Engine & Performance
Old 02-16-2010, 12:51 PM   #1
BTH14
My Ride: M3
05 E46 M3 LSD only 33K miles
Have the complete rear subframe/diff assembly from a 2005 M3 with only 33K miles. This includes the axles and driveshaft as well. Diff is still mounted in the subframe, all bushings look good. Pics available. Asking $1250, willing to ship at buyers expense.
BTH14 is offline   Reply With Quote
Old 02-16-2010, 12:53 PM   #2
E46 S54B32
My Ride: 323ci
soo basically this is plug and play for a non m...does it come with brakes too?
might be intersted
-oem m3 front -oem m3 hood -oem m3 sideskirts-conforti intake -h&r race springs -TR Motorsport C2's -smoked corners/sidemarkers -smoked LED tails-CF CSL trunk-Black roof vinyl
E46 S54B32 is offline   Reply With Quote
Old 02-16-2010, 12:57 PM   #3
BTH14
My Ride: M3
If you have a six speed trans this is plug and play. Other wise you need to have the driveshaft modified (different length) Doesn't come with the rear brakes.
Old 02-16-2010, 01:02 PM   #4
E46 S54B32
My Ride: 323ci
soo can i use my hubs on this so that i can use my brakes?
im also getting a 6 speed tranny too soon so i need this
any pics?
Old 02-16-2010, 01:25 PM   #5
BTH14
My Ride: M3
I am almost positive your hubs should fit no problem, but I encourage you to double check with your own research (check for other M diff swaps) just in case. I don't want to mislead anyone. The rear hub and trailing arm is one piece, and since the M3s have a wider rear track width this swap wouldn't be quite as common if the M3 axles didn't fit in the non M hubs. I can get pics this evening. Is there anything specific you want close up shots of?
Old 02-16-2010, 01:44 PM   #6
E46 S54B32
My Ride: 323ci
yea i tottally understand about misleading people..yea ill be doing some research today..umm notting really specific just some pics over all of the whole set up so i can see what im working with....any chance do you know how long it would take for a shop to swap this in my car and the tranny too?? more or less how much it would cost in labor?
thnaks
Old 02-16-2010, 07:16 PM   #7
BTH14
My Ride: M3
Here's a couple of pics, it still has all of the control arms and sway bar on it right now. Sorry the pics aren't great, I'll work on getting it apart and cleaned up this week and take some better ones, also try to weigh the stuff and get an idea for shipping. I took pics of all the subframe mount bushings to show that they're not falling apart or cracked. I don't have a picture of the drive shaft but like I said in the post that's included as well. I'll get some pics of that soon too. In terms of how long to install I can't say for sure. I can tell you that it took myself and a buddy about an hour and a half to drop out what you see in the pics. That consisted of dropping the exhaust, driveshaft, trailing arms, shocks, ebrake cables, brake lines, and the six bolts that hold the sub frame in. To fully install I'm guessing might take 4-5 hours considering you have to switch your suspension parts over. That's just a guess on my part though. I also have the additional u shaped subframe brace not shown in the pics.
ID:	348820   Click image for larger version
ID:	348821   Click image for larger version
ID:	348822   Click image for larger version
ID:	348824   Click image for larger version
Old 02-16-2010, 08:55 PM   #8
keithyaka
My Ride: 2003 m3 coupe 6 spd
might be intersted
If you need a set of M3 brakes, I have a mint set from my 22,600 mile M3 coupe.
See my thread:- http://forum.e46fanatics.com/showthr...915&highlight=
Let me know if you're interested.
Thanks,
Keith
P.S. free bump for the OP and a great deal.
keithyaka is online now   Reply With Quote
Old 02-16-2010, 10:43 PM   #9
E46 S54B32
My Ride: 323ci
Thanks,
Keith
alright ill deffinatly be getting backto you if i pick this up..it looks good from the pics..justy got out of work ill be doing my research now..yea and when you can a shipping estimate to 33174
Old 03-19-2010, 01:39 PM   #10
BTH14
My Ride: M3
Bump, willing to split this up if people are interested. Only 30K on everything
700 for diff and subframe, as mentioned all bushing look great. No cracks or dry rotting.
200 for full drive shaft.
150 for each axle.
Old 03-20-2010, 09:03 AM   #11
S54DR
My Ride: 332i/zhp/06 ZCP
the m3 rear will not fit on nonm hub/trailing arms. the m3 axle splines are bigger.
S54DR is offline   Reply With Quote
Old 03-20-2010, 09:32 AM   #12
BTH14
My Ride: M3
I've heard this is not the case, but I can't say for certain since I haven't tried myself. Have you done it yourself and had the issue? I know there are a number of Non M cars that have done this swap but don't use the M3 hub/trailing arm due to the wider track width.
Old 03-20-2010, 10:44 AM   #13
e46 330ci
My Ride: 2004 330Cic ZHP
Where in central NY are you located?
e46 330ci is offline   Reply With Quote
Old 03-21-2010, 03:25 PM   #14
BTH14
My Ride: M3
PMed
Old 03-23-2010, 12:48 PM   #15
BTH14
My Ride: M3
This would be a easy way to put almost new bushings and diff into high mileage M3
Also good for anyone wanting to get rid of the one wheel peel in non M cars. Anyone going FI or tracking could use this.
Old 04-06-2010, 12:14 PM   #16
BTH14
My Ride: M3
BUMP, low milage LSD guys
Old 04-12-2010, 01:26 PM   #17
BTH14
My Ride: M3
Bump, willing to split up. Make me offers on what you're interested in.
Old 05-11-2010, 10:56 AM   #18
BTH14
My Ride: M3
bump guys
Old 05-18-2010, 01:36 PM   #19
mttfrnndz
My Ride: JB/IR e46 m3 coupe
can i pick up the diff tomorrow?
CURRENT MODS LIST:
AA ssk | Frenetik rotors | axxis pads | injen intake | evo sport pulleys | gtr hood | csl v1 bumper | cdv delete | tein springs| RE: RSM,FCAB,RTAB| KONI yellows | f&r sway bars | race lip |black wheels | csl diffuser & trunk! |headers|shark race software| other secret stuff
FUTURE MODS:
summer?..hpf turbo :)
mttfrnndz is offline   Reply With Quote
Old 05-18-2010, 01:36 PM   #20
mttfrnndz
please pm me
CURRENT MODS LIST:
FUTURE MODS:
axles, diff, driveshaft, lsd
