Old 02-15-2010, 10:03 AM   #1
CLUTCH
My Ride: 330ci
weld the diff??
so i dont know if im going to get flamed for this but iv been thinking about welding the diff on my 330. i plan to use it for drifting events and im not worried about tire wear. i juss want some input from u guys. yay or nay?
CLUTCH is offline   Reply With Quote
Old 02-15-2010, 10:12 AM   #2
CLUTCH
My Ride: 330ci
screw it ima juss do it! lol
Old 02-15-2010, 10:59 AM   #3
NikolaiD
My Ride: 2002 M3C
Send a message via AIM to NikolaiD Send a message via MSN to NikolaiD Send a message via Yahoo to NikolaiD
It's ok for the drifting events, but sucks otherwise.
One of your tires skids every time you turn at a slow speed and you look like an idiot, haha.
Def the cheapest way to go though.
P.S.
Have some replacement half-shafts ready.
_______________________________________
My Ride: 2002 M3C
NikolaiD is offline   Reply With Quote
Old 02-15-2010, 11:18 AM   #4
CLUTCH
My Ride: 330ci
P.S.
yah i know what u mean i drove on a weld diff for a few years n ppl used to always think there was sumthin wrong with my car lol
Old 02-15-2010, 11:25 AM   #5
drumad
My Ride: E30, 240sx
Driven a 240 with a welded diff. It's good cheap fun.
drumad is offline   Reply With Quote
Old 02-16-2010, 02:45 PM   #6
mrshelley
My Ride: 2004 330i
Try driving a FWD drive car with a welded diff.
Old 02-16-2010, 03:04 PM   #7
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
That doesn't sound fun.
OP, go ahead & weld your diff up. As long as this car sees very little street use, & is on
the track most of the time, it will workout great.
SUMMIT POINT WV 1:24:229 SCCA
Old 02-16-2010, 09:03 PM   #8
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
I've done this, and have some serious warnings to give:
#1.) Wash the diff out with soap and water before starting extremely well. DO NOT use contact cleaner or other solvents. They can KILL whoever is welding if they inhale the fumes.
#2.) Wash the diff out again with soap and water afterwards. Spend a lot of time with a stiff brush around the welds. There will be lots of little loose bits from the welding spatter that you don't want in there when using the diff.
#3.) I would fill the diff with cheap fluid and put a 100 miles on it, then change the fluid again for a good fluid. There will still be crap in the diff after step #2.
Do 5-7 point turns if you want to keep your halfshafts alive. I couldn't even push my car by hand with the front wheels turned....there was just too much resistance.
Old 02-17-2010, 08:51 AM   #9
CLUTCH
My Ride: 330ci
thanks for the advice!
