The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 92 votes, 4.82 average.
Old 03-13-2010, 12:27 AM   #201
bimminge46
My Ride: 323Ci, 89 325i ETA
Originally Posted by BMW_Stu View Post
old style
Noticeable imperfections with the lower headlight trim mod.
E30 in progress.
bimminge46 is offline   Reply With Quote
Old 03-13-2010, 01:11 AM   #202
BillyJoelR
My Ride: Velvy B.
Those are really good pixors.
| There is no replacement for Displacement | Go Big or Go Home |
BillyJoelR is offline   Reply With Quote
Old 03-13-2010, 03:10 PM   #203
3uroslut
My Ride: 328ci 5speed
ok im doing this did u guys just use flat black paint? or is it the glass paint they were talking about
~~~~~INSTAGRAM @3uroslut~~~~~~
2000 328ci 5speeed uuc stage 2 clutch, 3.07 welded diff, ddm coils, solid rtabs, comber kit front and rear, bride zeta 2 racing seat, NEXT MOD: SLR super angle kit
3uroslut is offline   Reply With Quote
Old 03-13-2010, 04:45 PM   #204
ilbmwista
My Ride: 320 ci
very very nice!
ilbmwista is offline   Reply With Quote
Old 03-13-2010, 06:05 PM   #205
rpl
My Ride: 2002 330ci
^ Nope. Try again.
rpl is offline   Reply With Quote
Old 03-13-2010, 06:08 PM   #206
BillyJoelR
My Ride: Velvy B.
Wrong thread buddy.
Old 03-13-2010, 07:47 PM   #207
BMW_Stu
My Ride: HPF 330ci
yeah, heres the story on that... I had them molded smoothede and primed perfectly and i dropped them of @ the shop where my new rear bumper was being painted after being rear ended.
the idiot sanded everything down to the bare plastic, i took them back, re did my work and told them it was already sanded and primed and ready for paint, please do not sand it.
the idiot sanded it down bare again and then painted it so now im like im gonna get them re done somewhere else eventually
Originally Posted by Malladawg View Post
^Hot!
Did you paint the foglights, or did you buy they yellow ones?
both
BMW_Stu is offline   Reply With Quote
Old 03-13-2010, 07:48 PM   #208
BMW_Stu
My Ride: HPF 330ci
black paint for black, clear paint 4 colors.
Old 03-20-2010, 05:55 PM   #209
yellowssm
My Ride: 2005 M3
I am on the fence about doing the high beams yellow, is this easily reversable?
yellowssm is offline   Reply With Quote
Old 03-20-2010, 06:42 PM   #210
BMW_Stu
My Ride: HPF 330ci
if u dont like the yellow u can do black afterwards, i dont think theres any going back once u do it tho lol. aircraft remover should take it off but it would b pretty messy and you'd really have 2 be careful with it.
Old 03-20-2010, 07:05 PM   #211
dexx_x
My Ride: 2002 325ci
aircraft paint remover is some heavy stuff.... used it to strip the gas tank on my motorcycle and it had my skin itching like some herps.... not that i would kno what herps feel like
dexx_x is offline   Reply With Quote
Old 03-20-2010, 09:13 PM   #212
yellowssm
My Ride: 2005 M3
Wouldn't paint thiner take it off without messing up the reflector part of the high beam
Old 03-21-2010, 10:31 AM   #213
BMW_Stu
My Ride: HPF 330ci
i have very little paint removing experience, im sure whatever u do will b messy tho
Old 03-21-2010, 12:03 PM   #214
BBRetro
My Ride: bmw e46
cant u use the chrome speypaint? i'm thinking of blacking mine out but thinking if its reversable as well....
BBRetro is offline   Reply With Quote
Old 03-21-2010, 12:28 PM   #215
///OSS
///OSS's Avatar
My Ride: "The.. 325CI"
Send a message via AIM to ///OSS Send a message via MSN to ///OSS
both
you have no idea how many times thats happened to me. I sit there prep a piece and tell them its done, and they forget and go at it with a fuking block!!! LMAO, its already filled with filler so basically it gets ruined...LOL although my painter is on point, he notices before it goes in and calls me... but still I end up doing the sh it twice sometimes.
btw dont use spot putty to fill in, it will come off and warp immediately with expansion and contraction from the sun. Seems like you covered the whole thing. Spot putty is literally to fill in tiny little holes with no depth. Just use a good quality Everlast bondo to fill. use a block to sand the face and then go get a 90 degree aluminum bar, cut off a couple off feet of one, and line the bottom of the flat edges with stickable sand paper to do the top edge to perfection. You also did it 100% flat and it should be angled down a bit. I make a line on both and dremel the top edge then use the 90 degree to make it perfect.
just a couple tid bits
///OSS is offline   Reply With Quote
Old 03-21-2010, 04:31 PM   #216
BMW_Stu
My Ride: HPF 330ci
thanx but those r just 2 snap shots from the process, i had some other type of filler, i dont even remember what i used @ this point. now that its warm i will b getting them re done very soon.
here r some more, from the day i sent them 2 paint. its not top notch custom bodywork, but they were close 2 perfect. how they look now didnt happen over time, thats exactly how i got them back.
plastic cut and glued in
filling b4 sanding
primed!
temporarily spray painted
im sure that it would come pretty close 2 looking original and probably be just as refrective, but up close i'm sure it will be kind of rough.
Old 03-21-2010, 04:49 PM   #217
relentlessone
My Ride: '10 BMW 535i M-Sport
Send a message via AIM to relentlessone
I've been doing a lot of thinking about this since I want to black mine out but want it to be reversible. I have come up with two solutions:
1. Remove bowl, vacuum form polystyrene sheet over bowl, trim around edges and paint that black. This way it will snap on and off and be easily reversible. Downside would be that I don't know if it would warp in the hot summer sun.
2. Paint bowls black, then spray with this: http://www.dupli-color.com/products/nitelites.html
Bowl appears black until light is shined on it. Be it your own bulb or an oncoming driver.
Thoughts and suggestions?
relentlessone is offline   Reply With Quote
Old 03-21-2010, 04:55 PM   #218
BMW_Stu
My Ride: HPF 330ci
if u make the vacuum formed bowls i want some!
Old 03-21-2010, 05:58 PM   #219
snitzl3
My Ride: e60 LCI
Send a message via AIM to snitzl3
+1
snitzl3 is offline   Reply With Quote
Old 03-21-2010, 10:27 PM   #220
BBRetro
My Ride: bmw e46
can u ship that to thailand for me? if u make a 3rd extra set????................lol...............guess not.............. :')
Rate This Thread
