Sponsored by The Tire Rack
Old 02-16-2010, 08:15 PM   #1
lister1919
My Ride: s are red and black
Tight squeeze.
17x9.5 all around
ET55
On my sedan
Are they going to fit?
lister1919 is offline   Reply With Quote
Old 02-16-2010, 08:20 PM   #2
Penguin Koolaid
Banned
My Ride: Inline Six
Originally Posted by lister1919 View Post
17x9.5 all around
ET55
On my sedan
You're going to rub the strut on the front suspension. Even if you used spacers to push them out 10mm, it's going to poke.
Penguin Koolaid is offline   Reply With Quote
Old 02-16-2010, 08:21 PM   #3
Rotha
My Ride: N/A
Bbs rs?
The best thread on e46fanatics. Prompt answers by knowledgeable people and you don't get flamed for it.
http://forum.e46fanatics.com/showthread.php?t=523290
Welcome to e46fanatics.
Rotha is offline   Reply With Quote
Old 02-16-2010, 08:30 PM   #4
lister1919
So they will rub the strut even with spacers? Probably won't even fit in the rear. What is standard offset for e46?
Originally Posted by photogenic View Post
Bbs rs?
Yee, RS from a 'vette I believe
Old 02-16-2010, 10:36 PM   #5
BartenderPlease
My Ride: 328i Sport
Send a message via AIM to BartenderPlease
No it won't. Once a 9.5 starts to reach the offset in the low/mid 30's is when it starts to poke in the front of an e46.
Those wheels will work but will require spacers to prevent rubbing on the strut side of the vehicle. Use a 10mm spacer for the rear and about a 15mm for the front, maybe 12 depending on what suspension you have.
Gottalovethexi: thx for the old p-chopped sig
| BBS CH | FK coils | RE Bushings/Mounts | K&N Intake | ZHP box/no resonators |
| 330i brakes | FX-R + Orion V4 | Full Exterior LED kit | JL Audio in trunk |
BartenderPlease is offline   Reply With Quote
Old 02-17-2010, 10:16 AM   #6
Rotha
My Ride: N/A
if i had the money, i would replace the barrels. i have a set sitting at my shop, i just havent gotten to wanting to mount it, im rollin around on my track wheels right now.
im thinkin about selling my bbs rs and just being normal.
Old 02-17-2010, 04:30 PM   #7
Penguin Koolaid
Banned
My Ride: Inline Six
Spacers will resolve the issue of rubbing against the front struts, but then you have to contend with the wheel poking out past the fender. That may be problematic if you have a lowered suspension.
8.5 width with an et35 sits flush with the front fender. In order to clear the struts, it will definitely poke.
Old 02-17-2010, 04:59 PM   #8
kenny81
My Ride: 04 330i
I ran an 18x8 et20mm up front and the lip on the wheel was flush with the fender.As for the back it was a 18x9 24mm offset that needed the fenders trimmed and negative camber.Apex Motorsports sells a 18x9 square setup for the e46 and the offset is 42mm.So I think with some spacers you'l be fine maybe some tire stretching also
ID:	348953   Click image for larger version
kenny81 is offline   Reply With Quote
Old 02-17-2010, 05:16 PM   #9
BartenderPlease
My Ride: 328i Sport
I guess different cars create different results. ie. my alignment specs being different than yours. my -2* front camber gives me about 5mm or less of poke.
Here is how it fits
Old 02-17-2010, 05:53 PM   #10
VMRWheels
VMRWheels's Avatar
My Ride: 1:25 Scale Enzo
You'll need at least a 9.5 +33 up front to clear the shock/coilover body. Anything higher, you will run into problems. With that said, you can throw on a 255 tire up front with some camber.
-Charles@VMRWheels
Kevin @ VMR | Wheels
Tel: 714-442-7916 | Email: kevin.a@velocitymotoring.com
Facebook! | Flickr! | Blog!
Old 02-17-2010, 06:02 PM   #11
kenny81
My Ride: 04 330i
Here is how it fits
Sorry not to threadjack but your car looks awesome
Old 02-17-2010, 06:19 PM   #12
330xiBoarder
My Ride: a car
i thought this thread was gonna be about a fat chick in someones ride
330xiBoarder is offline   Reply With Quote
Old 02-17-2010, 07:20 PM   #13
lister1919
I wish...
hah.
I need to get my hands on a set of style 5's. ASAP!
Old 02-17-2010, 07:27 PM   #14
kenny81
My Ride: 04 330i
I wish...
hah.
Imo I would get the rs you were talking about.I like the step lip better how much you offering for them btw?
Old 02-17-2010, 11:13 PM   #15
Penguin Koolaid
Banned
My Ride: Inline Six
-2 is pretty aggressive compared to the stock specifications. Plus he'll have to stretch the tire as well. Then he'll just have to worry about the tires wearing quickly on the insides.
Old 02-17-2010, 11:38 PM   #16
BartenderPlease
My Ride: 328i Sport
A stretch wouldn't be too necessary. A 235/45/17 tire *should* fit with a bit of a slope on the sidewall, but not a huge stretch look. With a 20mm spacer I say it is doable depending on how low you go and with factory alignment, -1* front camber.
Being said, it still has to possibility of rubbing. Its what happens sometimes when you start doing custom, out of the ordinary fitment.
