Old 02-16-2010, 02:35 PM   #1
david @ eas
david @ eas's Avatar
My Ride: E46 M3
eas | Snow Performance - Stage 2 Boost Cooler now Available!
Gentlemen,
For those of you running high boost, who wants to get some added horsepower to get your car noticed more than the rest, Methanol is the way to go.
This kit uses manifold boost pressure to determine when and how much fluid to inject. Proportionally injecting according to boost pressure gives the most accurate delivery of water-methanol and allows the most cooling and performance improvement over the widest range. More power and driveability is the result. It can be used on any forced induction engine: carbureted, fuel injected, turbocharged, positive displacement or centrifugal blowers. The most suitable are the centrifugal supercharged and turbocharged engines, as they build boost is a more progressive manner concerning water-methanol injection. The positive displacement blower engines will work, but it might take more work to dial in the delivery. For higher boost applications (over 25psi), the controller can be upgraded to our VC100 unit. Now with Lifetime Warranty - please see details.
Kit includes
- SHO (Special High Output) Pump
- 3 Quart Reservoir
- Digital Variable Controller
- 2 Nozzles To Cover a Wide Range of Horsepower
- All Required Hardware Needed For Installation
- Comprehensive Instructions
http://www.europeanautosource.com/pr...oducts_id=2542
If you have any questions about running Meth/Water please contact me directly via PM, email or simply just give me a call!
David ///M | eas
david@europeanautosource.com web: www.europeanautosource.com
tel 866.669.0705 x33 | ca: 714.369.8524
Blog | YouTube | facebook | twitter | flickr
david @ eas is offline   Reply With Quote
Old 02-18-2010, 02:57 PM   #2
sheefo2k
sheefo2k's Avatar
My Ride: vrm psh - 02 325ci
added to the list of things I need to order from you guys!!
Performance BMW car
Sponsored by :
www.euro-spec.net
www.bimmian.com
BMW Motorwerks
support:
www.vmwerks.com
www.esstuning.com
www.my330i.com
sheefo2k is offline   Reply With Quote
Old 06-05-2010, 11:54 PM   #3
Au2bahn
My Ride: 05 330i ZHP,09 HCHII
Will this work on a Twin Screw system?
Au2bahn is offline   Reply With Quote
Old 06-07-2010, 11:09 AM   #4
david @ eas
My Ride: E46 M3
It'll work with any application really. N/A and F/I. Doesn't matter what style supercharger you have whether it's Roots style, twin screw, centrifugal, and even the turbo applications.
Obviously depending on these applications will you see a set HP gain, but if you're in F/I, you're going to see decent gains way above your HP level now. Just PM me if you want to order or if you have any specific questions about the kit and your car.
David ///M | eas
