard. Any suggestions?
BigSky is offline   Reply With Quote
Old 02-16-2010, 07:40 PM   #2
ultraviolet_m
My Ride: E46 325 CI
That is how I ended up breaking my speed meter. Another problem is that afterwards you can never readjust the needles precisely right and they well be a little off with the readings.
ultraviolet_m is offline   Reply With Quote
Old 02-16-2010, 07:59 PM   #3
Puri13
My Ride: '06 Altima SE-R
Hmmm. You could try using a little rivet-remover tool? It's just a two-pronged fork. You should be able to find a small plastic or metal one, hopefully at an auto parts store. It should be angled shortly after the prongs to get better leverage. A flat head would be fine too I'm sure. Breaking it is definitely a risk you're going to have to take though, just take your time and have the dealer's # handy incase you need new needles.
Puri13 is offline   Reply With Quote
Old 02-16-2010, 09:30 PM   #4
Darkoz
My Ride: E46 325Ci
I suspect your next post will be "how to fix broken gauge cluster after swapping out the gauge face"
Darkoz is offline   Reply With Quote
Old 02-17-2010, 06:09 AM   #5
PEEBU
My Ride: E46 Touring
Hi,
Try these
http://www.lockwoodinternational.co....ails-i363.html
I put some on an E30 I owned. No need to take the needles off. Look great. Very easy
PEEBU is offline   Reply With Quote
Old 02-17-2010, 07:29 AM   #6
MIRoundel
My Ride: E36\5, E46 325ia
All needles can be removed in the same way.
I've done that on 3 cars and was succeed.
Try to apply pressure directly.
MIRoundel is offline   Reply With Quote
