Sponsored by The Tire Rack
Old 02-16-2010, 12:27 PM   #1
treshfracks
My Ride: 325ci
Rubber Smell + Wheels Squeaking
Hi Guys,
So yesterday, I was forced to put my stock wheels back on, since my 19's tires had no more tread.
When I drove my car to work this morning, I noticed:
  1. a continuous smell of rubber (I'm assuming coming from the tires since I never smelled this before)
  2. and also continuous squeaking sounds when the wheels are spining/car is moving
Can you guys help me figure out on what's causing these? And also how to fix it?
treshfracks is offline   Reply With Quote
Old 02-16-2010, 01:20 PM   #2
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Stock wheels could possible be rubbing on the inside shock body if you are running coilovers since stock wheels are more conservative.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 02-16-2010, 02:33 PM   #3
treshfracks
My Ride: 325ci
ohhh shoooooooooot, i think you might be right on that Charles!
I have ST V1 coils installed, and I remember being told that the shock body on those are alot Wider than normal shock, which is why I was given spacers.
I can't put my spacers on until I get home. Would it be okay for me to drive back home (10 Miles) before I can install my spacers?
Would that also explain the "Sqeaking Sound" I'm hearing?
Old 02-16-2010, 02:37 PM   #4
G35 Stylez
My Ride: G Thirty Fizzy
Had that small problem on my previous car with an aftermarket setup, it was the tires rubbing the fender, especially while going into bumps on the highway. Get your fenders rolled, don't even think about wasting money for a new tire setup.
G35 Stylez is offline   Reply With Quote
Old 02-16-2010, 04:07 PM   #5
BartenderPlease
My Ride: '03 540i/6 M-Sport
this probably explains everything.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Fiber Trim |
BartenderPlease is offline   Reply With Quote
Old 02-16-2010, 05:19 PM   #6
treshfracks
My Ride: 325ci
thanks for the input g35, but it's not the fenders rubbing (got them rolled, and never rubbed even with staggered 19's)
I think it may be more of the inner sidewall of the tire rubbing on the springs themselves on the shock body itself (spring). I did some research and found that this problem is common with ST VI/KW coilovers since the shock body on these are much wider than normal. This only happens in the front shocks. Solution? Add some spacers.
Anyone else have any input/comments on this?
Old 02-16-2010, 06:03 PM   #7
VMRWheels
VMRWheels's Avatar
If its rubbing enough for you to smell the rubber, I would not recommend driving it for another 10 miles. You could possible cut the sidewall or even worse.
-Charles@VMRWheels
