Old 03-04-2010, 06:08 PM   #1
lkstaack
My Ride: 04 330iZHP, 05 325iT
BMW Codes: Need BMW Tech Help
I recently purchased the Autoenginuity scanner with enhanced BMW support. One of the great things about enhanced support is that it provides BMW factory codes. One of the bad things is that BMW refuses to publish their trouble code tables. So, while the AE scanner has reported two specific BMW codes, I don't know what they mean. I am hoping that a BMW Technician can verify my google search.
A search seems to indicate that "28DD" refers to a problem with the Secondary Air Injection System and that "2770" refers to a problem with fuel metering. Can someone with expert knowledge verify that? Thanks.
Lars
2004 330i ZHP ESS TS2
lkstaack is offline   Reply With Quote
Old 03-04-2010, 06:25 PM   #2
N4NOOK
My Ride: 323ci
http://www.obd-codes.com/trouble_codes/bmw/
N4NOOK is offline   Reply With Quote
Old 03-04-2010, 07:09 PM   #3
lkstaack
Originally Posted by N4NOOK View Post
People who know more about these things than I do tell me those are not factory codes; i.e. the codes that a GT-1 would report.
Lars
Old 03-04-2010, 08:08 PM   #4
TxZHP04
My Ride: ESS TS2+ ZHP
2770: Secondary Air Mass Flow Sensor Circuit
28DD: Air Mass System (or, according to my Bentley, barometric pressure plausibility)
Old 03-04-2010, 09:16 PM   #5
lkstaack
This stuff is in the Bentley Manual? Jeez, I need to crack it open!
Lars
Old 03-04-2010, 10:33 PM   #6
genuity
My Ride: 2001 330iS
It's all in the Bentley!
genuity is offline   Reply With Quote
