Old 02-12-2010, 09:00 PM   #1
jonheil
My Ride: 2002 330i
Droning noise when AC is switched on
BMW states that a droning noise that occurs when the AC is switched on comes from vibrations transmitted to the cabin through the compressor intake pipe. This goes between the compressor and the evaporator. The fix, they say, is to replace the intake pipe with a re-designed one that has a damper weight on it, or baffles of some sort. You'd swear the noise is compressor bearings but the TIS specifically says replacing the compressor will not fix the problem.
I've had this noise for a while but haven't spring for the fix yet. Has anyone done this repair? Does it work? How do I make sure I get the right (re-designed) intake pipe?
jonheil is offline   Reply With Quote
Old 02-12-2010, 11:40 PM   #2
iansanderson
My Ride: 2001 330CiC
i had this problem so I had BMW completely drain and refill my refrigerant with the correct amount of new oil. It fixed it 100%. I think the original oil gets wore out, dirty or low and causes the compressor to drone. My car cooled better after the drain/fill too.
Cheat Sheet:
GT1/ISIS/MoDiC = Factory authorized diagnostic system used by BMW dealerships across the world.
NCS Expert = BMW Factory R&D programming tool available on the internet (not intended for the public and not available to the dealership network)
OEM = Genuine BMW part only available from a franchised BMW dealership.
DME = Engine Management Computer
iansanderson is offline   Reply With Quote
Old 02-13-2010, 08:21 AM   #3
kwikt
My Ride: 2003 330i
Mine has been doing this for the last 2 years.
kwikt is offline   Reply With Quote
Old 02-14-2010, 04:59 AM   #4
EAZYE46
My Ride: E46 coupe.
Does your A/C currently blow cold?
I had the same problem and fixed it just like iansanderson did. Just get everything flushed out, and topped up with new refridgerant, check for leaks etc etc.
When it was making that noise, my A/C blew room temp air out.
EAZYE46 is offline   Reply With Quote
Old 02-15-2010, 05:33 PM   #5
jonheil
My Ride: 2002 330i
Strange thing is, it blows cold. Maybe I'll just flush the whole system anyway though. How much did it cost you?
Old 02-15-2010, 05:41 PM   #6
Rene325ci
My Ride: a car
I replaced that line and it took care of the problem
Originally Posted by Born Again View Post
relax kiddies ur 10 year old car is still god on this forum
Rene325ci is offline   Reply With Quote
Old 02-19-2010, 12:45 PM   #7
KillFox
KillFox's Avatar
My Ride: 2001 330xi
Send a message via AIM to KillFox
How do you drain the ac? How much did you pay for a flush?
Sig by 325i-Vizon
KillFox is offline   Reply With Quote
Old 02-19-2010, 02:07 PM   #8
kwikt
My Ride: 2003 330i
Is it a diy job???
Old 02-19-2010, 03:29 PM   #9
iansanderson
I think i was charged about $130 from the dealership. I'm sure a local shop could have done it for less, but I didn't want any headaches. I knew the dealership had probably done 2938472398 of them over the years, so they had it down pat and use the recommended oil.
Cheat Sheet:
Old 03-15-2010, 09:32 PM   #10
davothegreat
My Ride: 2002 325i
Part #
Does anyone have the part number for the revised intake line for a right hand drive 07/2002 325i (assuming there's a difference between LHD and RHD)?
My car has been making this noise for over a year. The freon was topped up 9 months ago (the guy said the system was pretty much full anyway) - this cured the noise for a week but the air is still freezing cold.
davothegreat is offline   Reply With Quote
Old 03-18-2010, 09:22 PM   #11
jonheil
My Ride: 2002 330i
UPDATE : It's been a while but I finally got around to ordering a new intake pipe. My car was built 11-2001 and according to realoem the part that is needed for cars built from 9-2001 is p/n 64 53 6 923 956. I called the local dealer and asked if they could verify if there was any re-engineered replacement part and they said no, but they a bunch of fools anyway. I'm done over there. So I took a chance and just ordered this p/n and anxiously awaited the arrival. Upon opening the box I noticed right away a large baffle hanging off the compressor side of the pipe, about the size of a lemon. Just like the TIS said, so I'm sure this is the right (re-engineered) part. I'm planning to swap it out myself, refill lost oil, then take it to an indy for evac and refill. As long as the system is open for less than 24 hours you don't have to replace the dryer.
I don't know if this is the same part for a RH drive. If your line is on the right side of the car, as seated in it, it should work.
Old 04-08-2010, 01:54 PM   #12
Zazupilot
My Ride: 2002 325i
any updates on this fix? I think I have the same problem and am considering this TSB fix.
Zazupilot is offline   Reply With Quote
Old 11-25-2010, 11:35 PM   #13
hamadyr
My Ride: '05 330i ZHP
Help !!!!!!!!!!!!!
Does anybody have the number of the TSB ?
Better yet, can someone post it. I have a few months of CPO warranty left and my local dealer wants to charge me for the pipe replacement ...
hamadyr is offline   Reply With Quote
Old 03-05-2012, 08:55 PM   #14
spugeddy
My Ride: 02 325i
subscribed.. anyone update this?
spugeddy is offline   Reply With Quote
Old 11-14-2012, 12:11 PM   #15
eerener
My Ride: 2001 BMW e46 325i
any updates? I guess I need to replace that hose too
eerener is offline   Reply With Quote
