Sponsored by The Tire Rack
Old 02-16-2010, 05:07 PM   #1
invictus
My Ride: M3 (F80 & E46), S3R
(noob) wheel fitment question
So I'm looking at picking up this set of Hamann HM2s, supposedly in an M3 fitment (they will be going on an M3) from a guy on the forum--
the wheels are 19x8.5 et 13 front, 19x10 et 22 rear.
Obviously this doesn't match the 'stock' specs.
Is my math correct in saying that the fronts will be pushed out 28mm compared to stock (ie, pretty damn flush if not poking a bit) and the rears and the rears pushed out 11mm?
Will I have problems with these running a 245/35/19f 275/30/19r (Goodyear F1 Asymetrics)? Do I need any fender work?
Suspension is currently stock, but will probably be replaced with camber plates and a TCKline double adjustables in the near future, with a small drop.
Thanks in advance!
CCW. Dunlop. Ground Control. StopTech. Hawk. Vorschlag. Rogue Engineering. Recaro. TCDesign. RaceTech. VAC. Motul. Vorsteiner.
Find me on track: 10/19-21 Sonoma Speedway // 11/10-11 Thunderhill
The story so far...
Fund my track car:
PM me about my: stock diffuser, stock trunk, e46 m3 part out
invictus is offline   Reply With Quote
Old 02-16-2010, 06:05 PM   #2
invictus
I was using http://www.1010tires.com/WheelOffsetCalculator.asp
The story so far...
Fund my track car:
Old 02-16-2010, 07:34 PM   #3
BartenderPlease
My Ride: '03 540i/6 M-Sport
Thanks in advance!
That setup will work fine considering a small drop and if you will have these camber plates and adjustables for the rear you should be able to dial out any possible rubbing.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Trim | JL Audio | V1
BartenderPlease is offline   Reply With Quote
Old 02-16-2010, 07:38 PM   #4
invictus
thanks!
The story so far...
Fund my track car:
