#1 |
Trouble with P0171/P0174, and now P0460??
Hi all. Long time lurker and learned soooo much from you guys so thank you!!
Today I need some advice with these codes I've been getting. Background: I have a (May) 2004 330i. I pulled the intake to locate a leak and fixed it (oil filter housing gasket). I also replaced the manifold and throttle body gasket along with replacing broken or brittle vacuum pipes since it was apart. This was about a year ago. Since putting it back together I have gotten P0171 (System too Lean (Bank 1)) and P0174 (System too Lean (Bank 2)) codes intermittently. Seemed to happen more when it was cold but not always, however that was the only pattern I could discern. The codes started with reading as two of each then went to two of P0171 and one P0174. I figured it was air in the line since I popped the fuel line off when doing all that work, but then more recently was thinking it was the fuel filter and need to get to it (48k miles now). Yesterday I got the three codes again, though this time when I read the codes I also had a P0460 (Fuel Level Sensor Circuit Malfunction). Initial searching brought me to TKC's thread where he replaced the sender, pump, and filter. http://forum.e46fanatics.com/showthread.php?t=592414 I haven't had a chance to pull it apart again to make sure the elbows were tight and no new holes (I had to get a new elbow off the TB because I butchered the old one to get it off) as I've found that and bad precat O2 sensors can cause the 171/174 codes. But now with this new code I'm getting a little worried. I need this car for work (unfortunately I do some field service in it) so pulling it apart has been backseated. It can be sluggish at times but it usually only lasts a second or two. And the SES comes one usually after driving and I'm stopped at a light. Does this sound like I need to replace the sender, pump, and filter? Could the codes be coming from something I did in the engine? I have INPA on my laptop and can see misc levels from the engine and I noticed the precat O2 sensors were only at 49%-50% while the postcats were 100%. This was with the engine temp at normal/middle of the gauge. I'm unfortunately on a budget and at times have limited time to work on it so any help, suggestions, advice, BS to narrow it down is so gratefully appreciated! Also if I'm not in the right forum I'm truly sorry. I wasn't sure if this was the right one or the DIYor even the Tuning and Tech/Driveline was the right place. thanks! |
#2 |
What are the Mv reading for all four o2 sensors?
#3 |
check the DISA intake for leaks!! Use combustion chmaber cleaner and spray around DISA inlet to manifold.... check for changes to engine RPM... had same issue (except for last code), and problem was with DISA seal and flap inside DISA broken. Flap repaired and DISA reinstalled and no issues since.
My Ride:
2004 330Xi DCT Electronic Shifter Bilstein and H&R sports suspension, AA Strut Bar AA Stage2 tuning Conforti CF Cold Air Intake Hamann Front Spoiler and Side Skirts BMW OEM rear wing spoiler. M3 SMG Paddle Steering Wheel and M3 Seats 18" M6 custom painted wheels Custom red kevlar interior +++ ![]() |
#4 |
I wouldn't replace the fuel level sensor and sending unit yet. First just change the fuel filter first and see if that does it. I think if the filter is clogged you get some of the same symptoms as when the sending unit isn't working right.
As for the 0174 and 0171 codes, as the poster above stated it could be a small leak in an intake hose. Easy to rule out with some brake cleaner before you go changing the O2 sensors out. |
#5 |
Look into intake tears, MAF sensor clean or replace and DISA as stated above.
I had the same codes and it was the MAF sensor. I also replaced the fuel filter and DISA as i had 95k miles. I replaced them as preventative. |
#6 |
Like grandsrus, same codes and MAF sensor. If they keep coming up you need to replace the sensor. Make sure you take care of it quick, you're not doing your engine any favors by running lean.
#7 |
@kamagazi: In INPA the precats are at 1.5v and the postcats are .67v - .70v. Though when I was looking at them they actually dipped a little bit. The Bank1 postcat sensor dropped to .11v but then went back up to .67v. If they were constant that would be the sensor, right? This means more the fuel is not getting there? The percentage I noticed before are the 'lambda sensor heating' readings. Both precats are 46% and postcats are 99%. I also checked the error memory and it was listing "2882 mixture preparation bank1", saying "signal or value above threshold" and giving the P-code P0171. In the 'detailed' list it shows "average value bank1 5.86%" but unsure which value that really is in INPA.
@everyone: I sprayed some CRC brake cleaner around the DISA and the elbows but no change in RPM. I only did a quick spray of it in those areas but could def smell it so not sure if I it was enough to find an intake leak. I sprayed some at the front air intake but it didn't seem to change any so I might not be spraying enough. As far as the MAF, I don't have MAF cleaner but looking at it it is very shiny so could it still be dirty even if it looks clean and shiny? I know oil from the K&N filter can mess with it but it's looking clean. And could I use TB cleaner and be safe? I know they make MAF cleaner for a reason but in ATL it's snowing and gonna be a PITA to get any probably for the next 24hrs. damn... did a search on that 2882 code and found this thread over at bimmerfest. My separator was replaced before I bought the car (it looks new and was told it was replaced) but maybe this is it or I have a leak somewhere in those lines? I tried opening the cap while running and there's a small vacuum and the idle does change a little bit when the cap is put on and taken off, is that normal? There's also a little 'sucking' sound from around the separator so maybe I didn't plug something in, again? Pulling this intake again is gonna ssuuuck lol again, thank you everyone! this is really helping me get to the bottom of this! addition: btw, should the DISA make noises like in this video? I don't think mine are as loud but sound similar. Last edited by envoid; 02-12-2010 at 05:51 PM. Reason: forgot question |
#8 | |
no, thats not always the case. Quite a few other things that it can be.
![]() Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight= ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight= |
#9 |
a small side question to all of this... been reading more as I gave up tearing out the intake for the night. What is 'multiplier adaption' and what would be decent values? Some of the screens i printed shows a multiplier of like 12%, but the additive is like around -1.0 to 1.0. It seems to deal with mixture trim but with taht i'm kinda lost.
thanks ![]() add: btw, i'm pulling the intake to make sure the stupid CCV is ok, along with its pipes, and to maybe replace this leaking oil line (not too bad just on the line tho). Last edited by envoid; 02-15-2010 at 09:18 PM. Reason: cuz i'm stupid |
#10 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Mod
Previous Thread
Next Thread
